Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Gatling for load testing metricsGatling for load testing metrics
Correlate load test metrics with Dynatrace data to diagnose performance issues.
Technology by Gatling
Documentation
Screenshot of a Dynatrace Dashboard with Gatling metricsScreenshot of a Dynatrace Dashboard with Gatling metricsScreenshot of a Dynatrace Dashboard with Gatling metrics
  • Product information
Overview
The Gatling x Dynatrace integration lets you stream load testing metrics from Gatling Enterprise Edition directly into Dynatrace, so you can analyze system behavior under controlled, repeatable traffic. Instead of reviewing performance tests and production telemetry in isolation, you correlate them in a single observability platform. This allows you to understand why performance degrades, not just that it degrades. With Gatling and Dynatrace together, you turn load testing into a diagnostic signal inside your observability strategy.
What you can do
  • Visualize Gatling load test metrics alongside infrastructure KPIs
  • Correlate response times, errors, and throughput with traces and logs
  • Reproduce production issues under controlled load to isolate bottlenecks
  • Compare performance behavior across test runs, environments, and releases
Use cases
  • Reproducible performance investigations: Replay the same workload and correlate Gatling metrics with Dynatrace telemetry to diagnose regressions and incidents.
  • Bottleneck attribution across layers: Identify whether latency inflation originates at the application, dependency, network, or infrastructure layer.
  • Regression detection across releases: Track performance drift by comparing identical load tests across builds using Dynatrace dashboards.
  • Capacity planning and scaling validation: Ramp traffic while monitoring autoscaling behavior, queue depth, and saturation signals in Dynatrace.
  • SLO verification under load: Validate latency and error budgets under realistic traffic mixes before production releases.
Get started
Prerequisites
  • Gatling Enterprise Edition account
  • Dynatrace environment
  • Dynatrace API token with: metrics.ingest and events.ingest
  • Gatling Private Locations with network access to Dynatrace
Installation overview
  1. Create a Dynatrace API token with required permissions
  2. Identify your Dynatrace environment ID
  3. Configure your Gatling Control Plane with Dynatrace credentials
  4. Run a load test: metrics and events automatically appear in Dynatrace
Once enabled, Gatling will push metrics and events to Dynatrace for every test run.
Details
Metrics sent to Dynatrace
Gatling Enterprise Edition pushes detailed load testing metrics, including:
  • Virtual users (started, concurrent, stopped)
  • Request and response counts
  • Response time percentiles (p95, p99, p99.9)
  • Error rates and response codes
  • TCP and TLS connection metrics
  • Bandwidth usage
These metrics can be filtered and aggregated using dimensions such as test name, scenario, request, run ID, and load generator.
Events sent to Dynatrace
Gatling generates custom information events for:
  • Load test start
  • Load test end
Each event includes metadata such as:
  • Test name
  • Run ID
  • Team
  • Injection phase
This makes it easy to align test execution windows with performance behavior in Dynatrace timelines.
Gatling
Documentation
By the partner
Request support
Copy to clipboard
Related to Gatling for load testing metrics
Dashboards logo
Dashboards
More resources
Documentation
Documentation
Read more about the Dynatrace integration for Gatling
Read more
Observability and Load Testing
How Gatling complements observability platforms with controlled load testing
Learn more
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
