Purple background
Software Delivery
Observability and automation at every stage of delivery
Ship faster and safer with quality gates powered by AI, automated incident triage, and closed-loop remediation built into your CI/CD workflow.
Shipping fast is easy. Shipping fast and safely is hard.
Every release is a risk without visibility into its impact. Dynatrace brings observability and AI directly into your delivery pipeline, so quality issues are caught before they reach production, and incidents are automatically addressed when they do.
  • Catch issues before production
    Automated quality gates validate every release against your SLOs, KPIs, and security requirements before it ships.
  • Triage faster, page less
    AI identifies and routes the right issues to the right teams automatically, cutting alert storms and false positives.
  • Close the loop on remediation
    When issues occur, Dynatrace executes remediation workflows automatically and verifies resolution without manual intervention.
Maximize quality and savings automatically
Leverage our easy-to-use visual workflow creator or automation-as-code workflow capabilities to see:
  • 61
    greater software quality
  • 57
    fewer deployment failures
  • 55
    lower IT costs
Embrace autonomous operations across your delivery pipeline
Leverage deterministic and agentic AI informed by full-stack observability and security data to autonomously drive incident triage, remediation, and release validation—all without manual intervention.
Incident triage
Automatically route the right issues to the right teams
Dynatrace Intelligence identifies and prioritizes incidents automatically, then creates or updates tickets and alerts the right teams. Your developers spend time on work that matters, not alert storms and false positives.
Auto-remediation
Close the loop from detection to fix, without manual intervention
When an incident occurs, Dynatrace pinpoints root cause and executes the right remediation workflow automatically through runbook integrations or natively in the platform. It verifies the resolution and updates your tickets, so nothing falls through the cracks.
Quality gates
Stop bad code before it reaches production
Site Reliability Guardian automatically validates every release against your KPIs, SLOs, and security requirements. If a build does not meet the bar, it does not ship. No manual review is required.
By providing advanced observability across our DevOps processes and app delivery pipelines, Dynatrace allows us to see the smoke before the fire starts to burn. We can stop bad code from ever reaching production, so it never becomes a problem.
Simon pilar
Simon Pilar Director DevOps & Toolchain, Clario
Bg multicolor
Create custom workflows with AutomationEngine
Our answer-driven automation technology leverages causal and predictive AI to intelligently power BizDevSecOps workflows throughout the DevOps lifecycle.
Automation engine
