Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
ExtensionsExtensions
Extensions
Extensions
Manage Dynatrace extensions for hundreds of technologies.
App
Try in PlaygroundDocumentation
The Monitoring configs tab lists the configs that are available for each extension. Includes extension version used by each config and status.The Health tab shows the extension health per monitoring configuration.Explore the logs related to the health of each extension.Start monitoring new data sources.Manage all Extensions 2.0 installed in your environment.
  • Product information
  • Release notes
Overview
Extensions allows you to extend Dynatrace capabilities for data acquisition and domain expertise to hundreds of technologies. Extensions app is your central resource for managing and configuring Extensions 2.0.
Use cases
  • Expand Dynatrace monitoring capabilities by configuring extensions
  • Check status of running extensions and their configurations
  • Troubleshoot extensions with logs and events in context
  • Upload custom extension tailored for your needs
Get started
  1. Check the status of the Dynatrace extensions running in your environment.
  2. Browse through the list of Dynatrace extensions in Dynatrace Hub.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
Release Notes for v2.6.0
Features
  • Configurations IDs in the Monitoring Configurations table can now easily be copied to clipboard.
  • Support for TRIMMED and NO_WHITESPACE constraints in monitoring configuration schemas has been added.
  • Added Python version deprecation warnings.
Bugfixes and Maintenance
  • Hosts with Discovery monitoring mode will no longer be shown in the host selection.
  • Hosts with property standalone equal to 'true' will no longer be filtered out.
Release Notes for v2.5.0
Features
  • Unpublished versions are no longer available for install through the "Available Versions" tab
  • Support for forceSecretResubmission fields when creating/updating monitoring configurations
  • Resolved vulnerabilities in lodash-es, jsdiff and fastify dependencies
  • Migrated publishing process from HubManager to HubConsole
Fixes
  • Lacking user permissions will no longer crash the app
  • Host status table in the Health view is displayed properly now
  • Configuration selection in the Health view is now sorted and searchable by description
Breaking Changes
  • Switched to using platform Extensions API
This change makes the environment:roles:manage-settings permission not sufficient to use the application. Please check needed permissions in the Hub entry for the Extensions app.
Core Changes
  • Switched to DQL queries for metrics data
  • Migrated to dt-app v1
UI Changes
  • Removed donut charts from Health page for better clarity
  • Removed download button from all tables
  • Adjusted type filter in Extension content view to show only available asset types
  • Aligned copy button icons on Product information view
Fixes
  • Numeric fields will now properly show value 0 when editing configuration
New
  • SQL extensions on Kubernetes can now be activated from UI
  • Added missing mapping for alert creation
Changes
  • Updated 3rd parties libraries
Fixes
  • Fixed bug where extension manager app was deleting variables on monitoring configuration
  • Fixed typo that prevented some alerts to be created (dealerting)
Changes
  • Updated all tables' look and layout to fit the style of other Dynatrace apps.
  • Optimised fetching of extensions' icons and images.
Fixes
  • Fixed minor inconsistencies when filtering hosts with tags.
Changes:
  • Updated table views
  • Enabled navigation using Extensions app logo icon
Fixes:
  • Adjusted sorting extensions by version to use semantic versioning
  • Fixed IDLE configurations showing as ERROR on extension configuration status
Changes
  • Extension and configuration statues can now be marked with a Warning status if only some of the endpoints require attention.
  • Hosts and Active Gates details can now be accessed from extension Health screen.
Fixes
  • Optimised network calls.
  • Fixed infinite loading of endpoints for Python Extensions activated using intent.
We fixed some bugs and improved several UI elements.
New
  • Alerts can now be created from the app if defined in the extension
  • Extension app is now able to send self-monitoring logs to Dynatrace
  • Help menu added to navigation bar
Changes
  • Extensions app uses now the latest shell components
Changes
  • Integrated new form validation engine
  • Added recommendations and descriptions to the feature sets list
Fixes
  • Attributes section is no longer displayed when editing local configuration
  • Adjusted validation errors' messages
Fixes
  • Confirmation toast after extension upload is no longer disappearing immediately.
  • Versions list correctly updates after upload or deletion of a version.
  • No Active Gate group will be selected when creating another configuration without page refresh, which previously resulted in blocking the activation form.
QoL improvements
  • It is now possible to type a name of a searched extension while installed extensions list is still loading.
  • Deleting the last version of a custom extension will now automatically redirect to Manage page.
  • SNMP-based extensions support credential vault
  • Create credentials in the app: Credentials for the vault can now be created directly within the app.
  • Support for activating extensions in Kubernetes (K8S)
Fixes
Fixed navigation to Discover and Manage pages using the title top bar.
Other
Changes and improvements for ready-made dashboards.
Features
  • Support for code component
  • It is now possible to fully activate prometheusMetrics based extensions
Fixes
  • Entering from intent with a single extension no longer causes infinite loading.
Other
  • Added a new modal for confirmation of successful activation.
  • Changes and improvements for ready-made dashboards.
Changes
Ready-made dashboards
Added 14 ready-made dashboards for most used extensions
  • VMware Extension Overview
  • Nutanix Overview
  • Extension Data Consumption
  • IBM MQ Monitoring Overview
  • IBM Datapower Overview
  • Salesforce Overview
  • Salesforce Ingest and Outage
  • Salesforce Pages with Timeout
  • Salesforce Use Activity Deep Dive
  • Salesforce Data Infest Overview
  • Cisco Device Overview
  • SQL Server Overview
  • Oracle DB Overview
  • Kafka Overview
Fixes
Management Zones
  • All Management Zones are now visible
  • Increased Management Zones host tags limit
Extensions list
  • Bug with infinite loading of extension list is now fixed
Changes
  • New dashboards Cisco; Nutanix; VMware
Fixes
  • EXT-10702: higher limit for Management Zones
  • Active version column in Extensions versions view is now correct.
  • improved Hosts and Host Groups selection screens
  • other minor fixes
No release notes
No release notes
No release notes
No release notes
No release notes
No release notes
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
