Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Citrix Netscaler ADCCitrix Netscaler ADC
Remotely monitor your Citrix NetScaler devices
Extension
Free trialDocumentation
Extension dashboardMetricsService Unified Analysis ScreenNetscaler Device Unified Analysis ScreenExtension Configuration
  • Product information
  • Release notes
Overview
Citrix NetScaler ADCs help enterprises secure applications and data. However, they do not permit the installation of agent-based monitoring solutions. For this, Dynatrace offers remote monitoring of NetScaler devices via the Citrix NetScaler ActiveGate extension. Our extension queries devices every minute and retrieves key performance data. These metrics are paired with OneAgent data to provide real-time interaction visualization and the ability to follow transactions throughout your stack.
Use cases
This is intended for users, who:
  • Would like to monitor the health and performance of their NetScaler services
This enables you to:
  • Monitor NetScaler with a dedicated dashboard and Dynatrace entities to represent core components
  • Detect and alert on anomalies
Get started
For more information on the installation and configuration, please see Citrix Netscaler ADC extension in the Dynatrace Documentation.
Details
Compatibility information
  • 12.x
  • 13.x
  • 14.x
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Power supply -12V outputnetscaler.system.voltagev12nPower supply -12V output. Acceptable range is -13.20 through -10.80 volts. 9800 and 9960 platforms display standard value of -12.0V.Count
Power supply -5V outputnetscaler.system.voltagev5nPower supply -5V output. Acceptable range is -5.50 through -4.50 volts. 9800 and 9960 platforms display standard value of -5.0V.Count
Power supply +12V outputnetscaler.system.voltagev12pPower supply +12V output. Acceptable range is 10.80 through 13.20 volts.Count
Power supply +5V outputnetscaler.system.voltagev5pPower supply +5V output. Acceptable range is 4.50 through 5.50 volts.Count
Main power supply +3.3V outputnetscaler.system.voltagev33mainMain power supply +3.3V output. Acceptable range is 2.970 through 3.630 volts. This is a critical counter.Count
CPU core 1 voltagenetscaler.system.voltagevcc1CPU core 1 voltage. Acceptable range is 1.080 through 1.650 volts. If CPU 1 is not connected to the health monitoring chip, display shows voltage of CPU 0.Count
CPU core 0 voltagenetscaler.system.voltagevcc0CPU core 0 voltage. Acceptable range is 1.080 through 1.650 volts.Count
Pin 0 voltagenetscaler.system.auxvolt0Voltage of a device connected to health monitoring chip through pin 0.Count
Pin 1 voltagenetscaler.system.auxvolt1Voltage of a device connected to health monitoring chip through pin 1.Count
Pin 2 voltagenetscaler.system.auxvolt2Voltage of a device connected to health monitoring chip through pin 2.Count
Pin 3 voltagenetscaler.system.auxvolt3Voltage of a device connected to health monitoring chip through pin 3.Count
Pin 4 voltagenetscaler.system.auxvolt4Voltage of a device connected to health monitoring chip through pin 4.Count
Pin 5 voltagenetscaler.system.auxvolt5Voltage of a device connected to health monitoring chip through pin 5.Count
Pin 6 voltagenetscaler.system.auxvolt6Voltage of a device connected to health monitoring chip through pin 6.Count
Pin 7 voltagenetscaler.system.auxvolt7Voltage of a device connected to health monitoring chip through pin 7.Count
Power supply 1 failure statusnetscaler.system.powersupply1statusPower supply 1 failure status.Count
Power supply 2 failure statusnetscaler.system.powersupply2statusPower supply 2 failure status.Count
Power supply 3 failure statusnetscaler.system.powersupply3statusPower supply 3 failure status.Count
Power supply 4 failure statusnetscaler.system.powersupply4statusPower supply 4 failure status.Count
AAATM Current Sessionsnetscaler.aaa.aaacurtmsessionsCount of current AAATM sessions.Count
Basic ICA Sessionsnetscaler.aaa.aaacuricasessionsCount of current Basic ICA only sessions.Count
Basic ICA Connectionsnetscaler.aaa.aaacuricaonlyconnCount of current Basic ICA only connections.Count
SmartAccess ICA Connectionsnetscaler.aaa.aaacuricaconnCount of current SmartAccess ICA connections.Count
Current SmartAccess AAA sessionsnetscaler.aaa.aaacursessionsCount of current SmartAccess AAA sessions.Count
vserver Statenetscaler.lbvserver.stateCurrent state of the server.Count
Request Bytesnetscaler.lbvserver.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Byte
Response Bytesnetscaler.lbvserver.totalresponsebytes.countNumber of response bytes received by this service or virtual server.Byte
Total vserver hitsnetscaler.lbvserver.tothits.countTotal vserver hitsCount
Total vserver requestsnetscaler.lbvserver.totalrequests.countTotal number of requests received on this service or virtual server.Count
Total vserver responsesnetscaler.lbvserver.totalresponses.countNumber of responses received on this service or virtual server.Count
Current vserver Connectionsnetscaler.lbvserver.cursrvrconnectionsNumber of current connections to the actual servers behind the virtual server.Count
Client connectionsnetscaler.lbvserver.curclntconnectionsNumber of current client connections.Count
Tolerable Transactionsnetscaler.lbvserver.toleratingttlbtransactions.countTolerable transactions based on APDEX threshold (>T ;; <4T).Count
Frustrating Transactionsnetscaler.lbvserver.frustratingttlbtransactions.countFrustrating transactions based on APDEX threshold (>4T).Count
Surge Requestsnetscaler.lbvserver.surgecount.countNumber of requests in the surge queue.Count
Invalid Requests and Responsesnetscaler.lbvserver.invalidrequestresponse.countNumber invalid requests/responses on this vserverCount
Invalid Requests and Responses Droppednetscaler.lbvserver.invalidrequestresponsedropped.countNumber invalid requests/responses dropped on this vserverCount
Backup traffic diversionsnetscaler.lbvserver.totvserverdownbackuphits.countNumber of times traffic was diverted to backup vserver since primary vserver was DOWN.Count
Active Servicesnetscaler.lbvserver.actsvcsnumber of ACTIVE services bound to a vserverCount
vserver Healthnetscaler.lbvserver.vslbhealthHealth of the vserver. This gives percentage of UP services bound to this vserver.Percent
vpnvserver Requestsnetscaler.vpnvserver.totalrequests.countTotal number of requests received on this service or virtual server.Count
vpnvserver Responsesnetscaler.vpnvserver.totalresponses.countNumber of responses received on this service or virtual server.Count
CPU 0 temperaturenetscaler.system.cpu0tempCPU 0 temperature. 9800 and 9960 platforms display internal chip temperature. This is a critical counter.Count
CPU 1 temperaturenetscaler.system.cpu1tempCPU 1 temperature. 9800 and 9960 platforms display internal chip temperature. 7000, 9010 and 10010 platforms display CPU 0 temperature. This is a critical counter.Count
Internal temperature of health monitoring chipnetscaler.system.internaltempInternal temperature of health monitoring chip. This is a critical counter.Count
Temperature of pin 0netscaler.system.auxtemp0Temperature of a device connected to health monitoring chip through pin 0.Count
Temperature of pin 1netscaler.system.auxtemp1Temperature of a device connected to health monitoring chip through pin 1.Count
Temperature of pin 2netscaler.system.auxtemp2Temperature of a device connected to health monitoring chip through pin 2.Count
Temperature of pin 3netscaler.system.auxtemp3Temperature of a device connected to health monitoring chip through pin 3.Count
Disk /flash used spacenetscaler.system.disk0usedUsed space in /flash partition of the hard disk.Byte
Disk /flash available spacenetscaler.system.disk0availAvailable space in /flash partition of the hard disk.Byte
Disk /var used spacenetscaler.system.disk1usedUsed space in /var partition of the hard disk.Byte
Disk /var available spacenetscaler.system.disk1availAvailable space in /var partition of the hard disk.Byte
Used /flash space (%)netscaler.system.disk0perusageUsed space in /flash partition of the disk, as a percentage. This is a critical counter.Percent
Used /var space (%)netscaler.system.disk1perusageUsed space in /var partition of the disk, as a percentage. This is a critical counter.Percent
csvserver Statenetscaler.csvserver.stateCurrent state of the server.Count
Total Request Bytesnetscaler.csvserver.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Byte
Total Response Bytesnetscaler.csvserver.totalresponsebytes.countNumber of response bytes received by this service or virtual server.Byte
Total vserver hitsnetscaler.csvserver.tothits.countTotal vserver hitsCount
Days until SSL certificate expirynetscaler.sslcertkey.daystoexpirationDays remaining for the certificate to expire.Day
Total requestsnetscaler.gslbservice.totalrequests.countTotal number of requests received on this service or virtual server.Count
Total responsesnetscaler.gslbservice.totalresponses.countNumber of responses received on this service or virtual server.Count
Current server connectionsnetscaler.gslbservice.cursrvrconnectionsNumber of current connections to the actual servers behind the virtual server.Count
Current client connectionsnetscaler.gslbservice.curclntconnectionsNumber of current client connections.Count
Established client connectionsnetscaler.gslbservice.establishedconnNumber of client connections in ESTABLISHED state.Count
Total vserver requestsnetscaler.csvserver.totalrequests.countTotal number of requests received on this service or virtual server.Count
Total vserver responsesnetscaler.csvserver.totalresponses.countNumber of responses received on this service or virtual server.Count
Current vserver Connectionsnetscaler.csvserver.cursrvrconnectionsNumber of current connections to the actual servers behind the virtual server.Count
Current client Connectionsnetscaler.csvserver.curclntconnectionsNumber of current client connections.Count
Tolerable Transactionsnetscaler.csvserver.toleratingttlbtransactions.countTolerable transactions based on APDEX threshold (>T ;; <4T).Count
Frustrating Transactionsnetscaler.csvserver.frustratingttlbtransactions.countFrustrating transactions based on APDEX threshold (>4T).Count
Invalid requests and reponsesnetscaler.csvserver.invalidrequestresponse.countNumber invalid requests/responses on this vserverCount
Invalid requests and reponses droppednetscaler.csvserver.invalidrequestresponsedropped.countNumber invalid requests/responses dropped on this vserverCount
gslbservice statenetscaler.gslbservice.stateCurrent state of the service.Count
Request Bytesnetscaler.gslbservice.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Byte
Response Bytesnetscaler.gslbservice.totalresponsebytes.countNumber of response bytes received by this service or virtual server.Byte
Service Provided Countnetscaler.gslbservice.vsvrservicehits.countNumber of times that the service has been provided.Count
Total Requestsnetscaler.authenticationvserver.totalrequests.countTotal number of requests received on this service or virtual server.Count
Total Requestsnetscaler.authenticationvserver.totalresponses.countNumber of responses received on this service or virtual server.Count
Heartbeat packets receivednetscaler.hanode.hatotpktrx.countNumber of heartbeat packets received from the peer node.Count
Heartbeat packets sentnetscaler.hanode.hatotpkttx.countNumber of heartbeat packets sent from the peer node.Count
Propagation timeoutsnetscaler.hanode.haerrproptimeout.countNumber of times propagation timed out.Count
Configuration synchronization failurenetscaler.hanode.haerrsyncfailure.countNumber of times the configuration of the primary and secondary nodes failed to synchronize since that last transition.Count
High availability current statenetscaler.hanode.hacurstateState of the HA node, based on its health, in a high availability setup.Count
High availability node statenetscaler.hanode.hacurmasterstateIndicates the high availability state of the node.Count
SmartAccess AAA Sessionsnetscaler.aaa.aaatotsessions.countCount of all SmartAccess AAA sessions.Count
AAA Authentication Successesnetscaler.aaa.aaaauthsuccess.countCount of authentication successes.Count
AAA Session Timeoutsnetscaler.aaa.aaatotsessiontimeout.countCount of AAA sessions that have timed out.Count
AAA Authentication Failuresnetscaler.aaa.aaaauthfail.countCount of authentication failures.Count
AAATM Sessionsnetscaler.aaa.aaatottmsessions.countCount of all AAATM sessions.Count
HTTP Connection Successesnetscaler.aaa.aaaauthonlyhttpsuccess.countCount of HTTP connections that succeeded authorization.Count
AAA non-http connection successesnetscaler.aaa.aaaauthnonhttpsuccess.countCount of non HTTP connections that succeeded authorization.Count
AAA HTTP Connection Failuresnetscaler.aaa.aaaauthonlyhttpfail.countCount of HTTP connections that failed authorization.Count
AAA Non-HTTP Connection Failuresnetscaler.aaa.aaaauthnonhttpfail.countCount of non HTTP connections that failed authorization.Count
Total Requestsnetscaler.gslbvserver.totalrequests.countTotal number of requests received on this service or virtual server.Count
Total Requestsnetscaler.gslbvserver.totalresponses.countNumber of responses received on this service or virtual server.Count
Established Connectionsnetscaler.gslbvserver.establishedconnNumber of client connections in ESTABLISHED state.Count
Inactive Bound Servicesnetscaler.gslbvserver.inactsvcsNumber of INACTIVE services bound to a vserver.Count
Active Bound Servicesnetscaler.gslbvserver.actsvcsNumber of ACTIVE services bound to a vserver.Count
Current Client Connectionsnetscaler.gslbvserver.curclntconnectionsNumber of current client connections.Count
Total vServer Hitsnetscaler.gslbvserver.tothits.countTotal vserver hits.Count
Time Since Start - Uptimenetscaler.system.timesincestartSeconds since the Citrix ADC started.Seconds
Management CPU Utilization.netscaler.system.mgmtcpuusagepcntAverage Management CPU utilization percentage.Percent
Packet Engines CPU Utilization.netscaler.system.pktcpuusagepcntAverage CPU utilization percentage for all packet engines excluding management PE.Percent
Memory Used (MB).netscaler.system.memuseinmbMain memory currently in use, in megabytes.MegaByte
Memory Utilization.netscaler.system.memusagepcntPercentage of memory utilization on NetScaler.Percent
Service group statenetscaler.servicegroup.stateCurrent state of the server.Count
Total Requestsnetscaler.service.totalrequests.countTotal number of requests received on this service or virtual server.Count
Total Responsesnetscaler.service.totalresponses.countNumber of responses received on this service or virtual server.Count
Server connectionsnetscaler.service.cursrvrconnectionsNumber of current connections to the actual servers behind the virtual server.Count
Client connectionsnetscaler.service.curclntconnectionsNumber of current client connections.Count
Tolerating Transactionsnetscaler.service.toleratingttlbtransactions.countTolerable transactions based on APDEX threshold (>T ;; <4T).Count
Frustrating Transactionsnetscaler.service.frustratingttlbtransactions.countTolerable transactions based on APDEX threshold (>T ;; <4T).Count
Surge Queue Requestsnetscaler.service.surgecount.countNumber of requests in the surge queue.Count
Average time to first bytenetscaler.service.avgsvrttfbAverage TTFB between the NetScaler appliance and the server.Second
authenticationvserver statenetscaler.authenticationvserver.stateCurrent state of the virtual server.Count
Total Request Bytesnetscaler.authenticationvserver.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Byte
Total Response Bytesnetscaler.authenticationvserver.totalresponsebytes.countTotal number of response bytes received on this service or virtual server.Byte
HTTP Compression Bandwidth Savingnetscaler.cmp.comphttpbandwidthsavingBandwidth saving from HTTP compression expressed as percentage.Percent
TCP Compression Bandwidth Savingnetscaler.cmp.comptcpbandwidthsavingBandwidth saving from TCP compression expressed as percentage.Percent
Inbound packets hardware droppednetscaler.Interface.rxerrors.countNumber of inbound packets dropped by the hardware on a specified interface once the NetScaler appliance starts or the interface statistics are cleared.Count
Outbound packets hardware droppednetscaler.Interface.txerrors.countNumber of outbound packets dropped by the hardware on a specified interface since the NetScaler appliance was started or the interface statistics were cleared.Count
Inbound packets discardednetscaler.Interface.indisc.countNumber of error-free inbound packets discarded by the specified interface due to a lack of resources.Count
Outbound packets discardednetscaler.Interface.outdisc.countNumber of error-free outbound packets discarded by the specified interface due to a lack of resources.Count
Inbound packets dropped interfacenetscaler.Interface.rxdrops.countNumber of inbound packets dropped by the specified interface.Count
Outbound packets dropped interfacenetscaler.Interface.txdrops.countNumber of packets dropped in transmission by the specified interface.Count
Days until license expirynetscaler.nslicense.daystoexpirationNumber of days until license expiryDay
Total Site Request Bytesnetscaler.gslbsite.sitetotalrequestbytes.countTotal number of request bytes received by the virtual servers represented by all GSLB services associated with this GSLB site.Byte
Total Site Response Bytesnetscaler.gslbsite.sitetotalresponsebytes.countNumber of response bytes received by the virtual servers represented by all GSLB services associated with this GSLB site.Byte
gslbvserver statenetscaler.gslbvserver.stateCurrent state of the virtual server.Count
Total Request Bytesnetscaler.gslbvserver.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Byte
Total Response Bytesnetscaler.gslbvserver.totalresponsebytes.countTotal number of response bytes received on this service or virtual server.Byte
vServer Healthnetscaler.gslbvserver.vslbhealthHealth of the vserver. This gives percentage of UP services bound to this vserver.Percent
vpnvserver Statenetscaler.vpnvserver.stateCurrent state of the server.Count
vpnvserver Request Bytesnetscaler.vpnvserver.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Count
vpnvserver Response Bytesnetscaler.vpnvserver.totalresponsebytes.countNumber of response bytes received by this service or virtual server.Count
service statenetscaler.service.stateCurrent state of the service.Count
Total Request Bytesnetscaler.service.totalrequestbytes.countTotal number of request bytes received on this service or virtual server.Byte
Total Response Bytesnetscaler.service.totalresponsebytes.countNumber of response bytes received by this service or virtual server.Byte
Throughputnetscaler.service.throughputNumber of bytes received or sent by this service (Mbps).MegaBytePerSecond
Connectivitynetscaler.system.connectivityNetscaler successful connection percentagePercent
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.cpu_ratio--
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_total--
-com.dynatrace.extension.network_device.if.status--
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.speed--
CPU Fan 0 speednetscaler.system.cpufan0speedCPU Fan 0 speed. Acceptable range is 3000 through 6000 RPM. This is a critical counter.Count
CPU Fan 1 speednetscaler.system.cpufan1speedCPU Fan 1 speed. Acceptable range is 3000 through 6000 RPM. 7000 platform displays speed of CPU fan 0. This is a critical counter.Count
System fan speednetscaler.system.systemfanspeedSystem fan speed. Acceptable range is 3000 through 6000 RPM. This is a critical counter.Count
System fan 1 speednetscaler.system.fan0speedSystem fan 1 speed. For new platforms associated pin is connected to CPU supporting fans. For platforms in which it is not connected, it will point to System Fan.Count
System fan 2 speednetscaler.system.fanspeedSystem fan 2 speed. For new platforms associated pin is connected to CPU supporting fans. For platforms in which it is not connected, it will point to System FanCount
Speed of Fan 0netscaler.system.fan2speedSpeed of Fan 0 if associated pin is connected to health monitoring chip.Count
Speed of Fan 1netscaler.system.fan3speedSpeed of Fan 1 if associated pin is connected to health monitoring chip.Count
Speed of Fan 2netscaler.system.fan4speedSpeed of Fan 2 if associated pin is connected to health monitoring chip.Count
Speed of Fan 3netscaler.system.fan5speedSpeed of Fan 3 if associated pin is connected to health monitoring chip.Count
Total Site Requestsnetscaler.gslbsite.sitetotalrequests.countTotal number of requests received by the virtual servers represented by all GSLB services associated with this GSLB site.Count
Total Site Responsesnetscaler.gslbsite.sitetotalresponses.countNumber of responses received by the virtual servers represented by all GSLB services associated with this GSLB site.Count
Current Site Client Connectionsnetscaler.gslbsite.sitecurclntconnectionsNumber of current client connections to the virtual servers represented by all GSLB services associated with this GSLB site.Count
Current Site Server Connectionsnetscaler.gslbsite.sitecursrvrconnectionsNumber of current connections to the real servers behind the virtual servers represented by all GSLB services associated with this GSLB site.Count
Interface Statenetscaler.Interface.intfstateCurrent state of the specified interface.Count
Interface Speednetscaler.Interface.speedActual speed setting for this interface - actspeed.Count
Bytes Receivednetscaler.Interface.rxbytes.countNumber of bytes received by an interface since the NetScaler appliance was started or the interface statistics were cleared.Byte
Bytes Transmittednetscaler.Interface.txbytes.countNumber of bytes transmitted by an interface since the NetScaler appliance was started or the interface statistics were cleared.Byte
Full version history
ReleaseDate
🐛 Bugs fixed in this version:
  • Resolved bug on network:interface UA screen where invalid entity selector error would appear
  • Resolve bug in which errors for hosts with a hyphen in their name were not reported to the UI properly
⚠️ Important Change:
  • This release requires a Minimum Dynatrace Version and Minimum ActiveGate version of 1.318.0 or higher.
New in this version:
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
Improved in this version:
  • Internal metadata updated.
🐛 Bugs Fixed:
  • Fixed Interfaces tile on Classic dashboard referencing incorrect metric key
NOTE: This version of the extension requires a minimum Dynatrace and EEC version of 1.313
  • Adds 6 new instance entity types that are split based upon the assigned primaryipaddress and primaryport
    • python:com_dynatrace_extension_netscaler_service_instance
    • python:com_dynatrace_extension_netscaler_lbvserver_instance
    • python:com_dynatrace_extension_netscaler_csvserver_instance
    • python:com_dynatrace_extension_netscaler_vpnvserver_instance
    • python:com_dynatrace_extension_netscaler_gslbservice_instance
    • python:com_dynatrace_extension_netscaler_authenticationvserver_instance
  • Adds an entity list for each new instance entity type to the preexisting entity's UA page
Major version update - please review release notes fully
⚠️ IMPORTANT CHANGES
Metrics in "default" feature set will always be enabled and cannot be disabled. These metrics are mandatory. Take extra caution configuring devices and interfaces for which you are collecting data. Make use of Interface filters to limit the number of interfaces, otherwise, all interfaces on the device will be collected by default.
  • FeatureSets have changed slightly. To migrate an existing monitoring configuration, uncheck the system-memory feature set and then select update.
    • system-memory feature set removed - metrics moved to system
    • The default feature set now includes the new generic network metrics
  • Network Device topology ID changed to use the Dynatrace default device.address
  • NetScaler ADC topology ID changed to use the system name (hostname) instead of the full host URL
  • Network Interface and Netscaler Interface topology ID now use the `mac.address.
  • Netscaler interface metrics are now collected from the /config/Interface API and the metric keys have slightly changed slightly. e.g, rxbytes instead of totrxbytes
New Features
  • Now collects Generic Network Topology metrics for the Dynatrace Infrastructure and Operations App.
    • include new metrics for interface speed and sysuptime
  • Adds a new platform overview dashboard
  • Generate new platform dashboard and screen updates
  • Add support for dt.security_context
  • Added support to link netscaler devices with process group instances via the SAME_AS relationship
  • Add credential vault support for username and password
  • Add network and interface entity types
  • Add new screen definitions
  • Fix for SSL_V3_ALERT_HANDSHAKE errors - custom SSL adaptor when verify SSL is false.
  • Fixed a bug where disabling feature sets would not prevent the metrics from being ingested
  • Refactored the entity definition and metric dimensions to adapt to the new NetScaler SDX extension
  • Add entity type to extension metrics for management zones and tagging rules
  • Update dependency packages
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
