Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cloudflare (extension)Cloudflare (extension)
Collect notification history and various metrics from your Cloudflare accounts.
Extension
Free trialDocumentation
Overview dashboardAccount screenExample monitoring configurationWorker screenZone screen
  • Product information
  • Release notes
Overview
Cloudflare is a platform that is built to improve the security, performance, and reliability of systems connected to the Internet. It primarily does this by serving as a reverse proxy for your web traffic. Your traffic flows through Cloudflare where rules and optimizations are applied to meet its goals.
Cloudflare is in a position where it has great visibility into your traffic and web performance. Dynatrace can collect this information and make it available in Dynatrace for use monitoring and analytics purposes in context with the rest of your Dynatrace information. The extension queries various APIs to collect metrics as well as notification history for ingestion into Dynatrace.
Use cases
  • Ingest metrics for use in context with Dynatrace information:
    • HTTP traffic
    • DNS analytics
    • Worker activity and performance
  • View notification history within Dynatrace for events detected in Cloudflare such as DDoS attacks
Get started
For more information on the installation and configuration, please see Cloudflare (extension) extension in the Dynatrace Documentation.
Details
Compatibility information
Metrics and events are pulled from the Cloudflare API and so access to this API alongside a token with proper permissions is required.
To access 1-minute granularity data for HTTP-traffic a paid Cloudflare account is required as this information is not available over API for 'free' accounts.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Worker requestscloudflare.workers.requestsTotal worker requestsCount
Worker subrequestscloudflare.workers.subrequestsTotal worker subrequestsCount
Worker errorscloudflare.workers.errorsTotal worker errorsCount
Worker durationcloudflare.workers.durationWorker durationKiloBytePerSecond
Worker duration 50th percentilecloudflare.workers.duration_p50Worker duration 50th percentileKiloBytePerSecond
Worker duration 99th percentilecloudflare.workers.duration_p99Worker duration 99th percentileKiloBytePerSecond
Worker wall timecloudflare.workers.wall_timeWorker wall timeMicroSecond
Worker wall time 50th percentilecloudflare.workers.wall_time_p50Worker wall time 50th percentileMicroSecond
Worker wall time 99th percentilecloudflare.workers.wall_time_p99Worker wall time 99th percentileMicroSecond
Worker CPU time 50th percentilecloudflare.workers.cpu_time_p50Worker CPU time 50th percentileMicroSecond
Worker CPU time 99th percentilecloudflare.workers.cpu_time_p99Worker CPU time 99th percentileMicroSecond
Total requestscloudflare.http.total_requestsTotal requests in this zoneCount
Cached requestscloudflare.http.cached_requestsRequests satisfied by the cacheCount
Bytescloudflare.http.bytesTotal bytes returned to the clientByte
Cached bytescloudflare.http.cached_bytesBytes returned to client from cacheByte
Encrypted bytescloudflare.http.encrypted_bytesBytes returned to client using SSL/TLS protocolByte
Threatscloudflare.http.threatsRequests classified as threatsCount
Requests by SSL protocolcloudflare.http.requests_by_ssl_protocolRequests broken down by SSL protocol versionCount
Requests by content typecloudflare.http.requests_by_content_typeRequests broken down by retuend content typeCount
Bytes by countrycloudflare.http.bytes_by_countryBytes returned to client broken down by countryByte
Requests by countrycloudflare.http.requests_by_countryRequests broken down by countryCount
Threats by countrycloudflare.http.threats_by_countryRequests classified as threats broken down by countryCount
Threats by pathing namecloudflare.http.threats_by_pathing_nameRequests classified as requests broken down by threat typeCount
Number of Cloudflare notificationscloudflare.notificationsThe number of notifications that have been pulled from CloudflareCount
DNS query countcloudflare.dns.queriesTotal DNS queriesCount
Full version history
ReleaseDate
  • Ensure required dimensions exist for entity creation
  • Update entity links in Dashboard App dashboards to use latest urls
New minimum Dynatrace version 1.313!
Changes
  • Improved error handling (Dynatrace Error Codes) and Endpoint Statuses.
New minimum Dynatrace version 1.310!
Changes
  • Platform dashboard
  • Add security context to all entities
  • App ready
  • Fixes rare issue where in some environments the proxy configuration was ignored
  • Configurable query delay
    • In large environments it was possible for some periods to not have all data available even with the built in delay of 5 minutes. This version has a configurable delay you can increase if you have large environments and notice frequent unexpected dips in data that is not seen in the Cloudflare UI.
    • Additionally, this version forces the query window to be the top of the minute for easier comparisons to Cloudflare exported data
  • Corrects bug with pagination that could result in some zones collecting duplicate data if a large number of zones are present
  • Improved method of determining timeframe to query
    • Prevents backwards drift that could cause delayed data or missing data in some situations
  • Cleaner error handling of no data in an interval for http-traffic
  • Correct fastcheck reporting in case of failures
  • Avoid loop if no zones accessible in account
  • Logging improvements
  • Enforce minimum of 1 account configured in configuration UI
  • batch requests for traffic data requests to reduce total number of API calls and decrease duration
  • improved error handling
  • respect pagination on the 'list zones' for scenarios where more than 50 zones are in an account
  • detect when a filtered zone configured is not found and do a direct lookup for this zone to cover scenarios where in some scenarios all zones are not actually included in the 'list zones' API call
    • Zones must be filtered by ID (not name) for this to work
  • Fixes bug that would cause the query time frame to drift resulting in empty data
No release notes
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
