Endless Loop in JavaScript makes Masters.com site unresponsive – How to spot the problem in a minute
Golfers follow the Masters 2011 – but – if you try to access masters.com right now you will get annoying popup messages from your browser telling you that you better stop JavaScript from executing because it takes too long. On my browser this looks like this:
JavaScript makes your browser unresponsive when browsing masters.com
This happens on every page. So – why does that happen?
Endless JavaScript is the problem
I used Dynatrace on both Internet Explorer and Firefox to diagnose this problem. The problem was really easy to spot. Here is the timeline showing me in which JavaScript handler the problem actually happens:
Problem is in the onload event handler triggered by jQuery
Double clicking on it brings me to the problematic method – getArraySample that gets called from setChildrenLayout with an empty array:
Passing an empty array but length with value 6 causes the while loop to never end
The problem can be fixed easily by checking the array. I hope this little analysis and recommendation will find the right people to fix this fast – because – Golfers want to see how their players are doing.
Andreas Grabner has 20+ years of experience as a software developer, tester and architect and is an advocate for high-performing cloud scale applications. He is a regular contributor to the DevOps community, a frequent speaker at technology conferences and regularly publishes articles on blog.dynatrace.com. You can follow him on Twitter: @grabnerandi
