Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Amazon ECRAmazon ECR
Amazon ECR
Amazon ECR
Ingest Amazon Elastic Container Registry vulnerability findings and scan events.
App
Free trialDocumentation
Sample dashboard with a summary of vulnerability findings across various accounts and regions.Sample dashboard with details of top vulnerabilities and vulnerable packages.Sample dashboard for the security coverage use case.Sample workflow for an automated Jira ticket creation for critical vulnerability findings.Sample workflow for automated Slack notifications for critical vulnerability findings.
  • Product information
  • Release notes
Overview
Dynatrace integrates with Amazon ECR to enable visibility, orchestration, and prioritization of cross-container registry vulnerability findings.
  • Single pane of glass: Ingest vulnerability findings from Amazon ECR into Dynatrace (powered by OpenPipelineā„¢).
  • Unified analysis: Dynatrace transforms and maps the findings to a unified format for vulnerability findings (powered by Dynatrace Semantic Dictionary).
  • Findings operationalization: Prioritize, visualize, and automate vulnerability findings with runtime context.
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC).
Use cases
  • Overview: Visualize and report your current security posture and trends around vulnerability findings across container registries with Dashboards.
  • Prioritization: Analyze and prioritize vulnerability findings across multiple tools and products uniformly with Notebooks.
  • Automation: Automate the orchestration of the critical vulnerability findings by creating notifications and tickets using Workflows.
  • Investigation: Use vulnerability findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
You can ingest Amazon ECR vulnerability findings and scan events (basic or enhanced scanning) into Dynatrace via AWS EventBridge using the CloudFormation template provided by Dynatrace. For instructions, go to Ingest Amazon ECR vulnerability findings and scan events.
Details
This integration app delivers several sample dashboards and workflows to help you
  • Visualize container vulnerability findings (dashboard)
  • Discover container scanning gaps (dashboard)
  • Automatically create Slack notifications for critical findings (workflow)
  • Automatically create Jira tickets for critical findings (workflow)
Compatibility information
  • Amazon ECR (basic scanning) EventBridge events format - completed image scan events and the corresponding security findings.
  • Amazon ECR (enhanced scanning) EventBridge events format - individual findings and scan events reported by AWS Inspector.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Amazon ECR
Workflows logo
Workflows
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Full version history
ReleaseDate
2.2.3
Patch Changes
  • Updated dependencies
2.2.2
Patch Changes
  • Update connection filter's label
2.2.1
Patch Changes
  • Connection filter now only filters for the connection's name
2.2.0
Minor Changes
  • Updated footer to provide an option for giving feedback
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.0
Minor Changes
2.1.0
Minor Changes
  • Modified CloudFormation template to include the ID of the scan event in Vulnerability Finding events. This is essential to connect Vulnerability Finding and Vulnerability Scan events detected by ECR basic scan
  • Modified CloudFormation template to generate scan ID for ECR Enhanced Vulnerability Finding events
Patch Changes
  • Update dependencies
  • Update Dashboards
2.0.0
Major Changes
  • Migrate app to fetching from new security.events table
Patch Changes
  • Remove "type" query parameter in url
1.1.3
Patch Changes
  • Fix CF delete-stack command
  • Update dependency
  • UI improvements
1.1.1
Patch Changes
  • Updated the Slack workflow to use version 3.0.0 at least
1.1.0
Minor Changes
  • Migrate app to headless
Patch Changes
  • Update dynatrace AWS event forwarder templates
  • Updated Container Vulnerability Findings Overview dashboard, all widgets use the filters.
  • Update workflows
  • Fixed a bug, where after invalidating a token the 'Invalidate token'-button wouldn't be enabled for any other connection.
  • Adjust texts in UI components
1.1.1
Patch Changes
  • Updated the Slack workflow dependency, now it requires Slack app with version >3.0.0
1.1.0
Minor Changes
Patch Changes
  • Update workflows
1.1.0
Minor Changes
  • Connection configuration and monitoring are now part of the Settings.
  • Small updates to the ready-made documents.
1.0.5
Patch Changes
  • Removing provider_product parameter from OpenPipeline Endpoint URL
  • Improved accuracy of the last event received value in the connection table
1.0.4
Patch Changes
  • Fix compatibility issues
1.0.3
Patch Changes
  • Adjust texts
1.0.2
Patch Changes
  • Updated sample dashboards, fixed filtering for Tag variable
  • Adjust CloudFormation template for multi-region deployment
  • Fix Platform URL for OpenPipeline endpoint
1.0.1
Patch Changes
  • Create unique secret-name for AWS CLI command
  • Improve texts
  • Adjust width of tooltip for Dynatrace OpenPipeline endpoint
1.0.0 - Initial Release
  • Step-by-step user onboarding with CLI commands and CloudFormation template for download.
  • Ready-made documents with sample dashboards and workflows.
1.0.4
Patch Changes
1.0.3
Patch Changes
  • Adjust texts
1.0.2
Patch Changes
1.0.1
Patch Changes
  • Improve texts
1.0.3
Patch Changes
  • Adjust texts
1.0.2
Patch Changes
1.0.1
Patch Changes
  • Improve texts
1.0.2
Patch Changes
1.0.1
Patch Changes
  • Improve texts
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
