Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cisco UCS M-SeriesCisco UCS M-Series
Cisco UCS M-Series
Cisco UCS M-Series
Get insights into your Cisco UCS M-Series devices
Extension
Free trialDocumentation
Cisco UCS M-Series Overview DashboardCisco UCS M-Series Overview Dashboard Pt.2Cisco UCS M-Series Service Profile View in I&O app
  • Product information
  • Release notes
Overview
Monitor your Cisco UCS M-Series devices with data collected through the UCS Manager API.
This extension collects infrastructure metrics to monitor the health and performance of your Cisco UCS M-Series devices and their components including CPU, fans, power supplies, interfaces and more.
Use cases
  • Monitor chassis and hardware health signals, including CPU temperature/current, fan, fan module, PSU, memory array, storage controller, local disk, and switch card properties.
  • Track Ethernet traffic and error counters for UCS ports, including receive/transmit bytes/packets, pause/error/collision counters, and utilization/headroom metrics.
  • Observe Fabric Interconnect environmental and system metrics.
  • Analyze uplink and pool-level behavior through metrics for Ethernet, server, and network port pools.
  • Detect device anomalies and avoid outages.
Get started
Activate the extension in your environment from Dynatrace Hub, configure connection details for your UCS endpoint, and select the feature sets you want to collect.
For more information on the installation and configuration, please see Cisco UCS M-Series extension in the Dynatrace Documentation.
Details
The extension package contains:
  • Overview dashboards (Classic & Platform)
  • Analysis screens integrated with the Infrastructure & Operations app
  • Unified analysis pages
  • Custom topology types extracted from metric dimensions:
    • Cisco UCS M-Series CPU
    • Cisco UCS M-Series Fan Module
    • Cisco UCS M-Series Local Disk
    • Cisco UCS M-Series Memory Array
    • Cisco UCS M-Series Power Supply
    • Cisco UCS M-Series Storage Controller
    • Cisco UCS M-Series Ethernet Port
    • Cisco UCS M-Series Ethernet Port Pool
    • Cisco UCS M-Series Network Port Pool
    • Cisco UCS M-Series Server Port Pool
    • Cisco UCS M-Series Fabric Interconnect
    • Cisco UCS M-Series Fabric Ethernet LAN PC
    • Cisco UCS M-Series Host Ethernet Interface
    • Cisco UCS M-Series Organization
    • Cisco UCS M-Series Rack
    • Cisco UCS M-Series Service Profile
    • Cisco UCS M-Series Switch Card
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
M-Series Memory Array Propertiesciscoucs.m_series.memoryArray.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Fan Propertiesciscoucs.m_series.fan.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Server Port Pool Bandwidth Headroom Rxciscoucs.m_series.serverPortPool.bandwidthHeadroomRxAggregation of the bandwidth headroom of all its membersBit
M-Series Server Port Pool Bandwidth Headroom Rx Balanceciscoucs.m_series.serverPortPool.bandwidthHeadroomRxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its membersBit
M-Series Server Port Pool Bandwidth Headroom Txciscoucs.m_series.serverPortPool.bandwidthHeadroomTxAggregation of the bandwidth headroom of all its membersBit
M-Series Server Port Pool Bandwidth Headroom Tx Balanceciscoucs.m_series.serverPortPool.bandwidthHeadroomTxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its membersBit
M-Series Server Port Pool Bandwidth Justified Headroom Rx Balanceciscoucs.m_series.serverPortPool.bandwidthJustifiedHeadroomRxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its members. The minimum operational speed of its members is the maximum value allowedBit
M-Series Server Port Pool Bandwidth Justified Headroom Tx Balanceciscoucs.m_series.serverPortPool.bandwidthJustifiedHeadroomTxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its members. The minimum operational speed of its members is the maximum value allowedBit
M-Series Server Port Pool Bandwidth Utilization Percentage Rxciscoucs.m_series.serverPortPool.bandwidthUtilizationPctRxCalculated as the average bandwidth utilization of its membersPercent
M-Series Server Port Pool Bandwidth Utilization Percentage Rx Balanceciscoucs.m_series.serverPortPool.bandwidthUtilizationPctRxBalanceCalculated as the median absolute deviation of the bandwidth utilization of its membersPercent
M-Series Server Port Pool Bandwidth Utilization Percentage Txciscoucs.m_series.serverPortPool.bandwidthUtilizationPctTxCalculated as the average bandwidth utilization of its membersPercent
M-Series Server Port Pool Bandwidth Utilization Percentage Tx Balanceciscoucs.m_series.serverPortPool.bandwidthUtilizationPctTxBalanceCalculated as the median absolute deviation of the bandwidth utilization of its membersPercent
M-Series Server Port Pool throughput Rxciscoucs.m_series.serverPortPool.throughputRxAggregation of the throughput of all its membersBit
M-Series Server Port Pool throughput Txciscoucs.m_series.serverPortPool.throughputTxAggregation of the throughput of all its membersBit
M-Series Organization Propertiesciscoucs.m_series.organization.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Power Supply Unit Propertiesciscoucs.m_series.powerSupply.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Ethernet Port Carrier Senseciscoucs.m_series.ethernetPort.carrierSense.count-Count
M-Series Ethernet Port XMITciscoucs.m_series.ethernetPort.xmit.count-Count
M-Series Ethernet Port SQETestciscoucs.m_series.ethernetPort.SQETest.count-Count
M-Series Ethernet Port Giantsciscoucs.m_series.ethernetPort.giants.count-Count
M-Series Ethernet Port Alignciscoucs.m_series.ethernetPort.align.count-Count
M-Series Ethernet Port Deferred Txciscoucs.m_series.ethernetPort.deferredTx.count-Count
M-Series Ethernet Port Excess Collisionciscoucs.m_series.ethernetPort.excessCollision.count-Count
M-Series Ethernet Port Out Discardciscoucs.m_series.ethernetPort.outDiscard.count-Count
M-Series Ethernet Port Total Packets Txciscoucs.m_series.ethernetPort.totalPacketsTx.count-Count
M-Series Ethernet Port Late Collisionciscoucs.m_series.ethernetPort.lateCollision.count-Count
M-Series Total Bytes Rxciscoucs.m_series.ethernetPort.totalBytesRx.count-Byte
M-Series Ethernet Port Under Sizeciscoucs.m_series.ethernetPort.underSize.count-Count
M-Series Ethernet Port Multicast Packets Txciscoucs.m_series.ethernetPort.multicastPacketsTx.count-Count
M-Series Ethernet Port Broadcast Packets Rxciscoucs.m_series.ethernetPort.broadcastPacketsRx.count-Count
M-Series Ethernet Port Unicast Packets Txciscoucs.m_series.ethernetPort.unicastPacketsTx.count-Count
M-Series Ethernet Port Resetsciscoucs.m_series.ethernetPort.resets.count-Count
M-Series Ethernet Port Broadcast Packets Txciscoucs.m_series.ethernetPort.broadcastPacketsTx.count-Count
M-Series Ethernet Port Multicast Packets Rxciscoucs.m_series.ethernetPort.multicastPacketsRx.count-Count
M-Series Ethernet Port Int Max Txciscoucs.m_series.ethernetPort.intMacTx.count-Count
M-Series Ethernet Port Rcvciscoucs.m_series.ethernetPort.rcv.count-Count
M-Series Ethernet Port Jumbo Packets Txciscoucs.m_series.ethernetPort.jumboPacketsTx.count-Count
M-Series Ethernet Port Int Max Rxciscoucs.m_series.ethernetPort.intMacRx.count-Count
M-Series Ethernet Port Total Packets Rxciscoucs.m_series.ethernetPort.totalPacketsRx.count-Count
M-Series Ethernet Port Unicast Packets Rxciscoucs.m_series.ethernetPort.unicastPacketsRx.count-Count
M-Series Ethernet Port Total Bytes Txciscoucs.m_series.ethernetPort.totalBytesTx.count-Count
M-Series Ethernet Port Multi Collisionciscoucs.m_series.ethernetPort.multiCollision.count-Count
M-Series Ethernet Port Recv Pauseciscoucs.m_series.ethernetPort.recvPause.count-Count
M-Series Ethernet Port XMIT Pauseciscoucs.m_series.ethernetPort.xmitPause.count-Count
M-Series Ethernet Port Jumbo Packets Rxciscoucs.m_series.ethernetPort.jumboPacketsRx.count-Count
M-Series Ethernet Port Single Collisionciscoucs.m_series.ethernetPort.singleCollision.count-Count
M-Series Ethernet Port Symbolciscoucs.m_series.ethernetPort.symbol.count-Count
M-Series Ethernet Port FCSciscoucs.m_series.ethernetPort.fcs.count-Count
M-Series Ethernet Port throughput Rxciscoucs.m_series.ethernetPort.throughputRx.count-Bit
M-Series Ethernet Port throughput Txciscoucs.m_series.ethernetPort.throughputTx.count-Bit
M-Series Ethernet Port Bandwidth Headroom Rxciscoucs.m_series.ethernetPort.bandwidthHeadroomRxCalculated as the difference between the port's link speed and the current throughputBit
M-Series Ethernet Port Bandwidth Headroom Txciscoucs.m_series.ethernetPort.bandwidthHeadroomTxCalculated as the difference between the port's link speed and the current throughputBit
M-Series Ethernet Port Bandwidth Utilization Percentage Rxciscoucs.m_series.ethernetPort.bandwidthUtilizationPctRxCalculated as the throughput, divided by the link speed, and multiplied by 100Percent
M-Series Ethernet Port Bandwidth Utilization Percentage Txciscoucs.m_series.ethernetPort.bandwidthUtilizationPctTxCalculated as the throughput, divided by the link speed, and multiplied by 100Percent
M-Series CPU Input Currentciscoucs.m_series.cpu.inputCurrent-Ampere
M-Series CPU Temperatureciscoucs.m_series.cpu.temperature-Celsius
M-Series Switch Card Propertiesciscoucs.m_series.switchCard.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Service Profile Pause Packets Rxciscoucs.m_series.serviceProfile.pausePacketsRx.count-Count
M-Series Service Profile PPP Packets Rxciscoucs.m_series.serviceProfile.pppPacketsRx.count-Count
M-Series Service Profile Dropped Rxciscoucs.m_series.serviceProfile.droppedRx.count-Count
M-Series Service Profile Errors Rxciscoucs.m_series.serviceProfile.errorsRx.count-Count
M-Series Service Profile Per Priority Pause Packets Rxciscoucs.m_series.serviceProfile.perPriorityPausePacketsRx.count-Count
M-Series Service Profile Total Packets Txciscoucs.m_series.serviceProfile.totalPacketsTx.count-Count
M-Series Service Profile Dropped Txciscoucs.m_series.serviceProfile.droppedTx.count-Count
M-Series Service Profile Total Packets Rxciscoucs.m_series.serviceProfile.totalPacketsRx.count-Count
M-Series Service Profile Bytes Txciscoucs.m_series.serviceProfile.bytesTx.count-Byte
M-Series Service Profile Good Packets Rxciscoucs.m_series.serviceProfile.goodPacketsRx.count-Count
M-Series Service Profile VLAN Packets Rxciscoucs.m_series.serviceProfile.vlanPacketsRx.count-Count
M-Series Service Profile Per Priority Pause Packets Txciscoucs.m_series.serviceProfile.perPriorityPausePacketsTx.count-Count
M-Series Service Profile Bytes Rxciscoucs.m_series.serviceProfile.bytesRx.count-Byte
M-Series Service Profile Pause Packets Txciscoucs.m_series.serviceProfile.pausePacketsTx.count-Count
M-Series Service Profile PPP Packets Txciscoucs.m_series.serviceProfile.pppPacketsTx.count-Count
M-Series Service Profile Throughput Txciscoucs.m_series.serviceProfile.throughputTx.count-Bit
M-Series Service Profile Throughput Rxciscoucs.m_series.serviceProfile.throughputRx.count-Bit
M-Series Service Profile Good Packets Txciscoucs.m_series.serviceProfile.goodPacketsTx.count-Count
M-Series Service Profile Errors Txciscoucs.m_series.serviceProfile.errorsTx.count-Count
M-Series Service Profile VLAN Packets Txciscoucs.m_series.serviceProfile.vlanPacketsTx.count-Count
M-Series Ethernet Port Pool Bandwidth Headroom Rxciscoucs.m_series.ethPortPool.bandwidthHeadroomRxAggregation of the bandwidth headroom of all its membersBit
M-Series Ethernet Port Pool Bandwidth Headroom Rx Balanceciscoucs.m_series.ethPortPool.bandwidthHeadroomRxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its membersBit
M-Series Ethernet Port Pool Bandwidth Headroom Txciscoucs.m_series.ethPortPool.bandwidthHeadroomTxAggregation of the bandwidth headroom of all its membersBit
M-Series Ethernet Port Pool Bandwidth Headroom Tx Balanceciscoucs.m_series.ethPortPool.bandwidthHeadroomTxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its membersBit
M-Series Ethernet Port Pool Bandwidth Justified Headroom Rx Balanceciscoucs.m_series.ethPortPool.bandwidthJustifiedHeadroomRxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its members. The minimum operational speed of its members is the maximum value allowedBit
M-Series Ethernet Port Pool Bandwidth Justified Headroom Tx Balanceciscoucs.m_series.ethPortPool.bandwidthJustifiedHeadroomTxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its members. The minimum operational speed of its members is the maximum value allowedBit
M-Series Ethernet Port Pool Bandwidth Utilization Percentage Rxciscoucs.m_series.ethPortPool.bandwidthUtilizationPctRxCalculated as the average bandwidth utilization of its membersPercent
M-Series Ethernet Port Pool Bandwidth Utilization Percentage Rx Balanceciscoucs.m_series.ethPortPool.bandwidthUtilizationPctRxBalanceCalculated as the median absolute deviation of the bandwidth utilization of its membersPercent
M-Series Ethernet Port Pool Bandwidth Utilization Percentage Txciscoucs.m_series.ethPortPool.bandwidthUtilizationPctTxCalculated as the average bandwidth utilization of its membersPercent
M-Series Ethernet Port Pool Bandwidth Utilization Percentage Tx Balanceciscoucs.m_series.ethPortPool.bandwidthUtilizationPctTxBalanceCalculated as the median absolute deviation of the bandwidth utilization of its membersPercent
M-Series Ethernet Port Pool throughput Rxciscoucs.m_series.ethPortPool.throughputRxAggregation of the throughput of all its membersBit
M-Series Ethernet Port Pool throughput Txciscoucs.m_series.ethPortPool.throughputTxAggregation of the throughput of all its membersBit
M-Series Rack Server Propertiesciscoucs.m_series.rackServer.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Network Port Pool Bandwidth Headroom Rxciscoucs.m_series.networkPortPool.bandwidthHeadroomRxAggregation of the bandwidth headroom of all its membersBit
M-Series Network Port Pool Bandwidth Headroom Rx Balanceciscoucs.m_series.networkPortPool.bandwidthHeadroomRxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its membersBit
M-Series Network Port Pool Bandwidth Headroom Txciscoucs.m_series.networkPortPool.bandwidthHeadroomTxAggregation of the bandwidth headroom of all its membersBit
M-Series network Port Pool Bandwidth Headroom Tx Balanceciscoucs.m_series.networkPortPool.bandwidthHeadroomTxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its membersBit
M-Series Network Port Pool Bandwidth Justified Headroom Rx Balanceciscoucs.m_series.networkPortPool.bandwidthJustifiedHeadroomRxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its members. The minimum operational speed of its members is the maximum value allowedBit
M-Series Network Port Pool Bandwidth Justified Headroom Tx Balanceciscoucs.m_series.networkPortPool.bandwidthJustifiedHeadroomTxBalanceCalculated as the median absolute deviation of the bandwidth headroom of its members. The minimum operational speed of its members is the maximum value allowedBit
M-Series Network Port Pool Bandwidth Utilization Percentage Rxciscoucs.m_series.networkPortPool.bandwidthUtilizationPctRxCalculated as the average bandwidth utilization of its membersPercent
M-Series Network Port Pool Bandwidth Utilization Percentage Rx Balanceciscoucs.m_series.networkPortPool.bandwidthUtilizationPctRxBalanceCalculated as the median absolute deviation of the bandwidth utilization of its membersPercent
M-Series Network Port Pool Bandwidth Utilization Percentage Txciscoucs.m_series.networkPortPool.bandwidthUtilizationPctTxCalculated as the average bandwidth utilization of its membersPercent
M-Series Network Port Pool Bandwidth Utilization Percentage Tx Balanceciscoucs.m_series.networkPortPool.bandwidthUtilizationPctTxBalanceCalculated as the median absolute deviation of the bandwidth utilization of its membersPercent
M-Series Network Port Pool throughput Rxciscoucs.m_series.networkPortPool.throughputRxAggregation of the throughput of all its membersBit
M-Series Network Port Pool throughput Txciscoucs.m_series.networkPortPool.throughputTxAggregation of the throughput of all its membersBit
M-Series Host Ethernet Interface Bytes Txciscoucs.m_series.hostEthernetInterface.bytesTx.count-Byte
M-Series Host Ethernet Interface VLAN Packets Txciscoucs.m_series.hostEthernetInterface.vlanPacketsTx.count-Count
M-Series Host Ethernet Interface PPP Packets Rxciscoucs.m_series.hostEthernetInterface.pppPacketsRx.count-Count
M-Series Host Ethernet Interface VLAN Packets Rxciscoucs.m_series.hostEthernetInterface.vlanPacketsRx.count-Count
M-Series Host Ethernet Interface Dropped Txciscoucs.m_series.hostEthernetInterface.droppedTx.count-Count
M-Series Host Ethernet Interface Dropped Rxciscoucs.m_series.hostEthernetInterface.droppedRx.count-Count
M-Series Host Ethernet Interface Good Packets Txciscoucs.m_series.hostEthernetInterface.goodPacketsTx.count-Count
M-Series Host Ethernet Interface Pause Packets Rxciscoucs.m_series.hostEthernetInterface.pausePacketsRx.count-Count
M-Series Host Ethernet Interface Throughput Txciscoucs.m_series.hostEthernetInterface.throughputTx.count-Bit
M-Series Host Ethernet Interface Errors Txciscoucs.m_series.hostEthernetInterface.errorsTx.count-Count
M-Series Host Ethernet Interface Total Packets Txciscoucs.m_series.hostEthernetInterface.totalPacketsTx.count-Count
M-Series Host Ethernet Interface Errors Rxciscoucs.m_series.hostEthernetInterface.errorsRx.count-Count
M-Series Host Ethernet Interface Pause Packets Txciscoucs.m_series.hostEthernetInterface.pausePacketsTx.count-Count
M-Series Host Ethernet Interface Bytes Rxciscoucs.m_series.hostEthernetInterface.bytesRx.count-Byte
M-Series Host Ethernet Interface Throughput Rxciscoucs.m_series.hostEthernetInterface.throughputRx.count-Bit
M-Series Host Ethernet Interface PPP Packetsciscoucs.m_series.hostEthernetInterface.pppPacketsTx.count-Count
M-Series Host Ethernet Interface Good Packets Rxciscoucs.m_series.hostEthernetInterface.goodPacketsRx.count-Count
M-Series Host Ethernet Interface Total Packets Rxciscoucs.m_series.hostEthernetInterface.totalPacketsRx.count-Count
M-Series Host Ethernet Interface Per Prioerty Packets Txciscoucs.m_series.hostEthernetInterface.perPriorityPausePacketsTx.count-Count
M-Series Host Ethernet Interface Per Priority Packets Rxciscoucs.m_series.hostEthernetInterface.perPriorityPausePacketsRx.count-Count
M-Series Fabric Interconnect PSU Ctrlr Inlet 1ciscoucs.m_series.fabricInterconnect.psuCtrlrInlet1-Count
M-Series Fabric Interconnect Total Bytesciscoucs.m_series.fabricInterconnect.totalBytesRx_avg.count-Byte
M-Series Fabric Interconnect Single Collisionciscoucs.m_series.fabricInterconnect.singleCollision_avg.count-Count
M-Series Fabric Interconnect XMITciscoucs.m_series.fabricInterconnect.xmit_avg.count-Count
M-Series Fabric Interconnect Int Max Rxciscoucs.m_series.fabricInterconnect.intMacRx_avg.count-Count
M-Series Fabric Interconnect Broadcast Packets Txciscoucs.m_series.fabricInterconnect.broadcastPacketsTx_avg.count-Count
M-Series Fabric Interconnect Int Max Txciscoucs.m_series.fabricInterconnect.intMacTx_avg.count-Count
M-Series Fabric Interconnect Excess Collisionciscoucs.m_series.fabricInterconnect.excessCollision_avg.count-Count
M-Series Fabric Interconnect Multicast Packets Txciscoucs.m_series.fabricInterconnect.multicastPacketsTx_avg.count-Count
M-Series Fabric Interconnect Jumbo Packets Rxciscoucs.m_series.fabricInterconnect.jumboPacketsRx_avg.count-Count
M-Series Fabric Interconnect Fan Ctrlr Inlet 4ciscoucs.m_series.fabricInterconnect.fanCtrlrInlet4-Count
M-Series Fabric Interconnect Late Collisionciscoucs.m_series.fabricInterconnect.lateCollision_avg.count-Count
M-Series Fabric Interconnect Resetsciscoucs.m_series.fabricInterconnect.resets_avg.count-Count
M-Series Fabric Interconnect Out Discardciscoucs.m_series.fabricInterconnect.outDiscard_avg.count-Count
M-Series Fabric Interconnect Fan Ctrlr Inlet 1ciscoucs.m_series.fabricInterconnect.fanCtrlrInlet1-Count
M-Series Fabric Interconnect Total Packets Txciscoucs.m_series.fabricInterconnect.totalPacketsTx_avg.count-Count
M-Series Fabric Interconnect FCSciscoucs.m_series.fabricInterconnect.fcs_avg.count-Count
M-Series Fabric Interconnect Jumbo Packets Txciscoucs.m_series.fabricInterconnect.jumboPacketsTx_avg.count-Count
M-Series Fabric Interconnect Total Packets Rxciscoucs.m_series.fabricInterconnect.totalPacketsRx_avg.count-Count
M-Series Fabric Interconnect Carrier Senseciscoucs.m_series.fabricInterconnect.carrierSense_avg.count-Count
M-Series Fabric Interconnect Fan Ctrlr Inlet 3ciscoucs.m_series.fabricInterconnect.fanCtrlrInlet3-Count
M-Series Fabric Interconnect Memory Availableciscoucs.m_series.fabricInterconnect.memAvailable-Byte
M-Series Fabric Interconnect Multicast Packets Rxciscoucs.m_series.fabricInterconnect.multicastPacketsRx_avg.count-COunt
M-Series Fabric Interconnect Total Bytes Txciscoucs.m_series.fabricInterconnect.totalBytesTx_avg.count-Count
M-Series Fabric Interconnect Unicast Packets Rxciscoucs.m_series.fabricInterconnect.unicastPacketsRx_avg.count-Count
M-Series Fabric Interconnect PSU Ctrlr Inlet 2ciscoucs.m_series.fabricInterconnect.psuCtrlrInlet2-Count
M-Series Fabric Interconnect Giantsciscoucs.m_series.fabricInterconnect.giants_avg.count-Count
M-Series Fabric Interconnect Loadciscoucs.m_series.fabricInterconnect.load-Count
M-Series Fabric Interconnect Rcvciscoucs.m_series.fabricInterconnect.rcv_avg.count-Count
M-Series Fabric Interconnect SQETestciscoucs.m_series.fabricInterconnect.SQETest_avg.count-Count
M-Series Fabric Interconnect Fan Ctrlr Inlet 2ciscoucs.m_series.fabricInterconnect.fanCtrlrInlet2-Count
M-Series Fabric Interconnect Symbolciscoucs.m_series.fabricInterconnect.symbol_avg.count-Count
M-Series Fabric Interconnect Recv Pauseciscoucs.m_series.fabricInterconnect.recvPause_avg.count-Count
M-Series Fabric Interconnect Main Board Outlet 2ciscoucs.m_series.fabricInterconnect.mainBoardOutlet2-Count
M-Series Fabric Interconnect Multi Collisionciscoucs.m_series.fabricInterconnect.multiCollision_avg.count-Count
M-Series Fabric Interconnect Deferred Txciscoucs.m_series.fabricInterconnect.deferredTx_avg.count-Count
M-Series Fabric Interconnect Broadcast Packets Rxciscoucs.m_series.fabricInterconnect.broadcastPacketsRx_avg.count-Count
M-Series Fabric Interconnect Main Board Outlet 1ciscoucs.m_series.fabricInterconnect.mainBoardOutlet1-Count
M-Series Fabric Interconnect Alignciscoucs.m_series.fabricInterconnect.align_avg.count-Count
M-Series Fabric Interconnect Under Sizeciscoucs.m_series.fabricInterconnect.underSize_avg.count-Count
M-Series Fabric Interconnect Unicast Packets Txciscoucs.m_series.fabricInterconnect.unicastPacketsTx_avg.count-Count
M-Series Fabric Interconnect XMIT Pauseciscoucs.m_series.fabricInterconnect.xmitPause_avg.count-Count
M-Series Fabric Interconnect throughput Rxciscoucs.m_series.fabricInterconnect.throughputRx_avg.countAverage Rx throughput of its members.Bit
M-Series Fabric Interconnect throughput Txciscoucs.m_series.fabricInterconnect.throughputTx_avg.countAverage Tx throughput of its members.Bit
M-Series Fabric Interconnect Memory Cachedciscoucs.m_series.fabricInterconnect.memCached-Count
M-Series Local Disk Propertiesciscoucs.m_series.localDisk.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Fabric Ethernet LAN PC Symbolciscoucs.m_series.fabricEthernetLanPc.symbol.count-Count
M-Series Fabric Ethernet LAN PC Total Packets Txciscoucs.m_series.fabricEthernetLanPc.totalPacketsTx.count-Count
M-Series Fabric Ethernet LAN PC Total Bits Txciscoucs.m_series.fabricEthernetLanPc.totalBitsTx.count-Bit
M-Series Fabric Ethernet LAN PC Multi Collisionciscoucs.m_series.fabricEthernetLanPc.multiCollision.count-Count
M-Series Fabric Ethernet LAN PC Broadcast Packets Txciscoucs.m_series.fabricEthernetLanPc.broadcastPacketsTx.count-Count
M-Series Fabric Ethernet LAN PC Carrier Senseciscoucs.m_series.fabricEthernetLanPc.carrierSense.count-Count
M-Series Fabric Ethernet LAN PC Recv Pauseciscoucs.m_series.fabricEthernetLanPc.recvPause.count-Count
M-Series Fabric Ethernet LAN PC Single Collisionciscoucs.m_series.fabricEthernetLanPc.singleCollision.count-Count
M-Series Fabric Ethernet LAN PC Deferred Txciscoucs.m_series.fabricEthernetLanPc.deferredTx.count-Count
M-Series Fabric Ethernet LAN PC Out Discardciscoucs.m_series.fabricEthernetLanPc.outDiscard.count-Count
M-Series Fabric Ethernet LAN PC Total Bytes Rxciscoucs.m_series.fabricEthernetLanPc.totalBytesRx.count-Byte
M-Series Fabric Ethernet LAN PC Excess Collisionciscoucs.m_series.fabricEthernetLanPc.excessCollision.count-Count
M-Series Fabric Ethernet LAN PC Resetsciscoucs.m_series.fabricEthernetLanPc.resets.count-Count
M-Series Fabric Ethernet LAN PC Int Mac Rxciscoucs.m_series.fabricEthernetLanPc.intMacRx.count-Count
M-Series Fabric Ethernet LAN PC Multicast Packets Rxciscoucs.m_series.fabricEthernetLanPc.multicastPacketsRx.count-Count
M-Series Fabric Ethernet LAN PC Alignciscoucs.m_series.fabricEthernetLanPc.align.count-Count
M-Series Fabric Ethernet LAN PC XMIT Pauseciscoucs.m_series.fabricEthernetLanPc.xmitPause.count-Count
M-Series Fabric Ethernet LAN PC Jumbo Packets Txciscoucs.m_series.fabricEthernetLanPc.jumboPacketsTx.count-Count
M-Series Fabric Ethernet LAN PC Total Bits Rxciscoucs.m_series.fabricEthernetLanPc.totalBitsRx.count-Bit
M-Series Fabric Ethernet LAN PC Rcvciscoucs.m_series.fabricEthernetLanPc.rcv.count-Count
M-Series Fabric Ethernet LAN PC Broadcast Packets Rxciscoucs.m_series.fabricEthernetLanPc.broadcastPacketsRx.count-Count
M-Series Fabric Ethernet LAN PC Late Collisionciscoucs.m_series.fabricEthernetLanPc.lateCollision.count-Count
M-Series Fabric Ethernet LAN PC Under Sizeciscoucs.m_series.fabricEthernetLanPc.underSize.count-Count
M-Series Fabric Ethernet LAN PC Jumbo Packets Rxciscoucs.m_series.fabricEthernetLanPc.jumboPacketsRx.count-Count
M-Series Fabric Ethernet LAN PC Fcsciscoucs.m_series.fabricEthernetLanPc.fcs.count-Count
M-Series Fabric Ethernet LAN PC XMITciscoucs.m_series.fabricEthernetLanPc.xmit.count-Count
M-Series Fabric Ethernet LAN PC Giantsciscoucs.m_series.fabricEthernetLanPc.giants.count-Count
M-Series Fabric Ethernet LAN PC Multicast Packets Txciscoucs.m_series.fabricEthernetLanPc.multicastPacketsTx.count-Count
M-Series Fabric Ethernet LAN PC SQETestciscoucs.m_series.fabricEthernetLanPc.SQETest.count-Count
M-Series Fabric Ethernet LAN PC Total Packets Rxciscoucs.m_series.fabricEthernetLanPc.totalPacketsRx.count-Count
M-Series Fabric Ethernet LAN PC Unicast Packets Txciscoucs.m_series.fabricEthernetLanPc.unicastPacketsTx.count-Count
M-Series Fabric Ethernet LAN PC Int Mac Txciscoucs.m_series.fabricEthernetLanPc.intMacTx.count-Count
M-Series Fabric Ethernet LAN PC Unicast Packets Rxciscoucs.m_series.fabricEthernetLanPc.unicastPacketsRx.count-Count
M-Series Fabric Ethernet LAN PC Total Bytes Txciscoucs.m_series.fabricEthernetLanPc.totalBytesTx.count-Count
M-Series Storage Controller Propertiesciscoucs.m_series.storageController.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
M-Series Fan Module Propertiesciscoucs.m_series.fanModule.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
Full version history
ReleaseDate
✨New in this version:
  • Initial release including Cisco UCS M-series overview dashboards, analysis screens and custom topology types.
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
