Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Azure Managed Apache CassandraAzure Managed Apache Cassandra
Gain insights into your Azure Managed Cassandra Instance health and performance
Extension
Free trialDocumentation
  • Product information
  • Release notes
Overview
Prometheus is an open-source monitoring toolkit for collecting and alerting on infrastructure and platform metrics. These metrics are exposed by Prometheus in OpenMetrics format. Prometheus exporters provide a standardized monitoring interface for numerous technologies and services. By adding Dynatrace support to metrics collected from Prometheus exporters, you get intelligent observability and automatic root cause analysis for technologies such as Apache Cassandra, Redis, and Kafka. As well 100+ integrations maintained by the Prometheus community.
This is intended for users who want to:
  • Leverage Apache Cassandra Prometheus metrics to extend Dynatrace’s monitoring capabilities.
This enables you to:
  • Monitor you Azure Managed Instance for Apache Cassandra Cluster
  • Visualize Infrastructure (Cluster, Data Center, Rack, Node) and Data (Keyspace & Table) Metrics.
  • Proactively alert on anomalies of Prometheus metrics with Davis AI.
Compatibility Requirements:
  • ActiveGate version 1.231+
Get started
For more information on the installation and configuration, please see Azure Managed Apache Cassandra extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Storage Loadmcac_storage_load_totalSize, in bytes, of the on disk data size this node manages.Byte
Storage Exceptionsmcac_storage_exceptions_total.countNumber of internal exceptions caught. Under normal exceptions this should be zero.Count
Commit Log Pending Tasksmcac_commit_log_pending_tasksNumber of commit log messages written but yet to be fsync’d.Count
Commit Log Completed Tasks Totalmcac_commit_log_total_commit_log_size.countTotal number of commit log messages written since [re]start.Count
Buffer Pool Sizemcac_buffer_pool_sizeSize, in bytes, of the managed buffer poolByte
Buffer Pool Misses Totalmcac_buffer_pool_misses_total.countThe number of misses in the pool. The higher this is the more allocations incurred.Count
Client Connected Native Clientsmcac_client_connected_native_clientsNumber of clients connected to this nodes native protocol server.Count
Client Auth Failure Totalmcac_client_auth_failure_total.countNumber of clients who experience authentication failures.Count
Client Auth Success Totalmcac_client_auth_success_total.countNumber of clients who successfully authenticate.Count
Storage Total Hints Totalmcac_storage_total_hints_total.countNumber of hint messages written to this node since [re]start. Includes one entry for each host to be hinted per hint.Count
CQL Prepared Statements Executed Totalmcac_cql_prepared_statements_executed_total.countNumber of prepared statements executed.Count
CQL Regular Statements Executed Totalmcac_cql_regular_statements_executed_total.countNumber of non prepared statements executed.Count
Dropped Messages Totalmcac_dropped_message_dropped_total.countNumber of dropped messages.Count
JVM GC Countmcac_jvm_gc_count.countTotal number of collections that have occurredCount
JVM GC Timemcac_jvm_gc_time.countApproximate accumulated collection elapsed time in milliseconds.MilliSecond
JVM Memory Usedmcac_jvm_memory_usedAmount of used memory in bytesByte
JVM Usage (raw)mcac_jvm_memory_usage_rawRatio of used to maximum memoryCount
Thread Pools Active Tasksmcac_thread_pools_active_tasksNumber of tasks being actively worked on by this pool.Count
Thread Pools Total Blocked Tasks Totalmcac_thread_pools_total_blocked_tasks_total.countNumber of tasks that were blocked due to queue saturation.Count
Thread Pools Completed Tasksmcac_thread_pools_completed_tasksNumber of tasks completed.Count
Client Request Latencymcac_client_request_latency-MicroSecond
Client Request Failures Totalmcac_client_request_failures_total.countNumber of transaction failures encountered.Count
Client Request Unavailables Totalmcac_client_request_unavailables_total.countNumber of unavailable exceptions encountered.MilliSecond
Cache Hit Rate (raw)mcac_cache_hit_rate_raw-Count
Cache Capacitymcac_cache_capacityCache capacity in bytes.Count
Cache Misses Totalmcac_cache_misses_total.countTotal number of cache misses.Count
Cache Sizemcac_cache_sizeTotal size of occupied cache, in bytes.Byte
Table Range Latencymcac_table_range_latency-MicroSecond
Table Read Latencymcac_table_read_latency-MicroSecond
Table Write Latencymcac_table_write_latency-MicroSecond
Table Bloom Filter Disk Space Usedmcac_table_bloom_filter_disk_space_usedDisk space used by bloom filter (in bytes).Byte
Table Bloom Filter False Positivesmcac_table_bloom_filter_false_positivesNumber of false positives on table’s bloom filter.Count
Table Bloom Filter False Ratiomcac_table_bloom_filter_false_ratio_raw-Count
Table Bytes Flushed Totalmcac_table_bytes_flushed_total.countTotal number of bytes flushed since server [re]start.Count
Table Compaction Bytes Written Totalmcac_table_compaction_bytes_written_total.countTotal number of bytes compacted since server [re]start.Count
Table Compression Ratiomcac_table_compression_ratio_raw-Count
Table Dropped Mutations Totalmcac_table_dropped_mutations_total.countNumber of dropped mutations on this table.Count
Table Estimated Partition Countmcac_table_estimated_partition_count.gaugeApproximate number of keys in table.Count
Table Key Cache Hit Ratemcac_table_key_cache_hit_rate_raw-Count
Table Live Disk Space Used Totalmcac_table_live_disk_space_used_totalDisk space used by SSTables belonging to this table (in bytes).Byte
Table Live SSTable Countmcac_table_live_ss_table_count.gaugeNumber of SSTables on disk for this table.Count
Table Memtable Columns Countmcac_table_memtable_columns_count.gaugeTotal number of columns present in the memtable.Count
Table Memtable Live Data Sizemcac_table_memtable_live_data_sizeTotal amount of live data stored in the memtable, excluding any data structure overhead.Byte
Table Memtable Switch Count Totalmcac_table_memtable_switch_count_total.countNumber of times flush has resulted in the memtable being switched out.Count
Table Pending Compactionsmcac_table_pending_compactionsEstimate of number of pending compactions for this table.Count
Table Pending Flushes Totalmcac_table_pending_flushes_total.countEstimate of number of pending flushes for this table.Count
Table Row Cache Hit Totalmcac_table_row_cache_hit_total.countNumber of table row cache hits.Count
Table Row Cache Miss Totalmcac_table_row_cache_miss_total.countNumber of table row cache misses.Count
Table Total Disk Space Used Totalmcac_table_total_disk_space_used_totalTotal disk space used by SSTables belonging to this table, including obsolete ones waiting to be GC’d.Byte
Client Request Latency Totalmcac_client_request_latency_total.countLatency of Client Requests.MilliSecond
Keyspace All Memtables Live Data Sizemcac_keyspace_all_memtables_live_data_sizeTotal amount of live data stored in the memtables (2i and pending flush memtables included) that resides off-heap, excluding any data structure overhead.Byte
Keyspace Bloom Filter Disk Space Usedmcac_keyspace_bloom_filter_disk_space_usedDisk space used by bloom filter (in bytes).Byte
Keyspace Live Disk Space Usedmcac_keyspace_live_disk_space_usedDisk space used by SSTables belonging to this table (in bytes).Byte
Keyspace Memtable Columns Countmcac_keyspace_memtable_columns_count.gaugeTotal number of columns present in the memtable.Count
Keyspace Memtable Live Data Sizemcac_keyspace_memtable_live_data_sizeTotal amount of live data stored in the memtable, excluding any data structure overhead.Byte
Keyspace Memtable Switch Countmcac_keyspace_memtable_switch_count.gaugeNumber of times flush has resulted in the memtable being switched out.Count
Keyspace Pending Compactionmcac_keyspace_pending_compactionsEstimated number of compactions remaining to perform.Count
Keyspace Pending Flushesmcac_keyspace_pending_flushesEstimated number of flush tasks pending for this table.Count
Keyspace Total Disk Space Usedmcac_keyspace_total_disk_space_usedTotal disk space used by SSTables belonging to this table, including obsolete ones waiting to be GC’d.Byte
Keyspace Read Latencymcac_keyspace_read_latency-MicroSecond
Keyspace Write Latencymcac_keyspace_write_latency-MicroSecond
Keyspace Read Total Latency Totalmcac_keyspace_read_total_latency_total.countRead latencyMilliSecond
Keyspace Write Total Latency Totalmcac_keyspace_write_total_latency_total.countWrite LatencyMilliSecond
Table Read Total Latency Totalmcac_table_read_total_latency_total.countRead Latency for this table.MilliSecond
Table Write Total Latency Totalmcac_table_write_total_latency_total.countWrite Latency for this table.MilliSecond
Full version history
ReleaseDate
1.5.1
What's New:
  • Added keyword key value pairs to extension
1.5.0
  • Add new metrics
    • mcac_client_request_latency
    • mcac_table_range_latency
    • mcac_table_read_latency
    • mcac_table_write_latency
    • mcac_keyspace_read_latency
    • mcac_keyspace_write_latency
    • Move old metrics to new Feature Sets
      • Client Requests (total)
        • mcac_client_request_latency_total.count
      • Keyspace Latency (total)
        • mcac_keyspace_read_total_latency_total.count
        • mcac_keyspace_write_total_latency_total.count
      • Table Latency (total)
        • mcac_table_read_total_latency_total.count
        • mcac_table_write_total_latency_total.count
  • Add Cluster & Job Filter Variables
  • DXS-3317
    • Add Platform Screens
    • Add Platform Dashboard
    • Add dt.security_context attribute to entities
v1.2.1
  • Update Extension Signature
v1.2.0
  • Initial Version to collect Prometheus metrics from Azure's Managed Instance for Apache Cassandra
  • See Documentation link for set up information
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
