Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Ceph storageCeph storage
Ceph storage
Ceph storage
Monitor usage of Ceph storage system at both client side and host level.
Extension
Free trialDocumentation
DashboardUA Screen
  • Product information
  • Release notes
Overview
This is intended for users, who:
  • Would like to monitor usage and performance of their Ceph platform.
  • Require constant ability to have live information about host resources and data flow.
  • Aim to shorten analysis time, required to find out root cause of possible system failures, to the minimum.
Use cases
This enables you to:
  • Monitor host resources usage and its capacity levels.
  • Collect data regarding active and inactive Ceph object storage daemons.
  • Observe system data flow in terms of write/read operations, for the cluster as a whole, and for the osd's in particular.
Get started
For more information on the installation and configuration, please see Ceph storage extension in the Dynatrace Documentation.
Details
Compatibility information
Environment with Ceph storage deployed
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Total Capacityceph_cluster_total_bytesTotal cluster capacity in bytesByte
Used Capacityceph_cluster_total_used_bytesUsed cluster capacity in bytesByte
Monitor Metadataceph_mon_metadataPlaceholder metric to get monitor metadata dimensions from exporterCount
OSD Metadataceph_osd_metadataPlaceholder metric to get OSD metadata dimensions from exporterCount
PG Activeceph_pg_activePlacement group active per poolCount
PG Downceph_pg_downPlacement group down per poolCount
PG Cleanceph_pg_cleanPlacement group clean per poolCount
PG Backfill Too Fullceph_pg_backfill_toofullPlacement group backfill_toofull per poolCount
PG Degradedceph_pg_degradedPlacement group degraded per poolCount
PG Failed Repairceph_pg_failed_repairPlacement group failed repair per poolCount
PG Incompleteceph_pg_incompletePlacement group incomplete per poolCount
PG Staleceph_pg_stalePlacement group stale per poolCount
PG Inconsistentceph_pg_inconsistentPlacement group inconsistent per poolCount
OSDs INceph_osd_inStorage daemons in the clusterCount
OSDs UPceph_osd_upStorage daemons runningCount
Placement groupsceph_osd_numpgPlacement groupsCount
Health Statusceph_health_statusHealth status of the ClusterUnspecified
Slow OPsceph_healthcheck_slow_opsOSD or Monitor requests taking a long time to processUnspecified
OSD Apply Latencyceph_osd_apply_latency_msLatency of the "commit" operation on the OSDMilliSecond
OSD Commit Latencyceph_osd_commit_latency_msLatency of the "commit" operation on the OSDMilliSecond
Total OSD Write Latencyceph_osd_op_w_latency_sumTotal latency of the "write" operations on the OSDMilliSecond
Total OSD Read Latencyceph_osd_op_r_latency_sumTotal latency of the "read" operations on the OSDMilliSecond
Bytes Writtenceph_osd_op_w_in_bytesTotal sum of bytes written to OSDByte
Bytes Readceph_osd_op_r_out_bytesTotal sum of bytes read from OSDByte
Write Operationsceph_osd_op_wTotal sum of write operations performed on OSDCount
Read Operationsceph_osd_op_rTotal sum of read operation performed on OSDCount
Recovery Operationsceph_osd_recovery_opsNumber of recovery operations in OSDCount
Objects Countceph_pool_objectsNumber of objects in poolCount
Objects Recoveredceph_pool_num_objects_recoveredNumber of recovered objects in poolCount
Bytes Recoveredceph_pool_num_bytes_recoveredNumber of recovered bytes in poolByte
Pool Objects Quotaceph_pool_quota_objectsObject quota set for poolCount
Pool Bytes Quotaceph_pool_quota_bytesByte quota set for poolCount
Open Sessionsceph_mon_num_sessionsNumber of open monitor sessionsCount
Quorumceph_mon_quorum_statusMonitor daemons in quorumCount
Full version history
ReleaseDate
āš ļø IMPORTANT: This version requires a minimum Dynatrace and EEC version of 1.318
✨ New in this version:
  • Added platform dashboard
  • Added platform screen definitions
  • Added security context attribute to entities
  • Added new health feature set with 2 metrics
    • ceph_health_status
    • ceph_healthcheck_slow_ops
Added additional placement group metrics
Fixed ceph-cluster:cluster entity rules to work with local monitoring configurations.
No release notes
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
