Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Zabbix IntegrationZabbix Integration
Zabbix Integration
Zabbix Integration
Eliminate event storms using Zabbix hosts data and problems in Dynatrace.
Technology by Alanata
Documentation
  • Product information
Overview
Consolidate and integrate your monitoring tools. Alanata Zabbix Integration enables you to connect existing Zabbix monitoring into Dynatrace. Enrich Dynatrace topology model with Zabbix hosts, ingest Zabbix problems, and let Davis AI engine process the problems together with native Dynatrace events in an integrated AIOps solution. With this extension, you can use Dynatrace as a unifying platform for data from external monitoring solutions, eliminate event storms, and minimize the effort spent on the investigation.
Details
Key Features
  • Synchronization of host data from Zabbix
    • Zabbix hosts and Zabbix host groups synchronized to Dynatrace entities.
    • Zabbix hosts information to Dynatrace custom entity properties, including Zabbix host IP and inventory (configurable)
    • Optional host IP interface discovery
  • Synchronization of problem data from Zabbix
    • Including additional data such as acknowledge information, severity changes
    • Mapping Zabbix problems to existing Dynatrace entities
  • Filtering
    • Filtering on Zabbix host groups
  • Context information
    • Dynatrace entity/problem properties contain URLs to link entities and problems in Dynatrace with Zabbix hosts and problems
  • Problem metric
    • Metric showing problem count in Zabbix for each Zabbix host (optional)
  • Custom topology
    • Zabbix server, Zabbix host group and Zabbix host entities in Dynatrace are created by the Zabbix ActiveGate extension
  • Dashboard
    • Zabbix Overview dashboard shows status of monitored Zabbix endpoints
Alanata logo
Alanata
Documentation
By the partner
Request support
Bring your own license
Copy to clipboard
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
