Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cisco UCS C-SeriesCisco UCS C-Series
Cisco UCS C-Series
Cisco UCS C-Series
Get insights into your Cisco UCS C-Series devices
Extension
Free trialDocumentation
Cisco UCS C-Series Overview DashboardCisco UCS C-Series Overview Dashboard Pt. 2Cisco UCS C-Series Local Disk View in I&O app
  • Product information
  • Release notes
Overview
Monitor your Cisco UCS C-Series devices with data collected through the UCS Manager XML API.
This extension collects infrastructure metrics and events for Cisco UCS C-Series hardware components, including CPU, fan modules, fans, memory, storage, power supplies, network adapters, and VIC interfaces.
Use cases
  • Monitor hardware health/state signals for CPUs, fan modules/fans, memory arrays/units, storage controllers, local disks, RAID batteries, power supplies, and virtual drives.
  • Observe connectivity and status for adapters, external interfaces, vHBAs, and vNICs.
  • Detect UCS faults and raise Dynatrace error events for faster issue triage.
Get started
Activate the extension in your environment from Dynatrace Hub, configure connection details for your UCS endpoint, and select the feature sets you want to collect.
For more information on the installation and configuration, please see Cisco UCS C-Series extension in the Dynatrace Documentation.
Details
The extension package contains:
  • Overview dashboards (Classic & Platform)
  • Analysis screens integrated with the Infrastructure & Operations app
  • Unified analysis pages
  • Custom topology types extracted from metric dimensions:
    • Cisco UCS C-Series CPU
    • Cisco UCS C-Series External Interface
    • Cisco UCS C-Series Fan Module
    • Cisco UCS C-Series Local Disk
    • Cisco UCS C-Series Memory Array
    • Cisco UCS C-Series Memory Unit
    • Cisco UCS C-Series Network Adapter
    • Cisco UCS C-Series Power Supply
    • Cisco UCS C-Series Raid Battery
    • Cisco UCS C-Series Storage Controller
    • Cisco UCS C-Series VIC Adapter
    • Cisco UCS C-Series VIC External Interface
    • Cisco UCS C-Series VIC vHBA
    • Cisco UCS C-Series VIC vNIC
    • Cisco UCS C-Series Virtual Drive
    • Cisco UCS C-Series Rack
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
C-Series CPU Presenceciscoucs.c_series.cpu.presence-Count
C-Series CPU Operational Stateciscoucs.c_series.cpu.operState-Count
C-Series Power Supply Unit Voltageciscoucs.c_series.powerSupply.voltage-Count
C-Series Memory Array Current Capacityciscoucs.c_series.memoryArray.currCapacity-Count
C-Series Memory Array Max Devicesciscoucs.c_series.memoryArray.maxDevices-Count
C-Series Memory Array Populatedciscoucs.c_series.memoryArray.populated-Count
C-Series Memory Array Presenceciscoucs.c_series.memoryArray.presence-Count
C-Series Fan Voltageciscoucs.c_series.fan.voltage-Count
C-Series VIC External Interface Link Stateciscoucs.c_series.vicExternalInterface.linkState-Count
C-Series Fan Module Voltageciscoucs.c_series.fanModule.voltage-Count
C-Series Fan Module Presenceciscoucs.c_series.fanModule.presence-Count
C-Series Fan Module Powerciscoucs.c_series.fanModule.power-Count
C-Series Fan Module Thermalciscoucs.c_series.fanModule.thermal-Count
C-Series Fan Module Operabilityciscoucs.c_series.fanModule.operability-Count
C-Series Power Supply Unit Presenceciscoucs.c_series.powerSupply.presence-Count
C-Series Power Supply Operabilityciscoucs.c_series.powerSupply.operability-Count
C-Series Power Supply Unit Powerciscoucs.c_series.powerSupply.power-Count
C-Series Power Supply Unit Thermalciscoucs.c_series.powerSupply.thermal-Count
C-Series Fan Powerciscoucs.c_series.fan.power-Count
C-Series Fan Thermalciscoucs.c_series.fan.thermal-Count
C-Series Fan Presenceciscoucs.c_series.fan.presence-Count
C-Series Fan Operabilityciscoucs.c_series.fan.operability-Count
C-Series VIC Adapter Presenceciscoucs.c_series.vicAdapter.presence-Count
C-Series Storage Controller Presenceciscoucs.c_series.storageController.presence-Count
C-Series Faultsciscoucs.c_series.faultsThis metric is just a placeholder and does not exist.Count
C-Series Raid Battery Voltageciscoucs.c_series.raidBattery.voltage-Volt
C-Series Raid Battery Temperatureciscoucs.c_series.raidBattery.temperature-Celsius
C-Series Raid Battery Currentciscoucs.c_series.raidBattery.current-Ampere
C-Series Raid Battery Design Voltageciscoucs.c_series.raidBattery.designVoltage-Volt
C-Series VIC vNICciscoucs.c_series.vicvNIC.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
C-Series Memory Unit Operabilityciscoucs.c_series.memoryUnit.operability-Count
C-Series Memory Unit Presenceciscoucs.c_series.memoryUnit.presence-Count
C-Series Local Disk Predictive Failure Countciscoucs.c_series.localDisk.predictiveFailureCount-Count
C-Series Network Adapter Propertiesciscoucs.c_series.networkAdapter.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
C-Series Virtual Drive Stateciscoucs.c_series.virtualDrive.driveState-Count
C-Series Virtual Drive Healthciscoucs.c_series.virtualDrive.health-Count
C-Series Local Diskciscoucs.c_series.localDisk.coercedSize-Byte
C-Series Local Disk Drive Stateciscoucs.c_series.localDisk.driveState-Count
C-Series Local Disk Link Speedciscoucs.c_series.localDisk.linkSpeed-Bit
C-Series Local Disk Onlineciscoucs.c_series.localDisk.online-Count
C-Series External Interface Propertiesciscoucs.c_series.externalInterface.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
C-Series VIC vHBA Propertiesciscoucs.c_series.vicvHBA.propertiesThis metric is used only to push properties as dimensions and has a constant value of 1.Count
Full version history
ReleaseDate
✨New in this version:
  • Initial release including Cisco UCS C-series overview dashboards, analysis screens and custom topology types.
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
