Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
AWS ConnectorAWS Connector
AWS Connector
AWS Connector
Automate your AWS infrastructure with actions across EC2, S3, Lambda, and more.
App
Free trialDocumentation
Example workflow to store Dynatrace BizEvents in S3 buckets.Example workflow to optimize cloud costs in AWS. Tags mark specific instances that are marked for termination.Excerpt of AWS actions, which allows you to manage tags, adjust Auto Scaling Groups based on Dynatrace insights and predictive analytics, ingest logs to S3, and more.
  • Product information
  • Release notes
Overview
Combine the strength of Dynatrace, AIOPS and predictive analytics with your AWS infrastructure:
  • Leverage Dynatrace Workflows to react to insights gathered by AI-based full stack AWS monitoring on resources such as Amazon EC2, AWS Lambda, and Kubernetes
  • Seamlessly and securely authenticate with OpenID Connect (OIDC) based authentication
  • Query and manipulate AWS resources, such as EC2 instances, S3 buckets, or Auto Scaling Groups, to optimize cloud costs by adjusting scaling in combination with Dynatrace predictive analytics, ingesting events and logs to S3, isolating instances in case of an attack, and more.
Use cases
With a broad set of AWS workflow actions, you can enable use cases like:
  • React to problems or outages and adjust availability zones
  • Optimize your cloud costs by leveraging Dynatrace predictive analytics to adjust the correct sizing of your AWS infrastructure
  • Isolate machines in case of identified vulnerabilities or attacks
  • Take snapshots of environments for forensic analysis
Get started
Install AWS, then follow the instructions detailed in Dynatrace Documentation.
Before you start, make sure that AWS is installed, outbound connections are configured, the connection to AWS is authorized, and the OIDC-based authentication is configured as outlined in the documentation.
Details
A broad set of AWS workflow actions across AWS services allows you to:
  • EC2: Create or delete tags, describe tags, availability zones, hosts, instances, security groups, start, run, stop, terminate instances, and more
  • EC2 Auto Scaling: Attach instances, describe Auto Scaling Groups and instances, detach instances, execute policy, set desired capacity, and more
  • Lambda: Invoke a Lambda function list or update the configuration
  • S3: Create or delete buckets, get bucket logging and list objects, list buckets, move and put objects, rename objects, and more
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to AWS Connector
Workflows logo
Workflows
Full version history
ReleaseDate
  • Required FunctionName Field – The lambda-invoke action now requires the FunctionName input instead of treating it as optional.
  • New Consumer Selection for Connection Management - When creating connections in the Connection Overview, users can now specify the consuming application: Workflows (existing option) or OpenPipeline.
  • Updated Connection Overview - The overview now includes a Consumer App column, indicating whether each connection belongs to Workflows or OpenPipeline.
  • Consumer-Based Filtering - A new filter option above the connection overview allows to view connections by consumer.
  • Setup Status Column Added - Introduced a new Setup column in the settings overview to show which parts of each connection’s setup are complete.
  • App Renamed to AWS Connector - The App has been renamed from "AWS" to "AWS Connector" to align with the Connectors concept.
  • Enhanced Connection Management with Access Control - We've introduced a new, enhanced schema for AWS Connections that includes fine-grained access control and sharing options.
  • Important Deprecation of Existing Connection Schema - With the launch of the new schema, the existing AWS connection schema will be set to read-only and will be fully deprecated by the end of March 2026. Customers must migrate to the new connection schema for any future modifications. The existing connections will continue to function for the next six months.
  • Flexible Body Input in S3 Put Object Action - The S3 Put Object action now accepts JavaScript objects as input for the Body field, allowing for more dynamic data handling.
  • Bugfix - Fixed an issue with the app crashing when using an invalid connection.
  • Enhanced Pagination Support - Added NextToken and MaxResults input fields to improve pagination capabilities across multiple actions. This allows for more efficient handling of large datasets and better control over result sets. The updated actions include:
    • Auto Scaling: Describe Auto Scaling Groups
    • Auto Scaling: Describe Auto Scaling Instances
    • Auto Scaling: Describe Instance Refreshes
    • Auto Scaling: Describe Scaling Activities
    • EC2: Describe Instances
    • EC2: Describe Hosts
    • EC2: Describe Security Groups
    • EC2: Describe Tags
    • S3: Get Object Attributes
    • S3: List Buckets
    • SSM: List Documents
    • SSM: Describe Automation Executions
    • SSM: List Commands
  • New SSM Command Actions - Added actions to send SSM commands and retrieve the list of executed commands.
  • Grouped input fields - Improved the user experience by grouping related input fields, making navigation and usage easier.
  • Permission Error Display - Accurately display permission errors when creating a connection within a workflow action, ensuring users are promptly informed of any access issues.
  • New IAM Role Policy Actions - Introduced several new actions to manage IAM role policies and tags.
  • New EC2 EBS Volume Management - Introduced actions to create, attach, and detach Amazon EC2 EBS volumes, providing enhanced control over your storage resources.
  • Bugfix in List Documents action - Resolved an issue where list-documents action would not apply filters correctly.
  • Bugfix in Start Automation Execution action - Fixed the target input format to ensure proper functionality.
  • First Major Version Now Available - Enhanced inputs for actions unlock new possibilities for customization and flexibility in your workflows.
  • App renamed to "AWS" - Streamlined the app name by removing the "Preview" suffix.
  • Expanded AWS Systems Manager Support - New actions introduced to start, stop, and describe automation execution actions.
  • New EC2 Snapshot Management Capabilities - Added support for creating snapshots and modifying snapshot attributes.
  • EC2 Instance Attribute Modification - Enabled the ability to modify EC2 instance attributes, offering greater flexibility for instance management.
  • New Action for Updating Auto Scaling Group - Auto Scaling groups can be updated now with ease using the new Update Auto Scaling Group action.
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
