Monitor HAProxy Load balancer using prometheus to feed Dynatrace with metrics.
The HAProxy (Prometheus) uses Prometheus to collect data remotely. Every minute, data is collected from HAProxy devices and is continuously analyzed by the Dynatrace platforms. The new framework allows you to go beyond simple metrics and apply a topology-first approach to monitoring.
This is intended for users, who:
Would like to monitor the performance of an edge proxy or ingress proxy
Focus on Kubernetes calls for supporting the most popular services of this kind in Kubernetes.
This enables you to:
Monitor infrastructure with a comprehensive dashboard
Use Prometheus as the data source
Take pre-emptive measures to avoid service degradations
Compatibility Requirements
HAProxy devices using Prometheus exporter
Simply activate the extension in your environment using in-product Hub, provide the required device configuration and you’re all set up.
Read more in the Prometheus Extension Documentation
Metrics collected:
The extension package contains:
This extension is built on top of the new Extension 2.0 Framework
More information can be found in the Product News Blog: https://www.dynatrace.com/news/blog/new-snmp-platform-extensions-provide-observability-at-scale-for-network-devices/
