Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Custom database extensionCustom database extension
Execute generic database queries and ingest metrics and logs to Dynatrace.
Technology
Free trialDocumentation
Sample screenshot of existing Oracle monitoring extension
  • Product information
Overview
Custom, self-made Activegate extensions allow you to run queries against the following databases:
  • Oracle
  • Microsoft SQL Server
  • MySQL
  • IBM DB2
  • PostgreSQL
  • SAP HANA
  • Snowflake
  • coming soon: Sybase, MariaDB, MongoDB, Teradata, IBM Informix
The results can be sent back to Dynatrace as metrics and logs.
You can already start creating your own DB extensions - please refer to the "Get Started" section.
NOTE: Custom DB extensions will eventually replace the existing Custom Database Queries extension. If you need paid assistance on creating your own extension, please reach out to your customer success or account manager.
Use cases
Bring in business data, job processing metrics, database and table statistics, or anything that is stored in your Databases.
Example queries
  • SELECT COUNT(*) FROM DAILY_PROCESSED_JOBS
  • SELECT DEPARTMENT, EMPLOYEE_COUNT FROM DEPARTMENTS
Get started
Create an extension
  1. Follow the documentation to create your custom database extension.
  2. VS Code add-on will help you achieve that efficiently.
  3. Once you have the extension configured and customized, follow this guide to upload and run it in your environment.
Hands-on experience based on fully functional sample extension
Coming soon: you'll be able to use the attached fully functional sample to get started quickly and follow good practices. The sample extension will cover a simple scenario and will provide configuration of:
  • artificial business data ingestion,
  • dashboard and details screen visualization,
  • topology definition,
  • alerting rules,
  • and more.
Details
Compatibility information
Custom extension utilizes Dynatrace Extension Framework's SQL Data Source to connect to the different databases. Please refer to the documentation regarding supported database versions.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
