Header background
The rise of agentic AI part 5: Developing and monitoring multi-agent applications with OpenAI Agents SDK on Azure AI Foundry
As agentic AI applications gain ground, the trick becomes how to build multi-agent systems quickly with all the connective tissue built in. In this fifth installment of our series, The Rise of Agentic AI, we explain how to build a simple agentic application using the OpenAI Agents SDK and instrument the data with Dynatrace.
Recently, OpenAI released a customer service agents demo built using the OpenAI Agents Python SDK that showcases an example multi-agent system at work. With the OpenAI Agents SDK, you can build agentic AI applications with the help of agents, handoffs, guardrails, tools (built-in and custom), and built-in tracing. These capabilities support the core pattern of knowledge, reasoning, and actioning as the foundation for scalable and trustworthy automation, first introduced by Dynatrace CTO Bernd Greifeneder.
In this blog post, we explain how to build an OpenAI agents SDK-based agentic application and instrument the agents and app with AI-powered observability from Dynatrace. Dynatrace can help you see agent executions, tool usages, and prompt flows from initial request to final response for quick root cause analysis and troubleshooting.
To illustrate the capabilities of the OpenAI Agents SDK and agent framework with Azure OpenAI on Azure AI Foundry, we have built our multi-agent solution using the OpenAI customer service agents demo mentioned above as a reference and modified it for our use cases.
About our sample agentic AI application
Our multi-agent system enables users to research, summarize and translate across a range of topics and content. The system consists of four agents:
  • Welcome Agent: Engages the user, reasons with Azure OpenAI to analyze the prompt, identifies the intent, and passes it to the right agent to start processing.
  • Researcher Agent: Searches the web and analyzes the results using OpenAI.
  • Summarizer Agent: Summarizes content, including search results, text, PDF, CSV, and more, using Anthropic Claude.
  • Translator agent: Translates queries and inputs into any user-requested language using OpenAI.
OpenAI Agent SDK sample app architecture
Figure 1: Azure OpenAI Agent SDK setup for demo application in Github
Next, we want the multi-agent system to perform two distinct scenarios:
  1. Context history: In a specified chat session, the entire chat history and context is available for the duration of the session, while the individual prompts might be handed off to different agents for processing.
  2. Composite queries: The app orchestrates multiple different agents for different purposes, such as Research, Translate, Summary, and Welcome, so users can engage to process a composite prompt with multiple sub-queries.
Understanding multi-agent frameworks and handoff workflows
There are some key differences between the agent frameworks. Unlike the A2A protocol, the OpenAI framework does not explicitly have a central registry for agents. Instead, OpenAI agents use the concept of “handoffs” orchestrated by the OpenAI Agent Framework.
OpenAI framework agent handoffs
While orchestrator-led coordination offers a more deterministic and structured workflow, agent-to-agent handoffs provide significant advantages in adaptability and modularity. These handoffs enable agents to collaborate dynamically, making it possible to handle complex, multi-step queries with greater flexibility. This approach focuses on a more decentralized and scalable system, allowing agents to specialize and respond to changing requirements in real-time.
Here are two example scenarios to illustrate the agent-to-agent collaboration in chat sessions, with context, as well as delivering multi-agent query processing.
Show the user prompts for a composite query and multi-agent workflow
For example: “Research Michael Jordan, then summarize in 40 words or less, and then translate to French.”
Welcome Agent user prompt and composite query for the sample agentic AI application
Figure 2: User prompt -> Welcome Agent -> Identifies as multi-step workflow -> Handoff -> Researcher
Researcher Agent, Handoff, and Summarizer activities of the multi-agent workflow
Figure 3: Researcher Agent processes -> Handoff -> Summarizer
Handoff to Translator agent in multi-agent workflow
Figure 4: Summarizer -> Summary -> Handoff to Translator -> Summary results in French
Additional user input triggering translator, researcher, and response in the sample agentic AI application
Figure 5: User chat continues with Context and History -> Translator handoff -> Researcher -> Response
Researcher agent handing off to the translator for translation to Hindi
Figure 6: Researcher -> Handoff -> Translator to translate results to Hindi, keeping context and history
Multi-agent processing for CSV files uploaded
This example includes sample customer data to showcase multi-agent workflow processes with context and history in the chat session.
customer-uploaded CSV file and multi-agent triggers in the sample agentic AI application
Figure 7: Customer Data CSV -> Summarize file -> Welcome Agent -> Handoff -> Summarizer
Countries listed in the CSV file of the sample agentic AI application
Figure 8: “What Countries are listed in the file” -> Summarizer Handoff -> Researcher -> results
Research on the first country in summary
Figure 9: “Research on the 1st country in summary” -> uses context, history -> Researcher -> Results
Overall, the agent-to-agent handoffs worked well (and with context) during all the session runs. Tracing and debugging can be achieved by instrumenting the SDK with OpenTelemetry and sending the data to Dynatrace’s built-in AI Observability solution for Azure OpenAI. You can easily capture the multi-agent workflow for a given prompt on the Azure AI Foundry platform dashboard. Find the code examples in our GitHub repository.
Set up tracing using Python
Using Python, you can set up the tracing by changing a few simple lines of code in your agent framework and core component:
from traceloop.sdk import Traceloop Traceloop.init( app_name="openai-cs-agents", api_endpoint="https://wkf10640.live.dynatrace.com/api/v2/otlp", disable_batch=True, headers=headers, should_enrich_metrics=True, )
with tracer.start_as_current_span(name="update_seat", kind=trace.SpanKind.INTERNAL) as span:
    context.context.confirmation_number = confirmation_number
    context.context.seat_number = new_seat
    assert context.context.flight_number is not None, "Flight number is required"
    return f"Updated seat to {new_seat} for confirmation number {confirmation_number}"
You can see the results right away in distributed tracing:
Results of the OpenAI chat
Figure 10: Multi-agent workflow trace view in Distributed Tracing
Reviewing all OpenAI consumption statistics with Dynatrace AI Observability
Figure 11: How to review all your OpenAI consumption on Dynatrace with AI Observability
OpenAI orchestration
Within the OpenAI framework, there are two approaches to orchestrating agents:
  1. Allow the LLM to make decisions: Use the intelligence of an LLM to plan, reason, and decide what steps to take.
  2. Orchestrate with code: Use code to determine the flow of agents.
Overall, the OpenAI Agents SDK is comprehensive and easy to get running with some minor code changes, this time with OpenAI’s Codex assistant.
OpenAI Agents SDK Codex assistant code example
Figure 12: Codex example
Multiple frameworks and toolkits are quickly ramping up to make multi-agent systems a reality. We foresee this space evolving and innovating rapidly.
The evolution of multi-agent systems
As agentic AI continues to advance, multi-agent applications are poised to play a transformative role in reshaping how applications operate. These systems enable dynamic, context-aware collaboration between specialized agents, empowering businesses to tackle increasingly complex workflows. From helping with automation, orchestrating large-scale data analysis, multi-agent systems will unlock new levels of efficiency, scalability, and innovation.
Tools like the OpenAI Agents SDK on Azure AI Foundry and Azure AI Studio are at the forefront of this evolution. By providing built-in capabilities such as agent handoffs, guardrails, and tracing, the SDK simplifies the development and monitoring of multi-agent workflows. These features make it easier for organizations to deploy responsible, secure, and robust AI systems and also ensure transparency and trustworthiness in their operations. These are key factors for widespread adoption.
Looking ahead, we can expect rapid innovation in this space. Emerging standards like MCP, A2A protocols, and frameworks such as OpenAI Agents are creating a vibrant ecosystem for multi-agent interoperability. The focus will likely shift toward even more intelligent and reliable orchestration, where agents autonomously plan, reason, and adapt to dynamic environments.
AI Observability for agentic AI applications
To keep pace with these advancements, we believe that observability must evolve in lockstep to ensure transparency across heterogeneous agent ecosystems. Advancements in observability tools, such as the Dynatrace AI Observability solution, are essential to help create more reliable and scalable AI frameworks at the enterprise level.
The future of multi-agent systems holds immense potential, with the OpenAI SDK marking the starting point. We’re just at the beginning of what’s possible. As this technology evolves, it will gradually become more stable and reliable, ultimately transforming the way we approach automation, collaboration, and AI-powered problem-solving across industries.
Check out our GitHub repo for detailed code examples for OpenAI Agents, AWS Strands, Google ADK, and start building your own AI Observability solutions today.
Read more
  • Part one of the Rise of Agentic AI blog series covers the fundamentals of AI agents, models, and emerging communication standards such as Agent2Agent (A2A) and MCP.
  • Part two explores how monitoring A2A and MCP communications results in better, more effective agentic AI. This blog post covers AI agent observability and monitoring, and how to scale and monitor Amazon Bedrock Agents.
  • Part three explains how to monitor Amazon Bedrock Agents and how observability optimizes AI agents at scale.
  • Part four covers full-stack observability for AI with NVIDIA Blackwell and NVIDIA NIM.
  • Part six explores AI Model Versioning and A/B testing for smarter LLM services.
  • Part seven introduces data governance and audit trails for AI services.
Together, these capabilities make it possible to achieve robust, scalable observability in agentic AI environments so teams can build reliable and trustworthy applications and services.
