Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Node.jsNode.js
Node.js
Node.js
Automatic and intelligent end-to-end observability for Node.js applications.
Technology
Free trialDocumentation
  • Product information
Overview
Deploy APM in seconds with fully automatic instrumentation of your applications as well as third-party applications written in Node.js. With a single click, monitor the health of your distributed applications across every tier in a frontend application down to every database statement. Reduce mean-time-to-repair (MTTR) and proactively optimize the performance of your applications. Dynatrace automatically analyzes Node.js. applications, detects and diagnoses problems in real-time thanks to our proprietary AI engine, and pinpoints the root cause down to code-level before your customers are even affected.
Use cases
  • Automatic end-to-end distributed tracing from frontend apps to databases.
  • Insight into remote services such as databases and queues.
  • See logs in context of your traces and workloads.
  • Always-on, 24/7, production-grade CPU and memory profiling
  • Deep code-level visibility to troubleshoot issues, down to a single line of code.
  • Analyze resource contention issues with memory, thread, and other process metrics.
  • Capture memory dumps for advanced troubleshooting
Get started
If your Node.js is running on a virtual machine directly, install OneAgent on that virtual machine to get started.
If your Node.js is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your Node.js is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Customer story USI
“Dynatrace has become my best friend as a developer. I can identify the root-cause of issues and quickly work out which team I need to solve the problem.”
Wendy Mathis
Software Lead Architect, USI Insurance Services
USI logo
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
