Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Nagios IntegrationNagios Integration
Nagios Integration
Nagios Integration
Eliminate event storms, using Nagios hosts data and problems in Dynatrace
Technology by Alanata
Documentation
  • Product information
Overview
Consolidate and integrate your monitoring tools. Alanata's Nagios integration enables you to connect existing Nagios monitoring with Dynatrace. Enrich Dynatrace topology model with Nagios hosts, ingest Nagios problems, and let Davis AI engine process the problems together with native Dynatrace events in an integrated AIOps solution. With this extension, you can use Dynatrace as a unifying platform for data from external monitoring solutions, eliminate event storms and minimize the time spent investigating.
Details
Key Features
  • Synchronization
    • Hosts information to Dynatrace entity, including Nagios host IP and monitoring configuration.
    • Status for monitored hosts and services in the form of Dynatrace events. Filter for Nagios object status to synchronize:
      • Status is not OK
      • State type is HARD
      • Active check or Passive check is enabled
      • Notification is enabled for Nagios Host or Service
      • Host and Service are not in scheduled downtime
    • Nagios metric data for monitored services
  • Filtering
    • Filtering on Nagios host groups
    • Filtering on Nagios service names via regular expressions list or substring
    • Filtering on metrics (Nagios service names) via regular expressions list or substring
  • Context information
    • Dynatrace entity or event contains a contextual URL link to Nagios host or service
  • Problem metric
    • Metric showing the problem count for each device
  • Nagios technology screens
    • Groups all custom topology entities from Nagios created by the Nagios ActiveGate extension
  • Dashboard
    • Overview of all monitored Nagios hosts with problems
    • Link to entity lists for connected Nagios servers and their hosts
    • Problems tile for Nagios entities
Alanata logo
Alanata
Documentation
By the partner
Request support
Bring your own license
Copy to clipboard
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
