593 technologies
Filters
Observability provided by
Cloud integrations
Top Filters
Extensibility provided by
Software Intelligence Hub
A curated catalog of supported technologies, integrations and extensions provided by Dynatrace and trusted partners.
Showing 593 technologies
OneAgent logo
OneAgent
All the operational and business performance metrics you need.
Active Directory services logo
Extend the visibility into your Active Directory services running on Windows hosts to monitor health and improve performance
ActiveGate logo
ActiveGate
Route traffic, monitor cloud environments, monitor remote technologies with extensions and run synthetic monitors.
ActiveMQ logo
ActiveMQ
Open source message broker written in Java together with a full Java Message Service client.
Adobe Analytics logo
Adobe Analytics
Get real-time answers for business anomalies with shared business context from Adobe Analytics
Adobe PhoneGap logo
Adobe PhoneGap
Monitor hybrid mobile apps built with Adobe PhoneGap running on iOS or Android
ADO.NET logo
ADO.NET
Solve ADO.NET performance problems at code level.
aDSS avodaq Data Snapshot Service logo
avodaq AGavodaq AG
Easily export and retain real user (including session replay) and performance data to address business and technical reporting requirements.
Advanced SSL Certificate Check for Dynatrace logo
360performance360performance
Perform extended SSL certificate checks and integrate seamlessly with your existing synthetic monitors.
Akamas logo
Akamas
AkamasAkamas
Akamas AI enables enterprises and online businesses to maximize service quality, resilience and cost savings.
Akka logo
Akka
Powerful reactive, concurrent, and distributed applications in Java and Scala.
amasol logo
amasol
amasol AGamasol AG
Seamlessly organize your IT infrastructure with maximum scalability, security and availability.
Amazon API Gateway logo
Amazon API Gateway
Service for developers to create, publish, maintain, monitor, and secure APIs.
Amazon AppStream 2.0 logo
Fully managed application streaming service that provides users with instant access to their desktop applications from anywhere.
Amazon Athena logo
Amazon Athena
Interactive query service that makes it easy to analyze data directly in Amazon S3 using standard SQL.
Amazon Aurora logo
Amazon Aurora
Relational database service developed and offered by Amazon Web Services.
Amazon CloudFront logo
Amazon CloudFront
Content delivery network offered by Amazon Web Services.
Amazon CloudSearch logo
Amazon CloudSearch
Set up, manage, and scale a search solution for your website or application using CloudSearch.
Amazon Cloudwatch logo
Amazon Cloudwatch
Monitoring service for AWS cloud resources and the applications you run on AWS.
Amazon CloudWatch Logs logo
Monitor, store, and access your log files from instances, AWS CloudTrail, Route 53, and other sources.
Amazon Cognito logo
Amazon Cognito
Add user sign-up, sign-in, and access control to your web and mobile apps quickly and easily.
Amazon Connect logo
Amazon Connect
Easy to use omnichannel cloud contact center that helps you to provide superior customer service at a lower cost.
Amazon DocumentDB logo
Amazon DocumentDB
Amazon DocumentDB (with MongoDB compatibility) is a fast, reliable, and fully managed database service.
Amazon DynamoDB logo
Amazon DynamoDB
Fully managed NoSQL database service that supports key-value and document data structures.
Amazon DynamoDB Accelerator (DAX) logo
Fully managed, highly available, in-memory cache for your Amazon DynamoDB.
Amazon EC2 logo
Amazon EC2
Web service that provides secure, resizable compute capacity in the cloud.
Amazon EC2 Auto Scaling logo
Amazon EC2 Auto Scaling helps you ensure that you have the correct number of Amazon EC2 instances available.
Amazon EC2 Spot Fleet logo
Spot Instances and On-Demand Instances to meet the target capacity that you specified.
Amazon ElastiCache logo
Amazon ElastiCache
Fully managed in-memory data store and cache service by Amazon Web Services.
Amazon Elastic Block Store (EBS) logo
Raw block-level storage that can be attached to Amazon EC2 instances.
Amazon Elastic Container Service (ECS) logo
Fully managed container orchestration service.
Amazon Elastic File Service (EFS) logo
Cloud storage service provided by Amazon Web Services.
Amazon Elastic Inference logo
Accelerate deep learning inference workloads by attaching to your Amazon EC2 CPU instances.
Amazon Elastic Kubernetes Service (EKS) logo
Kubernetes service that allows you to run on AWS without managing the control plane.
Amazon Elasticsearch Service logo
Fully managed service to deploy, secure, and run Elasticsearch cost effectively at scale, without the operational overhead.
Amazon Elastic Transcoder logo
Convert and transcode media files stored in Amazon S3.
Amazon EMR logo
Amazon EMR
Cloud big data platform for processing vast amounts of data using open source tools.
Amazon EventBridge logo
Amazon EventBridge
Serverless event bus to connect applications together using data from your own applications, integrated SaaS applications, and AWS services.
Amazon FSx for Lustre logo
Makes it easy and cost-effective to launch and run the popular, high-performance Lustre file system.
Amazon FSx for Windows File Server logo
Provides a managed Microsoft Windows file servers, backed by a native Windows file system.
Amazon GameLift logo
Amazon GameLift
Enables developers to deploy, operate, and scale dedicated, low-cost servers in the cloud for session-based, multiplayer games.
Amazon Inspector logo
Amazon Inspector
Tests the network accessibility of your EC2 instances and the security state of your applications that run on those instances.
Amazon Keyspaces for Apache Cassandra logo
Scalable, highly available, and managed Apache Cassandra–compatible database service.
Amazon Kinesis Data Analytics logo
Transform and analyze streaming data in real time with open source framework and engine for processing data streams (Apache Flink).
Amazon Kinesis Data Firehose logo
Fully managed service for delivering real-time streaming data.
Amazon Kinesis Data Streams logo
Collect log and event data from sources such as servers, desktops, and mobile devices.
Amazon Kinesis Video Streams logo
Provides you SDKs to install on your devices to make it easy to stream media.
Amazon Lex logo
Amazon Lex
Service for building conversational interfaces for applications using voice and text.
Amazon Linux 2 logo
Amazon Linux 2
Dynatrace observability for AWS Amazon Linux2 monitoring - using AI and automation to make capacity and server management easy.
Amazon Managed Service for Prometheus logo
Ingest metrics from Amazon Managed Prometheus to Dynatrace.
Amazon MSK logo
Amazon MSK
Fully managed service that enables you to build and run applications that use Apache Kafka to process streaming data.
Amazon Neptune logo
Amazon Neptune
Fast, reliable, fully managed graph database built for highly connected datasets.
Amazon Polly logo
Amazon Polly
Cloud service that converts text into lifelike speech.
Amazon Quantum Ledger Database (QLDB) logo
Ledger by a central trusted authority that provides an immutable, and cryptographically verifiable transaction log.
Amazon Redshift logo
Amazon Redshift
Data warehouse product which forms part of the larger cloud-computing platform AWS.
Amazon Rekognition logo
Amazon Rekognition
Amazon Rekognition makes it easy to add image and video analysis to your applications.
Amazon Relational Database Service (RDS) logo
Cloud web service designed to simplify the setup, operation, and scaling of a relational database.
Amazon Route 53 logo
Amazon Route 53
Effectively connects user requests to infrastructure running in AWS.
Amazon S3 logo
Amazon S3
Provides object storage through a web service interface.
Amazon SageMaker logo
Amazon SageMaker
Build, train, and deploy machine learning (ML) models quickly.
Amazon Simple Email Service (SES) logo
Cloud-based service that helps developers send marketing, notification, and transactional emails.
Amazon Simple Notification Service (SNS) logo
Provides a simple web services interface that can be used to create topics you want to notify apps.
Amazon Simple Queue Service (SQS) logo
Programmatic sending of messages via web service applications.
Amazon Simple Workflow Service (SWF) logo
Makes it easy to build applications that coordinate work across distributed components.
Amazon Textract logo
Amazon Textract
Makes it easy to add document text detection and analysis to your applications.
Amazon Transfer Family logo
Provides fully managed support for file transfers directly into and out of Amazon S3 using SFTP, FTPS, and FTP
Amazon Translate logo
Amazon Translate
Text translation service using machine learning to provide high-quality translation on demand.
Amazon VPC (NAT Gateway) logo
Connect to the Internet from instances within a private subnet in an AWS Virtual Private Cloud.
Amazon WorkMail logo
Amazon WorkMail
Secure, managed business email and calendaring service with support for existing desktop and mobile email clients.
Amazon WorkSpaces logo
Amazon WorkSpaces
Enables you to provision virtual, cloud-based Microsoft Windows or Amazon Linux desktops, known as WorkSpaces.
Amazon MQ logo
Amazon MQ
Managed message broker service for Apache ActiveMQ that makes it easy to migrate to a message broker in the cloud.
AMP logo
AMP
Accelerated Mobile Pages performance monitoring to ensure perfect user experience.
Android logo
Android
Monitor mobile applications that are running on the popular Android operating system.
Android Webkit logo
Android Webkit
Provides tools for browsing the web.
Angular logo
Angular
Platform for building mobile and desktop web applications.
AngularJS logo
AngularJS
JavaScript-based open-source front-end web framework mainly maintained by Google.
Ansible logo
Ansible
The simplest way to automate apps and IT infrastructure.
Ansible Tower logo
Ansible Tower
Way to automate apps and IT infrastructure.
Apache Axis2 logo
Apache Axis2
Core engine for Web services.
Apache Camel logo
Apache Camel
Extend observability with PurePath 4 by seamlessly integrating OpenTracing data for Java emitted by the Apache Camel integration framework.
Apache Cordova logo
Apache Cordova
Monitor hybrid mobile apps built with Cordova running on iOS or Android
Apache CXF logo
Apache CXF
Open-source, fully featured Web services framework.
Apache HTTP Server logo
Apache HTTP Server
Develop and maintain an open-source HTTP server.
Apache JMeter logo
Apache JMeter
Build management and continuous integration server from JetBrains.
Apache Kafka logo
Apache Kafka
Apache Kafka is an open-source, distributed publish-subscribe message bus designed to be fast, scalable, and durable.
Apache Mesos/Marathon logo
Abstracts CPU, memory and storage away from machines, enabling to easily run systems effectively.
Apache Solr logo
Apache Solr
Open-source enterprise-search platform, written in Java, from the Apache Lucene project.
Apache Spark logo
Apache Spark
Distributed general-purpose cluster-computing framework for programming entire clusters.
Apache Storm logo
Apache Storm
Get visibility into your Apache Storm infrastructure
Apache Tomcat logo
Apache Tomcat
Open source implementation of the Java Servlet, Pages, Expression Language and WebSocket.
Apache TomEE logo
Apache TomEE
Java Enterprise Edition of Apache Tomcat that combines several Java enterprise projects.
Apigee Edge logo
Apigee Edge
Design, secure, and analyze APIs across the entire API lifecycle.
Apple Safari logo
Apple Safari
Graphical web browser developed by Apple, based on the WebKit engine.
ASP.NET logo
ASP.NET
Deep visibility into the code execution of your ASP.NET apps.
ASP.NET AJAX logo
ASP.NET AJAX
Set of extensions to ASP.NET
ASP.NET Core logo
ASP.NET Core
Deep visibility into the code execution of your ASP.NET Core apps.
ASP.NET MVC logo
ASP.NET MVC
Deep visibility into the code execution of your ASP.NET MVC apps.
ASP.NET Owin/Katana logo
ASP.NET Owin/Katana
Flexible set of components for building and hosting OWIN-based web applications.
Atlassian Bamboo logo
Atlassian Bamboo
Continuous integration and continuous deployment server developed by Atlassian.
Atlassian JIRA logo
Atlassian JIRA
Issue tracking product that allows bug tracking and agile project management.
AWS logo
AWS
Reliable, scalable, and inexpensive cloud computing services with pay-as-you-go pricing approach.
AWS AppSync logo
AWS AppSync
Enterprise-level, fully managed GraphQL service with real-time data synchronization and offline programming features.
AWS Billing and Cost Management logo
The service that you use to pay your AWS bill, monitor usage, and analyze and control costs.
AWS Chatbot logo
AWS Chatbot
Enables DevOps to use Amazon Chime and Slack chat rooms to monitor and respond to events.
AWS CloudHSM logo
AWS CloudHSM
Hardware security modules (HSM) in the AWS Cloud.
AWS CodeDeploy logo
AWS CodeDeploy
Fully managed service that automates software deployments to a variety of compute services.
AWS CodePipeline logo
AWS CodePipeline
Continuous delivery service automating release pipelines for application and infrastructure updates.
AWS Database Migration Service logo
Makes it easy to migrate relational databases, and other types of data stores.
AWS DataSync logo
AWS DataSync
Transfer service designed to simplify and automate copying large amounts of data to and from AWS services.
AWS Direct Connect logo
AWS Direct Connect
Links your internal network to an AWS Direct Connect location over a standard Ethernet fiber-optic cable.
AWS Elastic Beanstalk logo
Quickly deploy and manage applications in the AWS Cloud without having to learn about the infrastructure beneath.
AWS Elastic Load Balancing logo
Automatically distributes incoming application traffic across multiple targets.
AWS Elemental MediaConnect logo
Service that makes it easy for broadcasters and other premium video providers to reliably ingest live video into the AWS Cloud.
AWS Elemental MediaConvert logo
File-based video processing service that provides scalable video processing for content owners and distributors.
AWS Elemental MediaPackage logo
Just-in-time video packaging and origination service that runs in the AWS Cloud.
AWS Elemental MediaTailor logo
Scalable ad insertion service that runs in the AWS Cloud.
AWS Fargate logo
AWS Fargate
Serverless compute for containers. Dynatrace provides automatic monitoring of AWS Fargate containers at scale.
AWS Glue logo
AWS Glue
Fully managed extract, transform, and load (ETL) service.
AWS IoT logo
AWS IoT
Run local compute, messaging, data caching, and machine learning inference capabilities.
AWS IoT Analytics logo
AWS IoT Analytics
Automates the steps required to analyze data from IoT devices.
AWS IoT Things Graph logo
Orchestration service that simplifies development of IoT applications.
AWS Lambda logo
AWS Lambda
Automatic and intelligent end-to-end observability for AWS Lambda traces.
AWS OpsWorks logo
AWS OpsWorks
Configuration management service that helps you configure and operate applications by using Puppet or Chef.
AWS Outposts logo
AWS Outposts
Fully managed service that extends AWS infrastructure, AWS services, APIs, and much more.
AWS PrivateLink logo
AWS PrivateLink
Provides private connectivity between VPCs, AWS services, and on-premises applications.
AWS RoboMaker logo
AWS RoboMaker
Service that makes it easy to create robotics applications at scale.
AWS Service Catalog logo
AWS Service Catalog
Enables organizations to create and manage catalogs of IT services that are approved for use on AWS.
AWS Site-to-Site VPN logo
Allows connecting and routing from your VPC to your remote network.
AWS Step Functions logo
AWS Step Functions
Enables you to coordinate the components of distributed applications and microservices using visual workflows.
AWS Storage Gateway logo
AWS Storage Gateway
Connects an on-premises software appliance with cloud-based storage to provide data security.
AWS Systems Manager logo
AWS Systems Manager
View and control your infrastructure on AWS using Systems Manager.
AWS Transit Gateway logo
AWS Transit Gateway
Network transit hub interconnecting virtual private clouds (VPC) and on-premises networks.
AWS Trusted Advisor logo
AWS Trusted Advisor
Identifies ways to reduce cost, increase performance, and improve security for your AWS account.
AWS Web Application Firewall (WAF) logo
Web application firewall that lets you monitor the HTTP(S) requests.
Azure Analysis Services logo
Fully managed platform as a service (PaaS) that provides enterprise-grade data models in the cloud.
Azure Anomaly Detector logo
Detects anomalies in time series data with numerical values that are uniformly spaced in time.
Azure API Management logo
Create consistent and modern API gateways for existing back-end services.
Azure App Configuration logo
Service to provide centrally managed application settings and feature flags.
Azure Application Gateway logo
Web traffic load balancer that enables you to manage traffic to your web applications.
Azure Application Insights logo
An extensible Application Performance Management (APM) service for developers and DevOps.
Azure App Service logo
Azure App Service
Cloud computing based platform for hosting websites, created and operated by Microsoft.
Azure Automation account logo
Allows you to automate your Azure management tasks and to orchestrate actions across external systems from right within Azure.
Azure Batch logo
Azure Batch
Get complete picture of jobs, tasks and node tracking, in each state, for operational efficiency.
Azure Bing Autosuggest logo
Helps users complete queries faster by adding intelligent type-ahead capabilities to your app or website.
Azure Bing Custom Search logo
An easy-to-use, ad-free, commercial-grade search tool that lets you deliver the results you want.
Azure Bing Entity Search logo
Bring rich context data to your apps through entity information for a more engaging experience.
Azure Bing Search logo
Azure Bing Search
Build apps and services that find webpages, images, news, locations, and more.
Azure Bing Spell Check logo
Correct spelling and word breaks errors, recognize slang, names, homonyms, brands and more.
Azure Blob Storage logo
Azure Blob Storage
Handles stored objects, with millions of requests per second, for customers around the world.
Azure Blockchain logo
Azure Blockchain
Fully managed ledger service that enables users the ability to grow and operate blockchain networks at scale in Azure.
Azure Cache for Redis logo
Industry-standard SSL to secure your data in transit and Azure Storage disk encryption at rest.
Azure CDN profiles logo
Azure CDN profiles
Collections of CDN endpoints and each CDN profile contains one or more CDN endpoints.
Azure Cloud Services (Classic) logo
Deploy web apps (web roles) and background services (worker roles) onto Azure virtual machines.
Azure CloudSimple Virtual Machines logo
Manage VMware virtual machines (VMs) from the Azure portal.
early
Azure Cognitive Services logo
Bring AI within reach of every developer—without requiring machine-learning expertise.
Azure Computer Vision logo
AI service to boost content discoverability, automate text extraction, analyze video in real time, and more.
Azure Connections logo
Azure Connections
This tool is designed to meet and accomplish your hybrid identity goals.
soon
Azure Container Instance logo
Deploy and manage serverless containers on the Microsoft Azure cloud, without having to manage any underlying infrastructure.
Azure Container Registries logo
Managed, private Docker registry service based on the open-source Docker Registry 2.0.
Azure Content Moderator logo
AI service for content moderation and human review tool for images, text, and videos.
Azure Cosmos DB logo
Azure Cosmos DB
Globally-distributed, multi-model database service "for managing data at planet-scale".
Azure Custom Vision Prediction logo
Customize computer vision for specific domain. No machine learning expertise is required.
Azure Custom Vision Training logo
Azure Database for Maria DB logo
Full coverage of performance for critical workloads with AI-problem detection, availability, and more.
Azure Database for MySQL logo
Full observability of MYSQL servers and database instances to ensure database health and performance.
Azure Database for PostgreSQL logo
Full insight into database performance for critical workloads with AI-problem detection and more.
Azure Data Box Edge  logo
Azure Data Box Edge
Rebranded as Azure Stack Edge. ... Azure Stack Edge is a Hardware-as-a-service solution.
soon
Azure Data Catalog logo
Azure Data Catalog
Fully managed cloud service that lets users discover the data sources they need and understand the data sources they find.
Azure Data Explorer Clusters logo
Engine and data management clusters which uses several Azure resources such as Azure Linux VM's and Storage.
Azure Data Factory logo
Azure Data Factory
Cloud-based ETL and data integration service for creating data-driven workflows for moving and transforming data at scale.
Azure Data Lake Analytics logo
Distributed, cloud-based data processing architecture offered by Microsoft in the Azure cloud.
Azure Data Lake Storage logo
Fully-managed, elastic, scalable, and secure file system that supports HDFS semantics and works with the Hadoop ecosystem.
Azure Data Share logo
Azure Data Share
Platform as a Service tool that allows you to share data sets using Azure Services.
Azure Device Provisioning Service logo
Helper service for IoT Hub that enables just-in-time provisioning to the right IoT hub without human intervention.
Azure DevOps Keptn Extension logo
Inetum-RealdolmenInetum-Realdolmen
Integrate your Azure DevOps pipelines with Keptn to enable features like quality gates
Azure Disk Storage logo
Azure Disk Storage
Cloud storage offering providing multiple solutions for organizations.
Azure DNS Zones logo
Azure DNS Zones
Data resource that contains the DNS records for a domain name.
Azure Event Grid Domains logo
Simplifies the development of event-based applications and simplifies the creation of serverless workflows.
Azure Event Grid Subscriptions logo
Support for Azure Event Grid Subscriptions.
soon
Azure Event Grid Topics logo
Topic based events for serverless and event based workflows.
Azure Event Hub Clusters logo
Big data streaming platform and event ingestion service. It can receive and process millions of events per second.
Azure Event Hubs logo
Azure Event Hubs
Fully managed data ingestion service that's simple, and scalable.
early
Azure ExpressRoute logo
Azure ExpressRoute
Extend your on-premise networks into the Microsoft cloud over a private connection.
Azure Express Route Circuits logo
Connect your on-premises infrastructure and Microsoft cloud services through a connectivity provider.
Azure Face logo
Azure Face
An AI service that analyzes faces in images
Azure File Storage logo
Azure File Storage
Fully managed file shareing in the cloud.
Azure Firewall logo
Azure Firewall
Managed, cloud-based network security service that protects your Azure Virtual Network resources.
Azure Front Door logo
Azure Front Door
Optimize application performance with visibility into requests and latency, ensuring routing efficiency and backend health.
Azure Functions logo
Azure Functions
Serverless compute functions. Dynatraces provides full observability for Azure functions end-to-end, at scale.
Azure HDInsight logo
Azure HDInsight
Holistic analytics of HDInsights with integrated metrics from Hadoop, Spark, and Kafka, all in one place.
Azure Immersive Reader logo
An AI service to embed text reading into applications.
Azure Ink Recognizer logo
An AI service that provides a cloud-based REST API to analyze and recognize digital ink content.
Azure Integration Service Environment logo
Allows you to deploy Logic Apps as a service in your Azure Virtual Network.
Azure IoT Central Applications logo
Fully hosted by Microsoft, which reduces the administration overhead of managing your applications.
Azure IoT Hub logo
Azure IoT Hub
Cloud-hosted solution backend to connect virtually any device.
Azure Key Vault logo
Azure Key Vault
Cloud service within you can securely store keys, passwords, certificates, and other secrets.
Azure Kubernetes Services (AKS) logo
Kubernetes based, managed container orchestration service, available on the Microsoft Azure public cloud.
Azure Language Understanding (LUIS) logo
An AI service that allows users to interact with your applications, bots, and IoT devices by using natural language.
Azure Load Balancer logo
Azure Load Balancer
Layer-4 load balancer that provides high availability by distributing incoming traffic among VMs.
Azure Logic Apps logo
Azure Logic Apps
Cloud service that helps you schedule, automate, and orchestrate tasks across enterprises or organizations.
Azure Machine Learning logo
Collection of services and tools intended to help developers train and deploy machine learning models.
Azure Maps account logo
Azure Maps account
Provides the geospatial capability for mapping the data.
Azure Media Services logo
Cloud-based platform to build solutions that achieve broadcast-quality video streaming.
Azure NetApp Capacity Pool logo
Enterprise-class, high-performance, metered file storage service
Azure NetApp files logo
Azure NetApp files
File-storage service to run your most demanding file-workloads in Azure, without the need for any code modification.
Azure Network Interface logo
Enables an Azure Virtual Machine to communicate with internet, Azure and on-premises resources.
Azure Network Watcher logo
Provides tools to monitor, diagnose, view metrics, and enable or disable logs for resources in an Azure virtual network.
Azure Notification Hub Namespaces logo
Push engine that allows you to send notifications to any platform from any backend (cloud or on-premises).
Azure Peerings logo
Azure Peerings
Virtual network peering enables you to seamlessly connect networks in Azure Virtual Network.
early
Azure Personalizer logo
Azure Personalizer
An AI service that prioritizes relevant content, layouts, and conversations to deliver personalized user experience.
Azure Private DNS Zone logo
Hosting service for DNS domains, providing name resolution using the Microsoft Azure infrastructure.
Azure Public IP address logo
Reserved public IP addresses for your public endpoints in Azure.
Azure QnA Maker logo
Azure QnA Maker
Build, train and publish a sophisticated bot without machine learning experience.
Azure Queue Storage logo
Azure Queue Storage
Service for storing large numbers of messages that can be accessed from anywhere in the world.
Azure Relays logo
Azure Relays
Enables you to securely expose services that run in your corporate network to the public cloud.
Azure Search Services logo
Fully managed cloud search service that provides a better user experience for customers.
Azure Service Bus logo
Azure Service Bus
Cloud messaging as a service (MaaS) and simple hybrid integration.
Azure Service-Fabric logo
Package, deploy, and manage scalable and reliable microservices and containers.
Azure Service Fabric Mesh logo
Deployment of microservice applications without managing virtual machines, storage, or networking.
Azure Service-Fabric Reliable Services logo
Simplifies writing and managing stateless and stateful services.
Azure SignalR logo
Azure SignalR
Adding real-time communications to your web application is as simple as provisioning a service.
Azure Speech To Text logo
An AI service that accurately converts spoken audio to text.
Azure Spring Cloud logo
Azure Spring Cloud
Brings modern microservice patterns to Spring Boot apps eliminating boilerplate code to quickly develop robust Java apps.
Azure SQL Database logo
Azure SQL Database
Managed cloud database provided as part of Microsoft Azure.
Azure SQL Managed logo
Azure SQL Managed
Full observability into cloud database performance and automated monitoring for Azure SQL Managed.
Azure SQL Server Stratch logo
Dynamically stretch warm and cold transactional data from SQL Server 2016 to Azure.
Azure Storage Sync Service logo
Centralize your file shares in the cloud while keeping the benefits of an on-premise file server.
Azure Stream Analytics Jobs logo
Serverless job service that eliminates the need for infrastructure, servers, virtual machines, or managed clusters.
Azure Synapse Analytics logo
Cloud-based, scale-out, relational database capable of processing massive volumes of data.
Azure Table Storage logo
Azure Table Storage
Stores structured NoSQL data in the cloud, providing a key/attribute store with a schemaless design.
Azure Text Analytics logo
Uncover insights such as sentiment, entities, and key phrases in unstructured text.
Azure Time Series Insights logo
Fully managed analytics, storage, and visualization service for managing IoT-scale time-series data in the cloud.
Azure Traffic Manager logo
Multi-cloud support for improved application performance and availability with distributed tracing.
Azure Translator logo
Azure Translator
AI powered service to translate text in real time across more than 70 languages.
Azure Virtual Machines logo
Documentation for creating and managing Windows virtual machines in Azure.
Azure Virtual Machine Scale Sets logo
Scale-out workloads, stateless web front ends, container orchestration, and microservices clusters.
Azure Virtual machines (classic) logo
Deep observability into Azure cloud service virtual machines and applications.
Azure Virtual Network Gateway logo
Monitor connecting workloads and performance to ensure Azure network is successfully connected.
Azure Virtual Networks logo
Fundamental building block for your private network in Azure. VNet enables many types of Azure resources.
Azure Web Apps logo
Azure Web Apps
Host websites, web apps, RESTful APIs, and mobile back ends in Azure App Service.
Backbone.js logo
Backbone.js
JavaScript library based on the Model–view–presenter application design paradigm.
Bitbucket logo
Bitbucket
Version control repository service for source code thas use either Mercurial or Git systems.
Blazemeter logo
Blazemeter
Commercial, self-service load testing platform as a service.
BOSH bpm logo
BOSH bpm
Auto-injection in BOSH bpm container (Deep monitoring)
C logo
C
Procedural programming language supporting lexical variable scope, and recursion.
C++ logo
C++
High-level, general-purpose programming language as an extension of the C programming language.
CakePHP logo
CakePHP
Open-source web framework, model–view–controller approach.
Cassandra logo
Cassandra
Right choice when you need scalability and high availability without compromising performance.
CentOS logo
CentOS
Community-supported computing platform compatible with Red Hat Enterprise Linux.
Chef logo
Chef
Configuration management tool.
Cisco Adaptive Security Appliance (ASA) logo
Monitor your Cisco Adaptive Security Appliance (ASA) devices
Citrix NetScaler ADC logo
All-in-one web ADC that makes applications run up to five times faster.
Citrix Virtual Apps and Desktops logo
Complete virtual app and desktop solution to meet all your business needs.
Cloud Automation Control Plane logo
Extend Dynatrace with an enterprise-grade control plane for lifecycle automation, release validation and closed loop problem remediation.
CloudFlare logo
CloudFlare
Content-delivery-network services, DDoS mitigation, Internet security, and distributed services.
Cloud Foundry logo
Cloud Foundry
Open source cloud application platform for developing and deploying cloud applications.
Composer logo
Composer
PerformetriksPerformetriks
Simplify Administration and Configuration Management for Dynatrace
Concourse logo
Concourse
Concourse is the automation engine for cloud native CI/CD.
Connection Pools: JBoss logo
Application server method of pooling and sharing multiple connections to a database.
Connection Pools: Tomcat logo
Connection Pools: WebLogic logo
Connection Pools: WebSphere Liberty logo
Consul Service Mesh (StatsD) logo
HashiCorp's Consul service mesh is designed to work with traditional and legacy applications, and workloads running in Kubernetes.
containerd logo
containerd
Automated deep monitoring w/o code-changes for apps and microservices running in containerd containers in Kubernetes.
Control-M Jobs logo
Control-M Jobs
Monitor your Control-M jobs execution status
CoreDNS logo
CoreDNS
Detailed visibility of CoreDNS server health state and throughput
CoreOS logo
CoreOS
Open-source lightweight OS based on the Linux, providing infrastructure to clustered deployments.
Couchbase logo
Couchbase
NoSQL document-oriented database software package optimized for interactive applications.
CouchDB logo
CouchDB
Open-source document-oriented NoSQL database, implemented in Erlang.
cri-o logo
cri-o
Automated deep monitoring w/o code-changes for apps and microservices running in cri-o containers in Kubernetes.
Custom Database Queries logo
Make custom databases queries to your Oracle, Postgres, MSSQL or DB2 databases and send the metrics to Dynatrace
Custom Linux Commands logo
Execute generic commands over SSH and evaluate the output either as a RegEx expression or as a numeric comparison.
Davis Assistant logo
Davis Assistant
Immediate actionable answers to complex Dynatrace questions with a simple conversation.
DC/OS logo
DC/OS
Monitor application and cluster health in highly-dynamic container environments.
Debian logo
Debian
Association of individuals who have made common cause to create a free operating system.
Docker logo
Docker
OS-level virtualization to deliver software in packages called containers.
Dojo logo
Dojo
Modular JavaScript library open source based.
Drupal logo
Drupal
Web content management for back-end framework.
Dynatrace App for Android logo
The Dynatrace mobile app provides real-time alerts detected in your application environment.
Dynatrace app for iOS logo
Provides real-time alerts on your iPhone/iPad when performance problems are detected.
Eclipse Jetty logo
Eclipse Jetty
Provides a Web server and javax.servlet container.
Elasticsearch logo
Elasticsearch
Provides a distributed, multitenant-capable full-text search engine, based on the Lucene library.
Ember.js logo
Ember.js
Open-source JavaScript web framework, based on the Model–view–viewmodel pattern.
Erlang logo
Erlang
General-purpose, concurrent, functional programming language, and a runtime system.
etcd for OpenShift logo
etcd for OpenShift
Get deep insights into your self-managed OpenShift control plane using etcd metrics exposed on your cluster.
Eureka logo
Eureka
Used in the AWS cloud for locating services for load balancing and failover of servers.
Express logo
Express
Fast, unopinionated, minimalist web framework for Node.js.
F5 BIG-IP LTM logo
F5 BIG-IP LTM
Intelligently manages network traffic so applications are always fast, available, and secure.
Fedora logo
Fedora
Linux distribution sponsored primarily by Red Hat, a subsidiary of IBM.
Files checks logo
Files checks
Checks for directories or files existence, count, size and modification date
Fluentd logo
Fluentd
Stream your logs via Fluentd to Dynatrace and analyze them
soon
Flutter logo
Flutter
Monitor mobile applications built with Flutter on iOS or Android.
Fortinet Fortigate logo
Fortinet Fortigate
Monitor your Fortigate devices via the REST API
Fujitsu Interstage logo
Fujitsu Interstage
Suite of inter-working software products.
Fujitsu Interstage IHS logo
Complete suite of software that helps companies continuously visualize and optimize their business.
Garden-RunC logo
Garden-RunC
Auto-injection in Garden-RunC container (Deep monitoring)
Gatling logo
Gatling
Open-source load and performance testing framework based on Scala, Akka and Netty.
Generic Cisco device logo
Monitor Cisco routers using SNMP to feed Dynatrace with metrics to allow alerting and Davis problem detection
soon
Generic network device logo
Monitoring devices using SNMP feeds Dynatrace with metrics to allow alerting and Davis problem detection
soon
GlassFish logo
GlassFish
Open source Java EE reference implementation.
Go logo
Go
Open source language that makes it easy to build simple, reliable, and efficient software.
Google Analytics logo
Google Analytics
Track and optimize marketing campaigns with shared business context from UTM parameters tracked in Google Analytics.
Google Analytics Real-Time logo
MarketWareMarketWare
Import your Google Analytics real-time data into Dynatrace and correlate it with all other metrics provided by Dynatrace.
Google App Engine logo
Google App Engine
Service and cloud computing platform for developing and hosting web applications.
Google Big Query logo
Google Big Query
Enterprise data warehouse.
Google Bigtable logo
Google Bigtable
NoSQL Big Data database service.
Google Chrome logo
Google Chrome
Cross-platform web browser developed by Google.
Google Cloud APIs logo
Google Cloud APIs
Programmatic interfaces for Google Cloud services.
Google Cloud Composer logo
A fully managed workflow orchestration service.
Google Cloud Dataflow logo
Streaming analytics service.
Google Cloud Dataproc logo
A cloud service for running Apache Spark and Apache Hadoop clusters.
Google Cloud DNS logo
Google Cloud DNS
Support for Google Cloud DNS.
Google Cloud Filestore logo
High-performance, fully managed file storage.
Google Cloud Firestore logo
A flexible, scalable database for mobile, web, and server development.
Google Cloud Interconnect logo
Get direct physical connections between your on-prem network and Google Cloud.
Google Cloud IoT logo
Google Cloud IoT
Secure device connection and management.
Google Cloud Load Balancing logo
High performance, scalable load balancing across multiple targets.
Google Cloud Memorystore for Redis logo
A fully managed in-memory data store service.
Google Cloud Platform logo
Meet your business challenges head on with cloud computing services from Google.
Google Cloud Router logo
Google Cloud Router
Exchange routes between your VPC and on-premises networks by using BGP.
soon
Google Cloud Run logo
Google Cloud Run
Dynatrace provides AI-powered observability into serverless containerized apps running on Google Cloud Run
Google Cloud SQL logo
Google Cloud SQL
Fully-managed database service for PostgreSQL, MySQL, and SQL Server
Google Cloud Storage logo
Reliable and secure object storage for any amount of data.
Google Cloud Tasks logo
Google Cloud Tasks
Distributed task queues.
soon
Google Cloud Tensor Processing Unit (TPU) logo
Train and run machine learning models.
Google CloudTrace logo
Google CloudTrace
Distributed tracing system that collects latency data from your apps and displays it in the GCP.
Google Compute Engine logo
Service component of Google Cloud Platform, built on the global infrastructure.
Google Container-optimized OS logo
Dynatrace OneAgent monitors Kubernetes nodes with Google's secure Container-optimized OS quickly, efficiently, and securely.
Google Data Loss Prevention (DLP) logo
Provides fast, scalable classification and redaction for sensitive data elements.
Google Datastore logo
Google Datastore
NoSQL database.
Google Firebase Storage, Hosting, Database logo
Mobile platform for application development.
Google Functions logo
Google Functions
Serverless platform for building event-based microservices.
Google Kubernetes Engine (GKE) logo
Dynatrace provides AI powered observability for Google Kubernetes Engine pods, nodes, and clusters.
Google Machine Learning logo
Machine learning services.
soon
Google Managed Service for Microsoft Active Directory logo
Service running Microsoft AD that enables you to manage authentication and authorization.
soon
Google Network Topology logo
Visualization tool for viewing the topology of your VPC networks and the metrics.
soon
Google Pub/Sub logo
Google Pub/Sub
Real-time messaging service.
Google reCAPTCHA Enterprise logo
Help protect your website from fraudulent activity, spam, and abuse.
Google Spanner logo
Google Spanner
Horizontally scalable, globally consistent, relational database service.
Google Storage transfer logo
Complete large-scale online data transfers from online and on-premises sources to Cloud Storage.
soon
Google VPC access logo
Google VPC access
Provides support for Google VPC access.
GraalVM logo
GraalVM
Java VM and JDK based on HotSpot/OpenJDK, implemented in Java.
Gradle logo
Gradle
Build automation system that introduces a language for declaring the project configuration.
Grails logo
Grails
Groovy-based web application framework for the JVM built on top of Spring Boot.
Gremlin for Dynatrace logo
GremlinGremlin
Gremlin for Dynatrace enables engineers to build more reliable software by running Chaos Engineering experiments with confidence.
gRPC logo
gRPC
Open source remote procedure call (RPC) system.
GWT Web Toolkit logo
GWT Web Toolkit
Set of tools that allows web developers to create and maintain JavaScript front-end applications.
Hadoop HDFS logo
Hadoop HDFS
The Hadoop Distributed File System (HDFS) is a distributed file system designed for high throughput, large application data sets.
Hadoop YARN logo
Hadoop YARN
Collection of utilities that allows to solve problems involving massive amounts of data.
HAProxy logo
HAProxy
Load balancer and proxy server for applications that spreads requests across multiple servers.
HashiCorp Terraform logo
HashiCorp Terraform
Leverage Terraform to automate deployment of dashboards, custom services, management zones etc. across your complete Dynatrace instance.
Hazelcast logo
Hazelcast
Dynatrace PurePath 4 seamlessly integrates OpenTracing data for Java emitted by the Hazelcast in-memory computing platform.
early
Heroku logo
Heroku
Platform as a service that enables developers to build, run, and operate applications in the cloud.
HornetQ logo
HornetQ
Open-source asynchronous messaging project from JBoss.
How fast is your app? logo
Measure your native mobile app performance and availability on real Android and iPhone devices, with no instrumentation.
HTML5 logo
HTML5
Markup language used for structuring and presenting content on the web.
HTTP logo
HTTP
Application protocol for distributed, collaborative, hypermedia information systems.
HTTP2 logo
HTTP2
Binary protocol that brings push, multiplexing streams and frame control to the web.
Hystrix logo
Hystrix
Isolate points of access to remote systems, services, and third-party libraries.
IBM AIX logo
IBM AIX
Series of proprietary Unix operating systems developed and sold by IBM.
IBM App Connect Enterprise logo
Allows business information to flow between applications across multiple platforms.
IBM Bluemix logo
IBM Bluemix
Architecture diagram templates to create your own architectures using simple icons.
IBM CICS Transaction Gateway for z/OS logo
Trace your transactions end-to-end and understand the performance of your z/OS Transaction Gateways.
IBM CICS Transaction Server logo
Trace your transactions end-to-end and understand the performance of your CICS regions.
IBM Cloud logo
IBM Cloud
Set of cloud computing services for business offered by the information technology company IBM.
IBM Cloud Kubernetes Service (IKS) logo
Dynatrace provides AI powered observability for IBM Cloud Kubernetes Service pods, nodes, and clusters.
IBM DataPower logo
IBM DataPower
Enables the classification of data requests based on service and application-level information.
IBM DB2 logo
IBM DB2
Data management products, including database servers, developed by IBM.
IBM DB2 LUW logo
IBM DB2 LUW
Extend IBM DB2 for Linux, UNIX and Windows (LUW) monitoring capabilities with a deeper look into performance metrics.
IBM Event Streams logo
IBM Event Streams
Monitor the health of your IBM Event Streams cluster
IBM HTTP Server logo
IBM HTTP Server
Web server that runs on AIX, HP-UX, Linux, Solaris, JADE, Windows NT, IBM i and z/OS.
IBM i logo
IBM i
Versatile, Multi-Environment H2Servers for the Era of e-business on demand.
IBM IMS logo
IBM IMS
Trace your transactions end-to-end and understand the performance of your IMS regions.
IBM IMS SOAP Gateway logo
Trace your transactions end-to-end and understand the performance of your IMS SOAP Gateways.
IBM Informix logo
IBM Informix
Remotely monitor your Informix databases
IBM Integration Bus logo
IBM Integration Bus
IBM JVM  logo
IBM JVM
Platform-specific component that runs a Java program.
IBM MQ - ActiveGate logo
IBM MQ - ActiveGate
Enterprise-grade messaging capabilities that safely move information between applications.
IBM MQ - OneAgent logo
IBM MQ - OneAgent
IBM Watson Explorer Engine logo
Monitor issues in your Watson Explorer Engine collections
IBM WebSphere logo
IBM WebSphere
Application and integration middleware allowing end-users to create and integrate applications.
IBM WebSphere Application Server logo
Trace your transactions end-to-end and understand the health of your WebSphere Application Server instances.
IBM WebSphere Application Server for z/OS logo
Trace your transactions end-to-end and understand the performance of your WebSphere Application Server instances.
IBM WebSphere Liberty logo
Trace your transactions end-to-end and understand the health of your WebSphere Liberty instances.
IBM WebSphere Liberty for z/OS logo
Trace your transactions end-to-end and understand the performance of your WebSphere Liberty instances.
IBM WebSphere Message Broker logo
Allows information to flow between disparate applications across multiple platforms.
IBM WebSphere Portal logo
Enterprise software used to build and manage web portals.
IBM z/Linux logo
IBM z/Linux
Collective term for the Linux operating system compiled to run on IBM mainframes.
IBM z/Linux Java logo
IBM z/Linux Java
Monitor your entire stack with a single solution, and control the sprawl.
IBM z/OS logo
IBM z/OS
Understand the performance and availability of your LPARs.
IBM z/OS Connect Enterprise Edition logo
Trace your transactions end-to-end and understand the performance of your z/OS Connect instances.
ICEFaces logo
ICEFaces
Open-source Rich Internet Application (RIA) development framework for Java EE.
InterSystems IRIS (Remote) logo
InterSystems IRIS is a platform for rapidly developing and deploying important applications.
Ionic logo
Ionic
Monitor hybrid mobile apps built with the Ionic framework running on iOS or Android
iOS logo
iOS
Monitor mobile applications that are running on Apple's popular iOS operating system.
iOS Safari logo
iOS Safari
ISAM logo
ISAM
Collect metrics about IBM Security Access Manager (ISAM)
Istio logo
Istio
Open platform to connect, manage, and secure microservices.
Istio and Envoy Service Mesh (Prometheus) logo
Istio service mesh helps managing distributed microservices architectures, especially in Kubernetes.
Java logo
Java
The #1 programming language for IoT, enterprise architecture, and cloud.
Java JDBC logo
Java JDBC
Application programming interface for the Java, defines access to a database.
Java JMS logo
Java JMS
Java message-oriented middleware API for sending messages between two or more clients.
Javascript logo
Javascript
Programming language that conforms to the ECMAScript specification.
JBoss logo
JBoss
Delivers enterprise-grade security, performance, and scalability in any environment.
Jenkins logo
Jenkins
Open source server which enables developers to reliably build, test, and deploy their software.
Joomla logo
Joomla
Management system for publishing web content.
jQuery logo
jQuery
JavaScript library designed to simplify HTML DOM tree traversal and manipulation.
Juniper Networks logo
Juniper Networks
Networking & cybersecurity solutions to service providers, enterprise companies & public sector.
Jython logo
Jython
Implementation of the Python programming language designed to run on the Java platform.
Keptn logo
Keptn
Event-based control plane for continuous delivery and automated operations.
Kubernetes logo
Kubernetes
Open-source system for automating deployment, scaling, and management of containerized applications.
KVM logo
KVM
Virtualization module in the Linux kernel that allows the kernel to function as a hypervisor.
Laravel logo
Laravel
PHP web framework, intended for the development of web applications.
LDAP logo
LDAP
Vendor-neutral protocol for accessing and maintaining distributed directory information services.
LDAP Synthetic logo
LDAP Synthetic
Execute synthetic LDAP searches to monitor the availability of your LDAP servers
LinkerdD logo
LinkerdD
Observability, reliability, and security without requiring any code changes for Kubernetes.
Linkerd Service Mesh (Prometheus) logo
LInkerd service mesh provides runtime debugging, observability, reliability, and security with zero code changes.
Linux logo
Linux
Family of open source Unix-like operating systems based on the Linux kernel.
LoadRunner logo
LoadRunner
Load testing tool for project teams.
Logstash logo
Logstash
Stream your logs from Logstash to Dynatrace and analyze them.
Machine Learning on AWS logo
Robust, cloud-based service that makes it easy for developers of all skill levels to use machine learning technology.
soon
Magento logo
Magento
Deep insight into user experience, top landing & exit pages and bounce rates.
Maven logo
Maven
Muild automation tool used primarily for Java projects.
Memcached logo
Memcached
Distributed memory-caching system often used to speed up dynamic database-driven websites.
Micrometer logo
Micrometer
Automatically ingest Spring Application metrics and analyze them end-to-end in context of your trace, log and diagnostics data.
Microsoft Active Directory replication logo
Monitors the sync status of your Active Directory servers
Microsoft Azure logo
Microsoft Azure
Cloud computing service for building, testing, deploying, and managing applications and services.
Microsoft Biztalk logo
Microsoft Biztalk
Gather metrics from your Biztalk Server deployments
Microsoft Edge logo
Microsoft Edge
Real user monitoring - visibility and monitoring starting on you clients browser (desktop, tablet, mobile)
Microsoft Exchange Server logo
Mail server and calendaring server developed by Microsoft.
Extend the visibility of your Microsoft Exchange mail and calendar server running on Windows hosts to monitor health and improve performance
Microsoft Hyper-V logo
Microsoft Hyper-V
Native hypervisor that can create virtual machines on x86-64 systems running Windows.
Microsoft IIS logo
Microsoft IIS
Flexible, secure and manageable Web server for hosting anything on the Web for Windows® Server.
Microsoft Internet Explorer logo
Series of graphical web browsers.
Microsoft Message Queuing (MSMQ) logo
Gather metrics about your MSMQ queues
Microsoft SQL Server (MSSQL - local monitoring) logo
Database management system - store and retrieve data as requested by other software applications.
Microsoft SQL Server (MSSQL - remote monitoring) logo
Expand visibility to improve the health and performance monitoring of your Microsoft SQL Servers!
Microsoft Teams logo
Microsoft Teams
Hub for team collaboration in Microsoft 365 that integrates the people, content, and tools.
Microsoft Visual Studio logo
Integrated development environment from Microsoft.
MongoDB logo
MongoDB
Distributed database built for modern application developers and for the cloud era.
Mongo DB Atlas logo
Mongo DB Atlas
Monitoring of your SaaS installation of Mongo DB (Atlas)
MooTools logo
MooTools
Object-oriented JavaScript framework. Released under the free, open-source MIT License.
Mozilla Firefox logo
Mozilla Firefox
Free, open source web browser that uses the Gecko layout engine.
Mule (HTTP Listener) logo
Event source enabling you to set up an HTTP server and trigger flows when requests are received.
Mulesoft (Cloudhub) logo
Mulesoft (Cloudhub)
Gather metrics about your Workers and Applications running in Mulesoft Cloudhub
MySQL logo
MySQL
Open-source relational database management system.
MySQL (remote monitoring) logo
Expand visibility to improve the health and performance monitoring of your MySQL databases!
Nagios Integration logo
Nagios Integration
TempestTempest
Monitoring consolidation - eliminate event storms, reduce MTTR using Nagios hosts data and problems in Dynatrace leveraging Davis AI engine.
Neo4j logo
Neo4j
Extend observability with PurePath 4 by seamlessly integrating OpenTracing data for Java emitted by Neo4j graph database.
NeoLoad logo
NeoLoad
NeotysNeotys
Automated Load Testing tool enabling you to run Continuous Performance Testing.
.NET logo
.NET
Developer platform for building apps: web, mobile, desktop, gaming, IoT, cloud, and microservices.
NetApp OnTap (Remote) logo
Increase visibility into your NetApp OnTap clusters by remotely collecting key metrics and performance indicators for use in Dynatrace.
Netbackup Jobs logo
Netbackup Jobs
Monitor your Veritas Netbackup jobs execution status
.NET Core logo
.NET Core
Deep insights into the your .NET Core framework and optimize the overall performance.
Netflix OSS logo
Netflix OSS
Provides runtime containers, libraries and services that power microservices.
.NET Framework logo
.NET Framework
Software framework developed by Microsoft that runs primarily on Microsoft Windows.
.NET PCL logo
.NET PCL
Portable Class Libraries enalbes you to share code across various platform-specific projects.
.NET RabbitMQ logo
.NET RabbitMQ
Lightweight and easy to deploy queueing system on premises and in the cloud.
.NET Remoting logo
.NET Remoting
Application programming interface for interprocess communication.
.NET Standard logo
.NET Standard
Formal specification of .NET APIs that are intended to be available on all .NET implementations.
Netty logo
Netty
I/O client-server framework for the development of Java network applications.
.NET UWP logo
.NET UWP
Computing platform created by Microsoft and first introduced in Windows 10.
NGINX logo
NGINX
Accelerates application delivery, improves security, facilitates availability & scalability.
NGINX Plus logo
NGINX Plus
All‑in‑one load balancer, content cache, and web server.
Nobl9 SLO Platform logo
Nobl9 SLO Platform
Nobl9Nobl9
Nobl9 simplifies SLO usage with an integrated approach that enables SLI collection, SLO calculation, and error budget alerts.
Node.js logo
Node.js
JavaScript runtime built on Chrome's V8 JavaScript engine.
NTP sync check logo
NTP sync check
Network Time Protocol assures host clocks are in sync with a trusted time source
NVIDIA GPUs logo
NVIDIA GPUs
Monitor the utilization and temperature of your NVIDIA GPUs
OCSP Monitoring logo
OCSP Monitoring
Monitor your OCSP certificates and validate them against an OCSP Responder
OpenMetrics logo
OpenMetrics
Use OpenMetrics to ingest, store and analyze metrics at scale
soon
OpenShift Control Plane logo
Get deep insights into your OpenShift control plane using metrics exposed by various control plane components.
openSUSE logo
openSUSE
The openSUSE project is a community program sponsored by SUSE Linux and other companies.
OpenTelemetry Metrics logo
Easily ingest custom OpenTelemetry metrics, pin them to your dashboard, and set alerts to be notified about unexpected metric drops.
OpenTelemetry Tracing logo
Ensure end-to-end traceability for heterogeneous cloud-native environments with OpenTelemetry data seamlessly integrated into PurePath.
OpenTracing logo
OpenTracing
Dynatrace PurePath 4 seamlessly integrates OpenTracing data emitted by auto- and custom-instrumentation of Java source code.
early
Opera logo
Opera
Freeware web browser for Microsoft Windows, Android, iOS, macOS, and Linux operating systems.
Opsgenie logo
Opsgenie
Alerting and on-call management platform for operating always-on services.
Oracle ASM Disks logo
Oracle ASM Disks
Monitor the utilization of your Oracle ASM (Automatic Storage Management) disks
Oracle Cloud logo
Oracle Cloud
Cloud computing serviceproviding servers, storage, network, applications and services.
Oracle Database logo
Oracle Database
Database management system used for running online transaction processing and data warehousing.
Oracle Grid Control logo
Oracle Grid Control
Gather CPU, memory and filesystem metrics from Oracle GridControl
Oracle HTTP Server logo
Oracle HTTP Server
Web server component for Oracle Fusion Middleware.
Oracle Solaris logo
Oracle Solaris
Provides proven, enterprise-class security, reliability, and performance for SPARC and x86 systems.
Oracle WebLogic logo
Oracle WebLogic
Allows building enterprise applications using Java EE, and deploying them.
OutSystems Cloud Metrics logo
OutSystems is a leading low-code application platform. With this integration, their Cloud API data becomes available inside Dynatrace.
PagerDuty logo
PagerDuty
SaaS incident response platform for IT departments.
Palo Alto firewalls logo
Palo Alto firewalls
Monitor Palo Alto firewalls using SNMP to feed Dynatrace with metrics to allow alerting and Davis problem detection
Perl logo
Perl
Perl is a family of two high-level, general-purpose, interpreted, dynamic programming languages.
PHP logo
PHP
Popular general-purpose scripting language that is especially suited for web development.
PHP-FPM logo
PHP-FPM
FPM (FastCGI Process Manager) is an alternative PHP FastCGI implementation for heavy-loaded sites.
PHPUnit logo
PHPUnit
Unit testing framework for the PHP programming language.
Ping Every Second logo
Ping Every Second
Measure your network latency every second, understand the performance level and receive more details about network availability.
Pivotal Platform logo
Pivotal Platform
Multi-cloud platform for the deployment, management, and continuous delivery of applications. Pivotal is now VMware Tanzu.
Play Framework logo
Play Framework
Open-source web application framework which follows the model–view–controller architectural pattern.
PostgreSQL logo
PostgreSQL
Relational database management system emphasizing extensibility and SQL compliance.
Process connections logo
Process connections
Gather data about the number of connections and their state for any process
Prometheus logo
Prometheus
Collect metrics from Prometheus exporters in Kubernetes to analyze and alert on them with Dynatrace.
Prometheus Alertmanager logo
Integrate alerts from Prometheus Alertmanager into Dynatrace
prototype logo
prototype
Web JavaScript framework, implemented as a single file of JavaScript code.
Python logo
Python
Python is an interpreted, high-level, general-purpose programming language.
QEMU logo
QEMU
Open-source emulator that performs hardware virtualization.
RabbitMQ logo
RabbitMQ
RadiantOne Logic VDS logo
Monitor your RadiantOne Federated Identity and Directory Service clusters health
React.js logo
React.js
JavaScript library for building user interfaces.
React Native logo
React Native
Monitor mobile applications built with React Native running on iOS or Android.
Red Hat Enterprise Linux logo
Scale existing apps across bare-metal, virtual, container, and all types of cloud environments.
Red Hat OpenShift logo
Red Hat OpenShift
Consistent hybrid cloud foundation for building and scaling containerized applications.
Red Hat OpenStack logo
Red Hat OpenStack
Free open standard cloud computing platform, infrastructure-as-a-service in clouds.
Redis logo
Redis
Open source, in-memory data structure store, used as a database, cache and message broker.
Remote Windows host monitoring logo
Agent-less monitoring of your Windows hosts
restify logo
restify
Framework for building semantically correct RESTful web services ready for use at scale.
Riak logo
Riak
NoSQL data store that offers high availability, operational simplicity, and scalability.
Richfaces logo
Richfaces
Ajax-enabled component library for JavaServer Faces (open source).
Ruby logo
Ruby
Dynatrace monitors your Ruby applications and services on the process level.
Runtime vulnerability detection logo
Detect vulnerabilities in your environment in real-time, with full context and automated risk assessment.
Salesforce Streaming API logo
Activegate extension, uses Openkit to create user sessions based on Salesforce Event Stream events
Salt Stack logo
Salt Stack
Infrastructure automation software that is used to drive security and reliability.
SAP Business Technology Platform logo
SAP Business Technology Platform (SAP BTP) is the technological foundation for the intelligent enterprise
SAP Commerce Cloud logo
SAP Commerce Cloud
SAP Cloud Platform integrates data and business processes.
SAP GUI and ABAP platform logo
Automatic problem detection and visibility into every user transaction, and insight into the performance of RFC without changing any code.
SAP HANA Database logo
SAP HANA Database
Easily understand the health and performance of your SAP HANA databases!
SAP Hybris logo
SAP Hybris
Cloud based CRM (customer relationship management) Suite.
Scala logo
Scala
Programming language providing support for functional programming and a strong static type system.
SCOM logo
SCOM
Retrieve alerts and metrics from SCOM to augment Davis, the Dynatrace AI
Selenium WebDriver logo
Selenium WebDriver
Web automation framework that allows you to execute your tests against different browsers.
Sencha ExtJS logo
Sencha ExtJS
JavaScript application framework for building interactive cross platform web applications.
Sencha Touch logo
Sencha Touch
User interface JavaScript library, or web framework, specifically built for the Mobile Web.
ServiceNow logo
ServiceNow
IT service management for large corporations, including help desk functionality.
servicetrace logo
servicetrace
ServicetraceServicetrace
Monitor the performance of any application from an end user‘s perspective.
Siebel logo
Siebel
Gathers metrics from the Siebel SARM logs to provide aggregated task information
SIGNL4 – Critical Mobile Alerting logo
DerdackDerdack
For a 10x faster response to critical incidents.
Slack logo
Slack
Where the people you need, the information you share, and the tools you use come together.
SNMP Traps logo
SNMP Traps
Receive SNMP traps and create Dynatrace Problems from them.
SNMP Traps' statistics logo
Report single counter metric for all traps received on a listener, split by a trap type (OID)
soon
Snyk logo
Snyk
Snyk is integrated with Dynatrace to provide precise vulnerability matches, actionable descriptions, and detailed remediation guidance.
Solarwinds logo
Solarwinds
Monitor events and node performance
Spring logo
Spring
Application framework and inversion of control container for the Java platform.
SQL Server Always On logo
Gather metrics about your Always On availability groups, availability databases and replicas
StatsD logo
StatsD
The easiest way to get you custom application metrics into Dynatrace.
SUSE Linux logo
SUSE Linux
Distributed system and application software from other open source projects.
Suse Pacemaker logo
Suse Pacemaker
Monitor the health of your Suse Pacemaker clusters
Sybase ASE logo
Sybase ASE
Gathers performance and utilization metrics from Sybase ASE
Sybase IQ logo
Sybase IQ
Gathers performance and utilization metrics from Sybase IQ
Symfony logo
Symfony
PHP web application framework and a set of reusable PHP components/libraries.
Synthetic monitor database queries logo
Make sure that your databases always respond in a timely fashion by using a synthetic monitor.
Synthetic monitor DNS logo
Synthetically monitor your DNS servers to be proactively alerted when they go down.
Synthetic monitor Ping logo
Synthetically monitor your device availability using ping. This allows you to be proactively alerted when they are unavailable.
Synthetic monitor Ports logo
Synthetically monitor port availability on your servers. This allows you to be proactively alerted when they are unavailable.
Synthetic SFTP monitor logo
Monitor SFTP availability and performance.
TeamCity logo
TeamCity
Powerful continuous integration out of the box.
telegraf logo
telegraf
Automatically analyze and monitor hundreds of Telegraf provided plugins and metrics with Dynatrace
Tempest - Dynatrace for Jira logo
TempestTempest
Accelerate service operations and reduce MTTR using automated problems integration and Smartscape for CMDB synchronization into Jira
TIBCO ActiveMatrix BusinessWorks logo
Complete observability of applications and technologies across BusinessWorks processes.
TIBCO EMS logo
TIBCO EMS
Automatic monitoring for flawless Enterprise-grade Tibco EMS messaging system.
Timeseries Streamer logo
Timeseries Streamer
360performance360performance
Export any Dynatrace metric to external timeseries databases for advanced processing, analytics and visualization.
Trello logo
Trello
Easy, free, flexible, and visual way to manage your projects and organize anything.
T-Systems / Jenkins logo
T-Systems / Jenkins
T-SystemsT-Systems
Self-contained Java-based program, ready to run out-of-the-box.
tvOS logo
tvOS
Monitor mobile apps running on Apple TV.
Ubuntu logo
Ubuntu
Open-source, free Linux distribution based on Debian.
Varnish logo
Varnish
HTTP accelerator designed for content-heavy dynamic web sites as well as APIs.
Varnish Cache logo
Varnish Cache
VCenter Alarms logo
VCenter Alarms
Collect VCenter alerts into Dynatrace
vCenter Server logo
vCenter Server
Centralized management utility for VMware.
versio.io logo
versio.io
Versio.ioVersio.io
Change detection and processing platform for business and IT with real-time CMDB
Vert.x logo
Vert.x
Extend observability by seamlessly integrating OpenTracing data for Java emitted by the Vert.x web framework into PurePath 4.
VictorOps logo
VictorOps
Incident management platform that combines the power of people and data to embolden DevOps teams.
VMware logo
VMware
Virtualization solution to partion a single physical server into multiple virtual machines.
VMware Cloud on AWS logo
VMware Cloud on AWS
Integrated cloud offering jointly developed by Amazon Web Services (AWS) and VMware.
soon
VMware ESXi Host logo
VMware ESXi Host
Servers/data storage devices on which the ESX or ESXi hypervisor has been installed.
VMware Horizon logo
VMware Horizon
Gather metrics from your VMware Horizon gateways, connection servers, domains, farms, event databases and Remote Desktop Services (RDS)
VMware Tanzu logo
VMware Tanzu
Dynatrace & VMware Tanzu – accelerate adoption automatic, AI-powered; TAS, TKG, hybrid, multi-cloud, automated DevOps continuous CD.
VMware Unified Access Gateway logo
Gather connection metrics for your VMware UAG (Unified Access Gateway)
VMware vSAN logo
VMware vSAN
Gather metrics about your VMware vSAN datastores
WebHooks logo
WebHooks
Out-of-the-box integrations that automatically push problem notifications to third-party solutions.
Wildfly logo
Wildfly
Flexible, lightweight, managed application runtime that helps you build amazing applications.
Windows logo
Windows
Group of several proprietary graphical operating system families, developed by Microsoft.
Windows Communication Foundation (WCF) logo
Free and open-source runtime in the .NET Framework for building connected, service-oriented apps.
Windows Scheduled Task monitoring logo
Monitors completion of tasks on Windows Scheduler
Windows Server logo
Windows Server
Increase security, evolve your datacenter, and innovate faster with the cloud-ready OS.
Windows Server File System Quotas logo
Monitor the utilization of your File System Quotas in Windows Servers
WIPRO Holmes logo
WIPRO Holmes
WiproWipro
All your needs from building to monetization of heterogeneous AI solutions.
WordPress logo
WordPress
Content management system written in PHP and paired with a MySQL or MariaDB database.
WSO2 API Manager logo
WSO2 API Manager
A fully open-source, full lifecycle API Management solution.
Xamarin logo
Xamarin
Monitor mobile applications built with Microsofts's popular Xamarin platform running on iOS or Android.
Xcode logo
Xcode
Environment containing a suite for developing software for macOS, iOS, iPadOS, watchOS, and tvOS.
Xen logo
Xen
Type-1 hypervisor, allows computer operating systems to execute on the same hardware concurrently.
xMatters logo
xMatters
xMatters powers the world’s most reliable customer experiences.
Yii logo
Yii
Open source, object-oriented, component-based MVC PHP web application framework.
Zabbix hosts logo
Zabbix hosts
Bring events from your Zabbix Hosts into Dynatrace
Zabbix Integration logo
Zabbix Integration
TempestTempest
Monitoring consolidation - eliminate event storms, reduce MTTR using Zabbix hosts data and problems in Dynatrace leveraging Davis AI engine
Zenduty logo
Zenduty
YellowAntYellowAnt
Modern incident response with Dynatrace & Zenduty
ZigiOps - Integration Platform logo
ZigiWaveZigiWave
ZigiOps is a highly scalable no-code integration platform, which creates powerful integrations within minutes with security in mind.
ZK logo
ZK
Open-source Ajax Web application framework, written in Java.
