Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Connection Pools: WebSphere LibertyConnection Pools: WebSphere Liberty
Application server method of pooling and sharing connections to a database.
Extension
Free trialDocumentation
Easily monitor all your Websphere Liberty connection pools in your environment thanks to the overview dashboard, automatically included with the extension activation.Get detailed insights into each individual connection pool thanks to the customized screen that comes with each instance of the automatically generated Liberty Connection Pool generic type.
  • Product information
  • Release notes
Overview
Several built-in OneAgent extensions provide insight into connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
Use cases
This extension collects connection pool performance, usage and availability metrics for Websphere Liberty.
Prerequisites:
  • Websphere process that runs on a supported Linux or Windows operating system.
  • OneAgent version 1.273+
  • Dynatrace version 1.273+
To get metric insight:
  1. Install OneAgent on the virtual machine or server of your Websphere process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the Liberty Connection Pool Overview dashboard.
Get started
For more information on the installation and configuration, please see Connection Pools: WebSphere Liberty extension in the Dynatrace Documentation.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Managed connectionsliberty.connectionPool.managedConnectionCount-Count
In use connectionsliberty.connectionPool.connectionHandleCount-Count
Free connectionsliberty.connectionPool.freeConnectionCount-Count
In use timeliberty.connectionPool.inUseTime-MilliSecond
Wait timeliberty.connectionPool.waitTime-MilliSecond
Full version history
ReleaseDate
New in this version:
  • Added keyword key value pairs to extension
Minimum Dynatrace version now 1.310!
Changes
  • Security context attribute on connection pool entity
  • New Dashboards App dashboard
  • Platform-ready screen definitions
  • Fixed a bug that prevented charts from being injected correctly
Convert EF1.0 to EF2.0:
  • Add Liberty Connection Pool entity and its relation to the Process Group Instance
  • Add Unified Analysis screen for Liberty Connection Pool
  • Add injection charts into Unified Analysis screen for Process Group Instance
  • Add overview dashboard
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
