Cloud computing service for building, testing, deploying, and managing applications and services.
Dynatrace automatically discovers, baselines, and intelligently monitors Microsoft Azure cloud environments.
Monitoring and problem detection
Dynatrace Azure monitoring performs AI-based automatic business impact, problem detection and root cause analysis for all Azure services, based on all metrics published to Azure Monitor. This analysis can be additionally extended by full-stack monitoring provided by OneAgent deployed on compute resources such like Azure Virtual Machines, Azure App Service and Azure Kubernetes Service. All of the entities can also be subject for comprehensive log analysis.
In addition to the above, Dynatrace allows for the understanding of workload applied Azure resources and environment dynamics per region.
The Azure monitoring is available for all Dynatrace customers, regardless if their Dynatrace cluster is SaaS based or Managed.
Ease of use and convenient visualisation
Azure monitoring comes with consistent out-of-the-box metrics, dashboards and alerts immediately after the monitoring is enabled.
The measurements and analysis of core Azure services is visualised on a purpose-built infographics dashboard (see the gallery). The convenient reports and dashboards are also available for business impact analysis and topology maps.
Flexibility
The Dynatrace users can select which services and instances are monitored and how this process is performed.This selection can be done as part of the initial monitoring setup, or at any later point. It also applies to new services enabled on the Azure cloud, or added by Microsoft.
It is possible to choose monitoring metrics for each of the supporting services. Equally, all the dashboards for Azure monitoring can be cloned and easily customized, if required.
Hybrid environments
Tracking services and dependencies is not limited to Azure. Thanks to Davis® and its ability to process data from all types of environments, Dynatrace is optimized for monitoring hybrid environments, including but not limited to business applications spanning across multiple cloud and virtualisation platforms like AWS, GCP, VMware, Kubernetes, Openshift, and on-premises infrastructure.
Built by experts
Azure monitoring and integration is built by Dynatrace experts in partnership with Microsoft.
To get started, please follow the comprehensive guide provided within our online documentation.
