1 technologies
Filters
Observability provided by
Cloud integrations
Top Filters
Extensibility provided by
Software Intelligence Hub
A curated catalog of supported technologies, integrations and extensions provided by Dynatrace and trusted partners.
Showing 1 of 633 technologies
servicetrace logo
servicetrace
ServicetraceServicetrace
Monitor the performance of any application from an end user‘s perspective.
OneAgent logo
OneAgent
All the operational and business performance metrics you need.
Active Directory services logo
Monitor the health and improve the performance of Microsoft Active Directory services.
ActiveGate logo
ActiveGate
Route traffic, monitor cloud environments, monitor remote technologies with extensions and run synthetic monitors.
ActiveMQ logo
ActiveMQ
Automatic and intelligent observability for ActiveMQ with end-to-end traces of connected producers and consumers.
ActiveMQ Artemis logo
ActiveMQ Artemis
Automatic and intelligent observability for ActiveMQ Artemis with end-to-end traces of connected producers and consumers.
Adobe Analytics logo
Adobe Analytics
Get real-time answers for business anomalies with shared business context from Adobe Analytics
Adobe PhoneGap logo
Adobe PhoneGap
Monitor hybrid mobile apps built with Adobe PhoneGap running on iOS or Android
ADO.NET logo
ADO.NET
Solve ADO.NET performance problems at code level.
aDSS avodaq Data Snapshot Service logo
avodaq AGavodaq AG
Easily export and retain real user (including session replay) and performance data to address business and technical reporting requirements.
Advanced SSL Certificate Check for Dynatrace logo
360performance360performance
Perform extended SSL certificate checks and integrate seamlessly with your existing synthetic monitors.
Akamas logo
Akamas
AkamasAkamas
Akamas AI enables enterprises and online businesses to maximize service quality, resilience and cost savings.
Akamas for Cloud Automation logo
AkamasAkamas
Integrate Akamas with Cloud Automation to automatically optimize applications in terms of performance, resilience, and cost efficiency
Akka logo
Akka
Automatically and intelligently monitor, analyze, and optimize your applications developed with Akka.
Amazon API Gateway logo
Amazon API Gateway
Service for developers to create, publish, maintain, monitor, and secure APIs.
Amazon AppStream 2.0 logo
Fully managed application streaming service that provides users with instant access to their desktop applications from anywhere.
Amazon Athena logo
Amazon Athena
Interactive query service that makes it easy to analyze data directly in Amazon S3 using standard SQL.
Amazon Aurora logo
Amazon Aurora
Relational database service developed and offered by Amazon Web Services.
Amazon CloudFront logo
Amazon CloudFront
Content delivery network offered by Amazon Web Services.
Amazon CloudSearch logo
Amazon CloudSearch
Set up, manage, and scale a search solution for your website or application using CloudSearch.
Amazon Cloudwatch logo
Amazon Cloudwatch
Monitoring service for AWS cloud resources and the applications you run on AWS.
Amazon CloudWatch Logs logo
Monitor, store, and access your log files from instances, AWS CloudTrail, Route 53, and other sources.
Amazon Cognito logo
Amazon Cognito
Add user sign-up, sign-in, and access control to your web and mobile apps quickly and easily.
Amazon Connect logo
Amazon Connect
Easy to use omnichannel cloud contact center that helps you to provide superior customer service at a lower cost.
Amazon Corretto logo
Amazon Corretto
Automatically and intelligently monitor, analyze, and optimize the performance of your virtual machine.
Amazon DocumentDB logo
Amazon DocumentDB
Amazon DocumentDB (with MongoDB compatibility) is a fast, reliable, and fully managed database service.
Amazon DynamoDB logo
Amazon DynamoDB
Fully managed NoSQL database service that supports key-value and document data structures.
Amazon DynamoDB Accelerator (DAX) logo
Fully managed, highly available, in-memory cache for your Amazon DynamoDB.
Amazon EC2 logo
Amazon EC2
Web service that provides secure, resizable compute capacity in the cloud.
Amazon EC2 Auto Scaling logo
Amazon EC2 Auto Scaling helps you ensure that you have the correct number of Amazon EC2 instances available.
Amazon EC2 Spot Fleet logo
Spot Instances and On-Demand Instances to meet the target capacity that you specified.
Amazon ElastiCache logo
Amazon ElastiCache
Fully managed in-memory data store and cache service by Amazon Web Services.
Amazon Elastic Block Store (EBS) logo
Raw block-level storage that can be attached to Amazon EC2 instances.
Amazon Elastic Container Service (ECS) logo
Fully managed container orchestration service.
Amazon Elastic File Service (EFS) logo
Cloud storage service provided by Amazon Web Services.
Amazon Elastic Inference logo
Accelerate deep learning inference workloads by attaching to your Amazon EC2 CPU instances.
Amazon Elastic Kubernetes Service (EKS) logo
Harness automation and AI to simplify Kubernetes observability at scale.
Amazon Elasticsearch Service logo
Fully managed service to deploy, secure, and run Elasticsearch cost effectively at scale, without the operational overhead.
Amazon Elastic Transcoder logo
Convert and transcode media files stored in Amazon S3.
Amazon EMR logo
Amazon EMR
Cloud big data platform for processing vast amounts of data using open source tools.
Amazon EventBridge logo
Amazon EventBridge
Serverless event bus to connect applications together using data from your own applications, integrated SaaS applications, and AWS services.
Amazon FSx for Lustre logo
Makes it easy and cost-effective to launch and run the popular, high-performance Lustre file system.
Amazon FSx for Windows File Server logo
Provides a managed Microsoft Windows file servers, backed by a native Windows file system.
Amazon GameLift logo
Amazon GameLift
Enables developers to deploy, operate, and scale dedicated, low-cost servers in the cloud for session-based, multiplayer games.
Amazon Inspector logo
Amazon Inspector
Tests the network accessibility of your EC2 instances and the security state of your applications that run on those instances.
Amazon Keyspaces for Apache Cassandra logo
Scalable, highly available, and managed Apache Cassandra–compatible database service.
Amazon Kinesis Data Analytics logo
Transform and analyze streaming data in real time with open source framework and engine for processing data streams (Apache Flink).
Amazon Kinesis Data Firehose logo
Fully managed service for delivering real-time streaming data.
Amazon Kinesis Data Streams logo
Collect log and event data from sources such as servers, desktops, and mobile devices.
Amazon Kinesis Video Streams logo
Provides you SDKs to install on your devices to make it easy to stream media.
Amazon Lex logo
Amazon Lex
Service for building conversational interfaces for applications using voice and text.
Amazon Linux 2 logo
Amazon Linux 2
Automatic insights of your Amazon Linux 2 CPU, memory, and network health metrics all the way down to the process level.
Amazon Managed Service for Prometheus logo
Ingest metrics from Amazon Managed Prometheus to Dynatrace.
Amazon MSK logo
Amazon MSK
Fully managed service that enables you to build and run applications that use Apache Kafka to process streaming data.
Amazon Neptune logo
Amazon Neptune
Fast, reliable, fully managed graph database built for highly connected datasets.
Amazon Polly logo
Amazon Polly
Cloud service that converts text into lifelike speech.
Amazon Quantum Ledger Database (QLDB) logo
Ledger by a central trusted authority that provides an immutable, and cryptographically verifiable transaction log.
Amazon Redshift logo
Amazon Redshift
Data warehouse product which forms part of the larger cloud-computing platform AWS.
Amazon Rekognition logo
Amazon Rekognition
Amazon Rekognition makes it easy to add image and video analysis to your applications.
Amazon Relational Database Service (RDS) logo
Cloud web service designed to simplify the setup, operation, and scaling of a relational database.
Amazon Route 53 logo
Amazon Route 53
Effectively connects user requests to infrastructure running in AWS.
Amazon S3 logo
Amazon S3
Provides object storage through a web service interface.
Amazon SageMaker logo
Amazon SageMaker
Build, train, and deploy machine learning (ML) models quickly.
Amazon Simple Email Service (SES) logo
Cloud-based service that helps developers send marketing, notification, and transactional emails.
Amazon Simple Notification Service (SNS) logo
Provides a simple web services interface that can be used to create topics you want to notify apps.
Amazon Simple Queue Service (SQS) logo
Programmatic sending of messages via web service applications.
Amazon Simple Workflow Service (SWF) logo
Makes it easy to build applications that coordinate work across distributed components.
Amazon Textract logo
Amazon Textract
Makes it easy to add document text detection and analysis to your applications.
Amazon Transfer Family logo
Provides fully managed support for file transfers directly into and out of Amazon S3 using SFTP, FTPS, and FTP
Amazon Translate logo
Amazon Translate
Text translation service using machine learning to provide high-quality translation on demand.
Amazon VPC (NAT Gateway) logo
Connect to the Internet from instances within a private subnet in an AWS Virtual Private Cloud.
Amazon WorkMail logo
Amazon WorkMail
Secure, managed business email and calendaring service with support for existing desktop and mobile email clients.
Amazon WorkSpaces logo
Amazon WorkSpaces
Enables you to provision virtual, cloud-based Microsoft Windows or Amazon Linux desktops, known as WorkSpaces.
Amazon MQ logo
Amazon MQ
Managed message broker service for Apache ActiveMQ that makes it easy to migrate to a message broker in the cloud.
aMC Synthetic App logo
aMC Synthetic App
amasol AGamasol AG
Always stay up to date with your Synthetic Monitors from Dynatrace SaaS/Managed and receive push notifications for alerts
AMP logo
AMP
Accelerated Mobile Pages performance monitoring to ensure perfect user experience.
Android logo
Android
Monitor mobile applications that are running on the popular Android operating system.
Android Webkit logo
Android Webkit
Provides tools for browsing the web.
Angular logo
Angular
Platform for building mobile and desktop web applications.
AngularJS logo
AngularJS
JavaScript-based open-source front-end web framework mainly maintained by Google.
Ansible logo
Ansible
The simplest way to automate apps and IT infrastructure.
Ansible Tower logo
Ansible Tower
Way to automate apps and IT infrastructure.
Apache Axis2 logo
Apache Axis2
Core engine for Web services.
Apache Camel logo
Apache Camel
Intelligently monitor, analyze, and optimize your integration framework and all applications deployed in your stack.
Apache Cassandra
Automatically and intelligently observe, analyze and optimize how your the usage, health and performance of your database.
Apache Cassandra (Remote) logo
Remotely gain insights into your Cassandra cluster health and performance.
Apache Cordova logo
Apache Cordova
Monitor hybrid mobile apps built with Cordova running on iOS or Android
Apache CouchDB logo
Apache CouchDB
Apache CXF logo
Apache CXF
Open-source, fully featured Web services framework.
Apache HTTP Server logo
Apache HTTP Server
Develop and maintain an open-source HTTP server.
Apache JMeter logo
Apache JMeter
Build management and continuous integration server from JetBrains.
Apache Kafka logo
Apache Kafka
Automatic and intelligent observability for Apache Kafka with end-to-end traces of connected producers and consumers.
Apache OpenEJB logo
Apache OpenEJB
Automatically and intelligently monitor, analyze and optimize your applications based on Apache OpenEJB
Apache Solr logo
Apache Solr
Open-source enterprise-search platform, written in Java, from the Apache Lucene project.
Apache Spark logo
Apache Spark
Distributed general-purpose cluster-computing framework for programming entire clusters.
Apache Storm logo
Apache Storm
ActiveGate extension for monitoring the free and open source distributed realtime computation system Apache Storm.
Apache Tomcat logo
Apache Tomcat
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Apache TomEE logo
Apache TomEE
Apigee Edge logo
Apigee Edge
Design, secure, and analyze APIs across the entire API lifecycle.
Apple Safari logo
Apple Safari
Graphical web browser developed by Apple, based on the WebKit engine.
ASP.NET / ASP.NET Core logo
Automatically and intelligently monitor, analyze and optimize your ASP.NET / ASP.NET Core apps.
ASP.NET Owin/Katana logo
ASP.NET Owin/Katana
Automatically and intelligently monitor, analyze, and optimize your applications developed with ASP.NET Owin/Katana.
Atlassian Bamboo logo
Atlassian Bamboo
Continuous integration and continuous deployment server developed by Atlassian.
Atlassian JIRA logo
Atlassian JIRA
Issue tracking product that allows bug tracking and agile project management.
AWS logo
AWS
Reliable, scalable, and inexpensive cloud computing services with pay-as-you-go pricing approach.
AWS AppSync logo
AWS AppSync
Enterprise-level, fully managed GraphQL service with real-time data synchronization and offline programming features.
AWS Billing and Cost Management logo
The service that you use to pay your AWS bill, monitor usage, and analyze and control costs.
AWS Chatbot logo
AWS Chatbot
Enables DevOps to use Amazon Chime and Slack chat rooms to monitor and respond to events.
AWS CloudHSM logo
AWS CloudHSM
Hardware security modules (HSM) in the AWS Cloud.
AWS CodeDeploy logo
AWS CodeDeploy
Fully managed service that automates software deployments to a variety of compute services.
AWS CodePipeline logo
AWS CodePipeline
Continuous delivery service automating release pipelines for application and infrastructure updates.
AWS Database Migration Service logo
Makes it easy to migrate relational databases, and other types of data stores.
AWS DataSync logo
AWS DataSync
Transfer service designed to simplify and automate copying large amounts of data to and from AWS services.
AWS Direct Connect logo
AWS Direct Connect
Links your internal network to an AWS Direct Connect location over a standard Ethernet fiber-optic cable.
AWS Elastic Beanstalk logo
Quickly deploy and manage applications in the AWS Cloud without having to learn about the infrastructure beneath.
AWS Elastic Load Balancing logo
Automatically distributes incoming application traffic across multiple targets.
AWS Elemental MediaConnect logo
Service that makes it easy for broadcasters and other premium video providers to reliably ingest live video into the AWS Cloud.
AWS Elemental MediaConvert logo
File-based video processing service that provides scalable video processing for content owners and distributors.
AWS Elemental MediaPackage logo
Just-in-time video packaging and origination service that runs in the AWS Cloud.
AWS Elemental MediaTailor logo
Scalable ad insertion service that runs in the AWS Cloud.
AWS Fargate logo
AWS Fargate
Intelligent end-to-end observability for serverless and hybrid environments using AWS Fargate
AWS Glue logo
AWS Glue
Fully managed extract, transform, and load (ETL) service.
AWS IoT logo
AWS IoT
Run local compute, messaging, data caching, and machine learning inference capabilities.
AWS IoT Analytics logo
AWS IoT Analytics
Automates the steps required to analyze data from IoT devices.
AWS IoT Things Graph logo
Orchestration service that simplifies development of IoT applications.
AWS Lambda logo
AWS Lambda
Automatic and intelligent end-to-end observability for AWS Lambda traces.
AWS OpsWorks logo
AWS OpsWorks
Configuration management service that helps you configure and operate applications by using Puppet or Chef.
AWS Outposts logo
AWS Outposts
Fully managed service that extends AWS infrastructure, AWS services, APIs, and much more.
AWS PrivateLink logo
AWS PrivateLink
Provides private connectivity between VPCs, AWS services, and on-premises applications.
AWS RoboMaker logo
AWS RoboMaker
Service that makes it easy to create robotics applications at scale.
AWS Service Catalog logo
AWS Service Catalog
Enables organizations to create and manage catalogs of IT services that are approved for use on AWS.
AWS Site-to-Site VPN logo
Allows connecting and routing from your VPC to your remote network.
AWS Step Functions logo
AWS Step Functions
Enables you to coordinate the components of distributed applications and microservices using visual workflows.
AWS Storage Gateway logo
AWS Storage Gateway
Connects an on-premises software appliance with cloud-based storage to provide data security.
AWS Systems Manager logo
AWS Systems Manager
View and control your infrastructure on AWS using Systems Manager.
AWS Transit Gateway logo
AWS Transit Gateway
Network transit hub interconnecting virtual private clouds (VPC) and on-premises networks.
AWS Trusted Advisor logo
AWS Trusted Advisor
Identifies ways to reduce cost, increase performance, and improve security for your AWS account.
AWS Web Application Firewall (WAF) logo
Web application firewall that lets you monitor the HTTP(S) requests.
Azul Platform Core (Zulu) logo
Azul Platform Prime (Zing) logo
Azure Analysis Services logo
Fully managed platform as a service (PaaS) that provides enterprise-grade data models in the cloud.
Azure Anomaly Detector logo
Detects anomalies in time series data with numerical values that are uniformly spaced in time.
Azure API Management logo
Create consistent and modern API gateways for existing back-end services.
Azure App Configuration logo
Service to provide centrally managed application settings and feature flags.
Azure Application Gateway logo
Web traffic load balancer that enables you to manage traffic to your web applications.
Azure Application Insights logo
An extensible Application Performance Management (APM) service for developers and DevOps.
Azure App Service logo
Azure App Service
Intelligent end-to-end observability for serverless and hybrid environments using Azure App Services.
Azure Automation account logo
Allows you to automate your Azure management tasks and to orchestrate actions across external systems from right within Azure.
Azure Batch logo
Azure Batch
Get complete picture of jobs, tasks and node tracking, in each state, for operational efficiency.
Azure Bing Autosuggest logo
Helps users complete queries faster by adding intelligent type-ahead capabilities to your app or website.
Azure Bing Custom Search logo
An easy-to-use, ad-free, commercial-grade search tool that lets you deliver the results you want.
Azure Bing Entity Search logo
Bring rich context data to your apps through entity information for a more engaging experience.
Azure Bing Search logo
Azure Bing Search
Build apps and services that find webpages, images, news, locations, and more.
Azure Bing Spell Check logo
Correct spelling and word breaks errors, recognize slang, names, homonyms, brands and more.
Azure Blob Storage logo
Azure Blob Storage
Handles stored objects, with millions of requests per second, for customers around the world.
Azure Blockchain logo
Azure Blockchain
Fully managed ledger service that enables users the ability to grow and operate blockchain networks at scale in Azure.
Azure Cache for Redis logo
Industry-standard SSL to secure your data in transit and Azure Storage disk encryption at rest.
Azure CDN profiles logo
Azure CDN profiles
Collections of CDN endpoints and each CDN profile contains one or more CDN endpoints.
Azure Cloud Services (Classic) logo
Deploy web apps (web roles) and background services (worker roles) onto Azure virtual machines.
Azure CloudSimple Virtual Machines logo
Manage VMware virtual machines (VMs) from the Azure portal.
Azure Cognitive Services logo
Bring AI within reach of every developer—without requiring machine-learning expertise.
Azure Computer Vision logo
AI service to boost content discoverability, automate text extraction, analyze video in real time, and more.
Azure Connections logo
Azure Connections
This tool is designed to meet and accomplish your hybrid identity goals.
soon
Azure Container Instance logo
Deploy and manage serverless containers on the Microsoft Azure cloud, without having to manage any underlying infrastructure.
Azure Container Registries logo
Managed, private Docker registry service based on the open-source Docker Registry 2.0.
Azure Content Moderator logo
AI service for content moderation and human review tool for images, text, and videos.
Azure Cosmos DB logo
Azure Cosmos DB
Globally-distributed, multi-model database service "for managing data at planet-scale".
Azure Custom Vision Prediction logo
Customize computer vision for specific domain. No machine learning expertise is required.
Azure Custom Vision Training logo
Azure Database for Maria DB logo
Full coverage of performance for critical workloads with AI-problem detection, availability, and more.
Azure Database for MySQL logo
Full observability of MYSQL servers and database instances to ensure database health and performance.
Azure Database for PostgreSQL logo
Full insight into database performance for critical workloads with AI-problem detection and more.
Azure Data Box Edge  logo
Azure Data Box Edge
Rebranded as Azure Stack Edge. ... Azure Stack Edge is a Hardware-as-a-service solution.
soon
Azure Data Catalog logo
Azure Data Catalog
Fully managed cloud service that lets users discover the data sources they need and understand the data sources they find.
Azure Data Explorer Clusters logo
Engine and data management clusters which uses several Azure resources such as Azure Linux VM's and Storage.
Azure Data Factory logo
Azure Data Factory
Cloud-based ETL and data integration service for creating data-driven workflows for moving and transforming data at scale.
Azure Data Lake Analytics logo
Distributed, cloud-based data processing architecture offered by Microsoft in the Azure cloud.
Azure Data Lake Storage logo
Fully-managed, elastic, scalable, and secure file system that supports HDFS semantics and works with the Hadoop ecosystem.
Azure Data Share logo
Azure Data Share
Platform as a Service tool that allows you to share data sets using Azure Services.
Azure Device Provisioning Service logo
Helper service for IoT Hub that enables just-in-time provisioning to the right IoT hub without human intervention.
Azure Disk Storage logo
Azure Disk Storage
Cloud storage offering providing multiple solutions for organizations.
Azure DNS Zones logo
Azure DNS Zones
Data resource that contains the DNS records for a domain name.
Azure Event Grid Domains logo
Simplifies the development of event-based applications and simplifies the creation of serverless workflows.
Azure Event Grid Subscriptions logo
Support for Azure Event Grid Subscriptions.
soon
Azure Event Grid Topics logo
Topic based events for serverless and event based workflows.
Azure Event Hub Clusters logo
Big data streaming platform and event ingestion service. It can receive and process millions of events per second.
Azure Event Hubs logo
Azure Event Hubs
Fully managed data ingestion service that's simple, and scalable.
Azure Face logo
Azure Face
An AI service that analyzes faces in images
Azure File Storage logo
Azure File Storage
Fully managed file shareing in the cloud.
Azure Firewall logo
Azure Firewall
Managed, cloud-based network security service that protects your Azure Virtual Network resources.
Azure Front Door (classic) logo
Optimize application performance with visibility into requests and latency, ensuring routing efficiency and backend health.
Azure Functions logo
Azure Functions
Intelligent end-to-end observability for serverless and hybrid environments using Azure Functions.
Azure HDInsight logo
Azure HDInsight
Holistic analytics of HDInsights with integrated metrics from Hadoop, Spark, and Kafka, all in one place.
Azure Immersive Reader logo
An AI service to embed text reading into applications.
Azure Ink Recognizer logo
An AI service that provides a cloud-based REST API to analyze and recognize digital ink content.
Azure Integration Service Environment logo
Allows you to deploy Logic Apps as a service in your Azure Virtual Network.
Azure IoT Central Applications logo
Fully hosted by Microsoft, which reduces the administration overhead of managing your applications.
Azure IoT Hub logo
Azure IoT Hub
Cloud-hosted solution backend to connect virtually any device.
Azure Key Vault logo
Azure Key Vault
Cloud service within you can securely store keys, passwords, certificates, and other secrets.
Azure Kubernetes Service logo
Azure Language Understanding (LUIS) logo
An AI service that allows users to interact with your applications, bots, and IoT devices by using natural language.
Azure Load Balancer logo
Azure Load Balancer
Layer-4 load balancer that provides high availability by distributing incoming traffic among VMs.
Azure Logic Apps logo
Azure Logic Apps
Cloud service that helps you schedule, automate, and orchestrate tasks across enterprises or organizations.
Azure Machine Learning logo
Collection of services and tools intended to help developers train and deploy machine learning models.
Azure Managed Instance for Apache Cassandra logo
Ingest metrics from Azure Managed Instance for Apache Cassandra to gain insights into your cluster's health and performance.
Azure Maps account logo
Azure Maps account
Provides the geospatial capability for mapping the data.
Azure Media Services logo
Cloud-based platform to build solutions that achieve broadcast-quality video streaming.
Azure NetApp Capacity Pool logo
Enterprise-class, high-performance, metered file storage service
Azure NetApp files logo
Azure NetApp files
File-storage service to run your most demanding file-workloads in Azure, without the need for any code modification.
Azure Network Interface logo
Enables an Azure Virtual Machine to communicate with internet, Azure and on-premises resources.
Azure Network Watcher logo
Provides tools to monitor, diagnose, view metrics, and enable or disable logs for resources in an Azure virtual network.
Azure Notification Hub Namespaces logo
Push engine that allows you to send notifications to any platform from any backend (cloud or on-premises).
Azure Peerings logo
Azure Peerings
Virtual network peering enables you to seamlessly connect networks in Azure Virtual Network.
Azure Personalizer logo
Azure Personalizer
An AI service that prioritizes relevant content, layouts, and conversations to deliver personalized user experience.
Azure Private DNS Zone logo
Hosting service for DNS domains, providing name resolution using the Microsoft Azure infrastructure.
Azure Public IP address logo
Reserved public IP addresses for your public endpoints in Azure.
Azure QnA Maker logo
Azure QnA Maker
Build, train and publish a sophisticated bot without machine learning experience.
Azure Queue Storage logo
Azure Queue Storage
Service for storing large numbers of messages that can be accessed from anywhere in the world.
Azure Relays logo
Azure Relays
Enables you to securely expose services that run in your corporate network to the public cloud.
Azure Search Services logo
Fully managed cloud search service that provides a better user experience for customers.
Azure Service Bus logo
Azure Service Bus
Cloud messaging as a service (MaaS) and simple hybrid integration.
Azure Service-Fabric logo
Intelligent end-to-end observability for serverless and hybrid environments using Azure Service Fabric.
Azure SignalR logo
Azure SignalR
Adding real-time communications to your web application is as simple as provisioning a service.
Azure Speech To Text logo
An AI service that accurately converts spoken audio to text.
Azure Spring Apps logo
Azure Spring Apps
Brings modern microservice patterns to Spring Boot apps eliminating boilerplate code to quickly develop robust Java apps.
Azure SQL Database logo
Azure SQL Database
Managed cloud database provided as part of Microsoft Azure.
Azure SQL Managed logo
Azure SQL Managed
Full observability into cloud database performance and automated monitoring for Azure SQL Managed.
Azure SQL Server Stratch logo
Dynamically stretch warm and cold transactional data from SQL Server 2016 to Azure.
Azure Storage Sync Service logo
Centralize your file shares in the cloud while keeping the benefits of an on-premise file server.
Azure Stream Analytics Jobs logo
Serverless job service that eliminates the need for infrastructure, servers, virtual machines, or managed clusters.
Azure Synapse Analytics logo
Cloud-based, scale-out, relational database capable of processing massive volumes of data.
Azure Table Storage logo
Azure Table Storage
Stores structured NoSQL data in the cloud, providing a key/attribute store with a schemaless design.
Azure Text Analytics logo
Uncover insights such as sentiment, entities, and key phrases in unstructured text.
Azure Time Series Insights logo
Fully managed analytics, storage, and visualization service for managing IoT-scale time-series data in the cloud.
Azure Traffic Manager logo
Multi-cloud support for improved application performance and availability with distributed tracing.
Azure Translator logo
Azure Translator
AI powered service to translate text in real time across more than 70 languages.
Azure Virtual Machines logo
Intelligent end-to-end observability for cloud environments using Azure Virtual machines.
Azure Virtual Machine Scale Sets logo
Scale-out workloads, stateless web front ends, container orchestration, and microservices clusters.
Azure Virtual machines (classic) logo
Deep observability into Azure cloud service virtual machines and applications.
Azure Virtual Network Gateway logo
Monitor connecting workloads and performance to ensure Azure network is successfully connected.
Azure Virtual Networks logo
Fundamental building block for your private network in Azure. VNet enables many types of Azure resources.
Backbone.js logo
Backbone.js
JavaScript library based on the Model–view–presenter application design paradigm.
BellSoft Liberica logo
BellSoft Liberica
Bitbucket logo
Bitbucket
Version control repository service for source code thas use either Mercurial or Git systems.
BizTalk Plugin 2.0 logo
BizTalk Plugin 2.0
AtosAtos
Easy, cheap, reliable and secure way to load Biztalk metrics into Dynatrace, based on the Dynatrace WMI 2.0 standard.
Blazemeter logo
Blazemeter
Commercial, self-service load testing platform as a service.
BOSH bpm logo
BOSH bpm
Automated monitoring of platform processes running in BOSH bpm containers.
Business events logo
Business events
Business events deliver real-time business observability to business and IT teams with precision and context for data-driven decisions.
C logo
C
Procedural programming language supporting lexical variable scope, and recursion.
CakePHP logo
CakePHP
Automatically and intelligently monitor, analyze, and optimize your applications developed with CakePHP.
CentOS logo
CentOS
Community-supported computing platform compatible with Red Hat Enterprise Linux.
Ceph storage logo
Ceph storage
This extension provides ability to monitor usage of Ceph storage system. It covers both client side and host level in-depth data.
Chef logo
Chef
Configuration management tool.
Citrix NetScaler ADC logo
All-in-one web ADC that makes applications run up to five times faster.
Citrix Virtual Apps and Desktops logo
Complete virtual app and desktop solution to meet all your business needs.
Cloud Automation Control Plane logo
Enable Dynatrace for automation of release validation, problem remediation, and orchestration of your software development lifecycle tools.
CloudFlare logo
CloudFlare
Content-delivery-network services, DDoS mitigation, Internet security, and distributed services.
Cloud Foundry logo
Cloud Foundry
Harness automation and AI to simplify observability on Cloud Foundry at scale.
Composer logo
Composer
PerformetriksPerformetriks
Simplify Administration and Configuration Management for Dynatrace
Concourse logo
Concourse
Concourse is the automation engine for cloud native CI/CD.
Configuration as Code logo
Get Dynatrace observability and security configurations in a fully automated everything-as-code fashion - via YAML files.
Confluent Cloud (Kafka) logo
Remotely monitor your Confluent Cloud Kafka Cluster and other resources with this Prometheus based Extension 2.0.
Connection Pools: JBoss logo
Application server method of pooling and sharing multiple connections to a database.
Connection Pools: Tomcat logo
Connection Pools: WebLogic logo
Connection Pools: WebSphere Liberty logo
Consul Service Mesh (StatsD) logo
Extend visibility into your Consul Service Mesh instances to monitor health and improve performance.
containerd logo
containerd
Automated distributed tracing and metrics for microservices running in containerd containers in Kubernetes.
Control-M Jobs logo
Control-M Jobs
ActiveGate extension to monitor your Control-M jobs execution status.
CoreDNS logo
CoreDNS
Detailed visibility of CoreDNS server health state and throughput
Couchbase logo
Couchbase
Automatically and intelligently observe, analyze and optimize how your the usage, health and performance of your NoSQL database.
cri-o logo
cri-o
Automated distributed tracing and metrics for microservices running in cri-o containers in Kubernetes.
Custom Database Queries logo
Make generic databases queries to your Oracle, Postgres, MSSQL, MySQL, DB2, Informix or SAP HANA databases and send the metrics to Dynatrace
Custom Data ingest via API logo
Extend Dynatrace with custom ingest APIs
Databricks logo
Databricks
Use this extension to ingest metrics from your Databricks Clusters via the embedded Ganglia metric repository.
Davis Assistant logo
Davis Assistant
Immediate actionable answers to complex Dynatrace questions with a simple conversation.
DC/OS logo
DC/OS
Monitor application and cluster health in highly-dynamic container environments.
Debian logo
Debian
Association of individuals who have made common cause to create a free operating system.
Disk Analytics logo
Disk Analytics
This extension allows more detailed visibility on Linux hosts' local datastores where OneAgent is installed. DDUs required.
Docker logo
Docker
Automated distributed tracing and metrics for microservices running in docker containers in Kubernetes.
Dojo logo
Dojo
Modular JavaScript library open source based.
Drupal logo
Drupal
Web content management for back-end framework.
Dynatrace API Gateway by ESA logo
Define and enforce fine-grained policies for using the Dynatrace APIs.
Dynatrace ETL Service by ESA logo
Continuously extract metrics and properties for Dynatrace entities, user sessions and more.
Dynatrace Integration for Jira logo
AlanataAlanata
Accelerate service operations and reduce MTTR using automated problems integration and Smartscape for CMDB synchronization into Jira
Dynatrace mobile app for Android logo
The DynatraceÂŽ mobile app provides real-time alerts on your mobile for business-critical incidents that impact your application environment.
Dynatrace mobile app for iOS logo
Dynatrace Self-Monitoring (Managed) logo
This extension enables a dashboard for the self-monitoring environment on the Managed cluster showing cluster utilization and data ingest.
Dynatrace Solution Server by ESA logo
Seamlessly deploy, manage, and run ESA Solutions and conventional Dynatrace extensions.
Eclipse Jetty logo
Eclipse Jetty
Automatically and intelligently monitor, analyze, and optimize your applications developed with Jetty
Eclipse OpenJ9 logo
Eclipse OpenJ9
Eclipse Temurin (Adoptium) logo
Elasticsearch logo
Elasticsearch
Monitor your Elasticsearch Clusters, Nodes, and Indexes to identify the root cause of potential performance issues
Ember.js logo
Ember.js
Open-source JavaScript web framework, based on the Model–view–viewmodel pattern.
Envoy logo
Envoy
Automated distributed tracing and metrics for Envoy proxies.
Erlang logo
Erlang
General-purpose, concurrent, functional programming language, and a runtime system.
etcd for OpenShift logo
etcd for OpenShift
Get deep insights into your self-managed OpenShift control plane using etcd metrics exposed on your cluster.
Express logo
Express
Fast, unopinionated, minimalist web framework for Node.js.
Extensions Health logo
Extensions Health
Reporting health of deployed extensions and additionally showing used resources (CPU and memory) and top data point contributors.
F5 BIG-IP LTM logo
F5 BIG-IP LTM
Monitor your F5 BIG-IP Local Traffic Manager (LTM) platform remotely and gain insights into the health and performance of these devices.
Fedora logo
Fedora
Linux distribution sponsored primarily by Red Hat, a subsidiary of IBM.
Filesystem monitoring logo
Monitor your files and folders. Deploy to hundreds of hosts automatically in minutes.
Flagsmith JavaScript Integration logo
FlagsmithFlagsmith
Understand the impact of your feature releases on user behavior in Dynatrace.
Fluent Bit logo
Fluent Bit
Stream log data to Dynatrace via Fluent Bit for analysis.
Fluentd logo
Fluentd
Stream log data to Dynatrace via Fluentd for analysis.
Flutter logo
Flutter
Monitor mobile applications built with Flutter on iOS or Android.
Fortinet Fortigate logo
Fortinet Fortigate
Monitor your Fortigate devices via the REST API
Fujitsu Interstage logo
Fujitsu Interstage
Suite of inter-working software products.
Fujitsu Interstage IHS logo
Complete suite of software that helps companies continuously visualize and optimize their business.
Fujitsu JVM logo
Fujitsu JVM
Garden-RunC logo
Garden-RunC
Automated distributed tracing and metrics for microservices running in garden runc containers in Cloud Foundry.
Gatling logo
Gatling
Open-source load and performance testing framework based on Scala, Akka and Netty.
Generic Cisco Device logo
Monitor Cisco devices using SNMP to feed Dynatrace with metrics and enable alerting.
Generic Linux Commands logo
Remotely execute commands on your Linux hosts (over SSH). Baseline and alert on your KPIs through metrics created from the command output.
Generic network device logo
Level up your network infrastructure observability by monitoring your network equipment within the Dynatrace platform.
Gigamon Deep Observability Pipeline logo
GigamonGigamon
The Gigamon Deep Observability Pipeline harnesses actionable network-level intelligence to amplify the power of Dynatrace
GlassFish logo
GlassFish
Go logo
Go
Automatic and intelligent end-to-end observability for Go applications
Google AI Platform logo
Google AI Platform
Get insights into Google AI Platform service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google AlloyDB logo
Google AlloyDB
Get insights into Google AlloyDB service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Analytics logo
Google Analytics
Track and optimize marketing campaigns with shared business context from UTM parameters tracked in Google Analytics.
Google Analytics Real-Time logo
MarketWareMarketWare
Import your Google Analytics real-time data into Dynatrace and correlate it with all other metrics provided by Dynatrace.
Google Apigee logo
Google Apigee
Get insights into Google Apigee service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google App Engine logo
Google App Engine
Service and cloud computing platform for developing and hosting web applications.
Google App Engine. Monitor with GCP integration logo
Get insights into Google App Engine service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Assistant Smart Home logo
Get insights into Google Assistant Smart Home metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Big Query logo
Google Big Query
Get insights into Google BigQuery service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Chrome logo
Google Chrome
Cross-platform web browser developed by Google.
Google Cloud APIs logo
Google Cloud APIs
Get insights into Google Cloud APIs service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Bigtable logo
Get insights into Google Cloud Bigtable metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Composer logo
Get insights into Google Cloud Composer metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Data Loss Prevention logo
Get insights into Google Data Loss Prevention metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Cloud DNS logo
Google Cloud DNS
Get insights into Google Cloud DNS service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Filestore logo
Monitor your Google Cloud Filestore services using metrics ingested to your Dynatrace cluster
Google Cloud Firestore logo
Get insights into Google Cloud Firestore metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Functions logo
Intelligent end-to-end observability for serverless and hybrid environments using Google Functions.
Google Cloud IoT Core logo
Get insights into Google Cloud IoT Core metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Load Balancing logo
Get insights into Google Load Balancing metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Platform logo
Meet your business challenges head on with cloud computing services from Google.
Google Cloud Router logo
Google Cloud Router
Get insights into Google Cloud Router service metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Cloud Run logo
Google Cloud Run
Dynatrace provides AI-powered observability into serverless containerized apps running on Google Cloud Run
Google Cloud Run. Monitor with GCP integration logo
Get insights into Google Cloud Run service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud's operations suite logo
Get insights into Google Cloud's operations suite metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Google Cloud Spanner logo
Get insights into Google Cloud Spanner metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud SQL logo
Google Cloud SQL
Get insights into Google Cloud SQL service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Storage logo
Get insights into Google Cloud Storage metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Storage Transfer logo
Get insights into Google Cloud Storage Transfer metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Google Cloud Tasks logo
Google Cloud Tasks
Get insights into Google Cloud Tasks service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Cloud Tensor Processing Unit (TPU) logo
Train and run machine learning models.
Google CloudTrace logo
Google CloudTrace
Distributed tracing system that collects latency data from your apps and displays it in the GCP.
Google Compute Engine logo
Service component of Google Cloud Platform, built on the global infrastructure.
Google Compute Engine. Monitor with GCP integration logo
Get insights into Google Compute Engine metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Container-optimized OS logo
Dynatrace OneAgent monitors Kubernetes nodes with Google's secure Container-optimized OS quickly, efficiently, and securely.
Google Dataflow logo
Google Dataflow
Get insights into Google Dataflow service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Dataproc logo
Google Dataproc
Get insights into Google Dataproc service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Firebase logo
Google Firebase
Get insights into Google Firebase service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Firestore in Datastore mode logo
Get insights into Google Firestore in Datastore mode metrics collected from the Google Operations API to ensure health of infrastructure
Google Hybrid Connectivity logo
Get insights into Google Hybrid Connectivity metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Kubernetes Engine logo
Google Kubernetes Engine (GKE). Monitor with GCP integration logo
Get insights into Google Kubernetes Engine metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Managed Microsoft AD logo
Get insights into Google Managed Microsoft AD metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Memorystore logo
Google Memorystore
Get insights into Google Memorystore service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Network Security logo
Get insights into Google Network Security metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Network Topology logo
Get insights into Google Network Topology metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Pub/Sub logo
Google Pub/Sub
Get insights into Google Pub/Sub service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
Google Pub/Sub Lite logo
Google Pub/Sub Lite
Get insights into Google Pub/Sub Lite service metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google reCAPTCHA Enterprise logo
Get insights into Google reCAPTCHA Enterprise metrics collected from the Google Operations API to ensure health of your cloud infrastructure
Google Virtual Private Cloud logo
Get insights into Google Virtual Private Cloud metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Google VPC access logo
Google VPC access
Provides support for Google VPC access.
GraalVM logo
GraalVM
Grail logo
Grail
Grail (TM) is a new data lakehouse technology for boundless observability, security, and business analytics.
GraphQL logo
GraphQL
Intelligently observe, analyze and optimize your applications using GraphQL queries.
Gremlin for Cloud Automation logo
GremlinGremlin
Integrate Gremlin with Cloud Automation to trigger chaos experiment scenarios.
Gremlin for Dynatrace logo
GremlinGremlin
Gremlin for Dynatrace enables engineers to build more reliable software by running Chaos Engineering experiments with confidence.
gRPC logo
gRPC
Open source remote procedure call (RPC) system.
GWT Web Toolkit logo
GWT Web Toolkit
Set of tools that allows web developers to create and maintain JavaScript front-end applications.
Hadoop HDFS logo
Hadoop HDFS
The Hadoop Distributed File System (HDFS) is a distributed file system designed for high throughput, large application data sets.
Hadoop YARN logo
Hadoop YARN
Collection of utilities that allows to solve problems involving massive amounts of data.
HAProxy logo
HAProxy
Load balancer and proxy server for applications that spreads requests across multiple servers.
HAProxy (Prometheus) logo
Monitor HAProxy Load balancer using prometheus to feed Dynatrace with metrics.
HashiCorp Terraform logo
HashiCorp Terraform
Leverage Terraform to automate deployment of dashboards, custom services, management zones etc. across your complete Dynatrace instance.
Hazelcast logo
Hazelcast
Dynatrace PurePathÂŽ technology seamlessly integrates OpenTracing data for Java emitted by the Hazelcast in-memory computing platform.
Heroku logo
Heroku
Platform as a service that enables developers to build, run, and operate applications in the cloud.
Hitachi JVM logo
Hitachi JVM
How fast is your app? logo
Measure your native mobile app performance and availability on real Android and iPhone devices, with no instrumentation.
HTML5 logo
HTML5
Markup language used for structuring and presenting content on the web.
HTTP logo
HTTP
Application protocol for distributed, collaborative, hypermedia information systems.
HTTP2 logo
HTTP2
Binary protocol that brings push, multiplexing streams and frame control to the web.
Huawei JVM logo
Huawei JVM
IBM AIX logo
IBM AIX
Series of proprietary Unix operating systems developed and sold by IBM.
IBM App Connect Enterprise logo
Allows business information to flow between applications across multiple platforms.
IBM Bluemix logo
IBM Bluemix
Architecture diagram templates to create your own architectures using simple icons.
IBM CICS Transaction Gateway for z/OS logo
Intelligently monitor your transactions end-to-end and analyze the performance of your CICS Transaction Gateway on z/OS.
IBM CICS Transaction Server logo
Intelligently monitor, analyze and optimize your transactions end-to-end including the related CICS regions.
IBM Cloud Foundry logo
IBM Cloud Foundry
Set of cloud computing services for business offered by the information technology company IBM.
IBM Cloud Kubernetes Service logo
IBM DataPower logo
IBM DataPower
Enables the classification of data requests based on service and application-level information.
IBM DB2 logo
IBM DB2
Data management products, including database servers, developed by IBM.
IBM DB2 for LUW (remote monitoring) logo
Remotely monitor your DB2 instances to collect data on transactions, connections, buffer pools. tablespaces, and transaction logs.
IBM Event Streams logo
IBM Event Streams
Monitor your IBM Event Streams, a Kafka offering by IBM.
IBM HTTP Server logo
IBM HTTP Server
Automatically and intelligently monitor, analyze, and optimize your applications developed with IBM HTTP Server.
IBM i logo
IBM i
Versatile, Multi-Environment H2Servers for the Era of e-business on demand.
IBM IMS logo
IBM IMS
Intelligently monitor, analyze and optimize your transactions end-to-end including the related IMS regions.
IBM IMS SOAP Gateway logo
Intelligently monitor your transactions end-to-end and analyze the performance of your IMS SOAP Gateway.
IBM Informix logo
IBM Informix
Remotely monitor your Informix databases and get insight into crucial Informix metrics
IBM Integration Bus logo
IBM Integration Bus
IBM JVM logo
IBM JVM
IBM MQ logo
IBM MQ
Automatic and intelligent observability for IBM MQ with end-to-end traces of connected producers and consumers.
IBM MQ - ActiveGate logo
IBM MQ - ActiveGate
ActiveGate extension that allows monitoring of IBM MQ performance remotely.
IBM Semeru logo
IBM Semeru
IBM WebSphere Application Server logo
IBM WebSphere Application Server for z/OS logo
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed on it.
IBM WebSphere Liberty logo
IBM WebSphere Liberty for z/OS logo
IBM WebSphere Message Broker logo
Allows information to flow between disparate applications across multiple platforms.
IBM z/OS logo
IBM z/OS
Intelligently monitor the performance and availability of your LPARs and regions.
IBM z/OS Connect Enterprise Edition logo
Modernize to hybrid cloud infrastructure with end-to-end observability from the mainframe to the cloud, and everything in between.
ICEFaces logo
ICEFaces
Open-source Rich Internet Application (RIA) development framework for Java EE.
InterSystems IRIS (Remote) logo
ActiveGate extension that collects metrics and events from the InterSystems IRIS APIs for use in Dynatrace.
Ionic logo
Ionic
Monitor hybrid mobile apps built with the Ionic framework running on iOS or Android
iOS logo
iOS
Monitor mobile applications that are running on Apple's popular iOS operating system.
iOS Safari logo
iOS Safari
ISAM logo
ISAM
Collect metrics about IBM Security Access Manager (ISAM)
Istio Service Mesh logo
Istio Service Mesh
Automated distributed tracing, metrics & logs for microservices and proxies managed by Istio Service Mesh.
Jakarta Servlet logo
Jakarta Servlet
Automatically and intelligently monitor, analyze, and optimize the performance of your Servlets.
Java logo
Java
Automatic and intelligent end-to-end observability for Java applications
Java JDBC logo
Java JDBC
Application programming interface for the Java, defines access to a database.
Java JMS logo
Java JMS
Java message-oriented middleware API for sending messages between two or more clients.
JavaScript logo
JavaScript
Programming language that conforms to the ECMAScript specification.
JBoss Enterprise Application Platform logo
Joomla logo
Joomla
Management system for publishing web content.
jQuery logo
jQuery
JavaScript library designed to simplify HTML DOM tree traversal and manipulation.
Juniper Networks (SNMP) logo
Start monitoring your Juniper Network devices to collect metrics and enable alerting on top of them.
Jython logo
Jython
Implementation of the Python programming language designed to run on the Java platform.
Keptn logo
Keptn
Event-based control plane for continuous delivery and automated operations.
Kestrel for ASP.NET Core logo
Automatically and intelligently monitor, analyze and optimize your ASP.NET Core apps running on a Kestrel web server.
Kong Gateway logo
Kong Gateway
Intelligently monitor, analyze, and optimize your Kong Gateway and its managed APIs.
Kubernetes logo
Kubernetes
Open-source system for automating deployment, scaling, and management of containerized applications.
Kubernetes Monitoring Statistics logo
Effective troubleshooting of your Dynatrace Kubernetes monitoring and Prometheus integration setup.
Kubernetes persistent volume claims logo
Monitor your Kubernetes persistent volume claims and alert on capacity limits.
KVM logo
KVM
Monitor health and performance of KVM virtual machines from the system’s perspective.
Laravel logo
Laravel
Automatically and intelligently monitor, analyze, and optimize your applications developed with Laravel.
LaunchDarkly for Cloud Automation logo
LaunchDarklyLaunchDarkly
LaunchDarkly empowers all teams to deliver and control software to contribute to the customer's digital experience in a meaningful way.
LaunchDarkly Integration for Dynatrace logo
The LaunchDarkly Dynatrace integration combines the analytics from Dynatrace with the power of LaunchDarkly’s feature management platform.
LDAP logo
LDAP
Vendor-neutral protocol for accessing and maintaining distributed directory information services.
LDAP Synthetic logo
LDAP Synthetic
Execute synthetic LDAP searches to monitor the availability of your LDAP servers
Lightrun Developer Observability Platform logo
LightrunLightrun
Troubleshoot and understand the behavior of live, cloud-native apps by adding logs metrics and snapshots in real-time directly from your IDE
LinkerdD logo
LinkerdD
Observability, reliability, and security without requiring any code changes for Kubernetes.
Linkerd Service Mesh (Prometheus) logo
LInkerd service mesh provides runtime debugging, observability, reliability, and security with zero code changes.
Linux logo
Linux
Family of open source Unix-like operating systems based on the Linux kernel.
Linux on IBM Z mainframe logo
Automatic insights into your Linux operating system on IBM Z mainframe with performance and health metrics down to the process level.
LoadRunner logo
LoadRunner
Load testing tool for project teams.
Log Management and Analytics powered by Grail logo
Get answers to any question, any time, at any scale, with no indexes, rehydration, or sampling.
Log Monitoring for AWS logo
Get answers from logs across all services in context.
Logstash logo
Logstash
Stream log data from Logstash and analyze it in Dynatrace.
Machine Learning on AWS logo
Robust, cloud-based service that makes it easy for developers of all skill levels to use machine learning technology.
soon
Magento logo
Magento
Deep insight into user experience, top landing & exit pages and bounce rates.
MariaDB logo
MariaDB
Maven logo
Maven
Muild automation tool used primarily for Java projects.
Memcached logo
Memcached
Distributed memory-caching system often used to speed up dynamic database-driven websites.
Micrometer logo
Micrometer
Automatically ingest Spring Application metrics and analyze them end-to-end in context of your trace, log and diagnostics data.
Microsoft Active Directory replication logo
Monitors the sync status of your Active Directory servers as well as the file shares status.
Microsoft Azure logo
Microsoft Azure
Cloud computing service for building, testing, deploying, and managing applications and services.
Microsoft Edge logo
Microsoft Edge
Real user monitoring - visibility and monitoring starting on you clients browser (desktop, tablet, mobile)
Microsoft Exchange Server logo
Monitor health and improve performance of your Microsoft Exchange mail server and calendaring server.
Microsoft Hyper-V logo
Microsoft Hyper-V
Monitor health and performance of Microsoft Hyper-V virtual machines from the system’s perspective.
Microsoft Hyper-V (WMI) logo
Monitor health and performance of native Windows virtual machines from the host’s perspective
Microsoft IIS logo
Microsoft IIS
Flexible, secure and manageable Web server for hosting anything on the Web for WindowsÂŽ Server.
Microsoft Internet Explorer logo
Series of graphical web browsers.
Microsoft Message Queuing (MSMQ) logo
Automatic and intelligent observability for MSMQ with end-to-end traces of connected producers and consumers.
Microsoft SQL Server logo
Expand visibility to improve the health and performance monitoring of your Microsoft SQL Servers!
Microsoft Teams logo
Microsoft Teams
Hub for team collaboration in Microsoft 365 that integrates the people, content, and tools.
Microsoft Visual Studio logo
Integrated development environment from Microsoft.
MongoDB logo
MongoDB
Mongo DB Atlas logo
Mongo DB Atlas
Monitoring of your SaaS installation of Mongo DB (Atlas)
MongoDB (Prometheus) logo
Monitor MongoDB server using prometheus to feed Dynatrace with metrics.
MooTools logo
MooTools
Object-oriented JavaScript framework. Released under the free, open-source MIT License.
Mozilla Firefox logo
Mozilla Firefox
Free, open source web browser that uses the Gecko layout engine.
MuleSoft logo
MuleSoft
Event source enabling you to set up an HTTP server and trigger flows when requests are received.
Mulesoft Cloudhub (Extension v2) logo
Gather in depth metrics and topology from your Anypoint Cloudhub Organizations, Environments, Applications, APIs and Workers
MySQL logo
MySQL
MySQL (remote monitoring) logo
Remotely monitor your MySQL instances, collect connections, statements, throughput, waits, database metrics.
Nagios Integration logo
Nagios Integration
AlanataAlanata
Monitoring consolidation - eliminate event storms, reduce MTTR using Nagios hosts data and problems in Dynatrace leveraging Davis AI engine.
Neo4j logo
Neo4j
Extend observability with PurePathÂŽ distributed traces by seamlessly integrating OpenTracing data emitted by the Neo4j graph database.
NeoLoad logo
NeoLoad
TricentisTricentis
Automated Load Testing tool enabling you to run Continuous Performance Testing.
NetApp on Google Cloud logo
Get insights into NetApp on Google Cloud metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
NetApp OnTap (Remote) logo
ActiveGate extension that collects important NetApp OnTap metrics from the OnTap 9.6+ REST API for use in Dynatrace.
Netbackup Jobs logo
Netbackup Jobs
Monitor your Veritas Netbackup jobs execution status
.NET Framework logo
.NET Framework
Software framework developed by Microsoft that runs primarily on Microsoft Windows.
.NET / .NET Core logo
.NET / .NET Core
Automatic and intelligent end-to-end observability for .NET / .NET Core applications
Netty logo
Netty
I/O client-server framework for the development of Java network applications.
NGINX logo
NGINX
Accelerates application delivery, improves security, facilitates availability & scalability.
NGINX Plus logo
NGINX Plus
All‑in‑one load balancer, content cache, and web server.
Nobl9 SLO Platform logo
Nobl9 SLO Platform
Nobl9Nobl9
Nobl9 simplifies SLO usage with an integrated approach that enables SLI collection, SLO calculation, and error budget alerts.
Node.js logo
Node.js
Automatic and intelligent end-to-end observability for Node.js applications
NTP sync check logo
NTP sync check
Network Time Protocol assures host clocks are in sync with a trusted time source
Nutanix AHV logo
Nutanix AHV
Monitor health and performance of Nutanix AHV virtual machines from the system’s perspective.
NVIDIA GPUs logo
NVIDIA GPUs
Monitor the utilization and temperature of your NVIDIA GPUs
Omniscopy logo
Omniscopy
OmniscopyOmniscopy
User Journey analytics for Dynatrace DEM to understand and reduce friction points affecting user engagement and end-user productivity.
OpenJDK logo
OpenJDK
OpenMetrics logo
OpenMetrics
Use OpenMetrics to ingest, store and analyze metrics at scale
soon
OpenShift Control Plane logo
Get deep insights into your OpenShift control plane using metrics exposed by various control plane components.
openSUSE logo
openSUSE
The openSUSE project is a community program sponsored by SUSE Linux and other companies.
OpenTelemetry logo
OpenTelemetry
Ingest OpenTelemetry traces & metrics, pin them to a dashboard, set alarms, analyze them in the context of metric, log, and diagnostic data.
OpenTracing logo
OpenTracing
Ingest and chart OpenTracing data, set alerts, and analyze everything in the context of traces, metrics, logs, and diagnostics data.
Opera logo
Opera
Freeware web browser for Microsoft Windows, Android, iOS, macOS, and Linux operating systems.
Opsgenie logo
Opsgenie
Alerting and on-call management platform for operating always-on services.
Oracle Cloud logo
Oracle Cloud
Cloud computing serviceproviding servers, storage, network, applications and services.
Oracle Database logo
Oracle Database
Automatically and intelligently observe, analyze and optimize the usage, health and performance of your Oracle database.
Oracle Hotspot VM logo
Oracle Hotspot VM
Oracle HTTP Server logo
Oracle HTTP Server
Web server component for Oracle Fusion Middleware.
Oracle JRockit logo
Oracle JRockit
Oracle Solaris logo
Oracle Solaris
Provides proven, enterprise-class security, reliability, and performance for SPARC and x86 systems.
Oracle WebLogic logo
Oracle WebLogic
OutSystems Cloud Metrics logo
OutSystems is a leading low-code application platform. With this integration, their Cloud API data becomes available inside Dynatrace.
PagerDuty logo
PagerDuty
SaaS incident response platform for IT departments.
Palo Alto firewalls logo
Palo Alto firewalls
Monitor Palo Alto firewalls using SNMP to feed Dynatrace with metrics to allow alerting and Davis problem detection
Payara logo
Payara
Perl logo
Perl
Perl is a family of two high-level, general-purpose, interpreted, dynamic programming languages.
PHP logo
PHP
Automatic and intelligent end-to-end observability for PHP applications
PHPUnit logo
PHPUnit
Unit testing framework for the PHP programming language.
Ping Every Second logo
Ping Every Second
Measure your network latency every second, understand the performance level and receive more details about network availability.
Pivotal Platform logo
Pivotal Platform
Multi-cloud platform for the deployment, management, and continuous delivery of applications. Pivotal is now VMware Tanzu.
Play Framework logo
Play Framework
Automatically and intelligently monitor, analyze, and optimize your applications developed with Play Framework.
PostgreSQL logo
PostgreSQL
Prometheus logo
Prometheus
Prometheus is an open-source monitoring toolkit for collecting and alerting on infrastructure and platform metrics.
Prometheus Alertmanager logo
Integrate alerts from Prometheus Alertmanager into Dynatrace
Prometheus in Kubernetes logo
Collect metrics from Prometheus exporters in Kubernetes for Dynatrace analysis and alerting.
prototype logo
prototype
Web JavaScript framework, implemented as a single file of JavaScript code.
Python logo
Python
End-to-end observability for your Python applications
QEMU logo
QEMU
Monitor health and performance of QEMU virtual machines from the system’s perspective.
RabbitMQ logo
RabbitMQ
Automatic and intelligent observability for RabbitMQ with end-to-end traces of connected producers and consumers.
RabbitMQ (Prometheus) logo
Start monitoring the most widely deployed open source message broker within minutes
React.js logo
React.js
JavaScript library for building user interfaces.
React Native logo
React Native
Monitor mobile applications built with React Native running on iOS or Android.
Reactor Core logo
Reactor Core
End-to-end trace your applications when the Reactor Core publishers Mono and Flux are used.
Red Hat Enterprise Linux logo
Scale existing apps across bare-metal, virtual, container, and all types of cloud environments.
Red Hat Enterprise Linux CoreOS logo
Open-source lightweight OS based on the Linux, providing infrastructure to clustered deployments.
Red Hat Fuse logo
Red Hat Fuse
Intelligently monitor, analyze, and optimize your enterprise service bus and all applications deployed in your stack.
Red Hat OpenShift logo
Red Hat OpenShift
Harness automation and AI to simplify observability on OpenShift at scale.
Red Hat OpenStack logo
Red Hat OpenStack
Free open standard cloud computing platform, infrastructure-as-a-service in clouds.
Red Hat Quarkus logo
Red Hat Quarkus
Automatically and intelligently monitor, analyze, and optimize your applications deployed on Red Hat Quarkus.
Redis logo
Redis
Automatically and intelligently observe, analyze and optimize how your the usage, health and performance of your Redis in memory store.
Redis Enterprise logo
Redis Enterprise
RedisRedis
Provides deep visibility into Redis Enterprise software installations. Auto-detects Redis Enterprise features and monitors automatically.
Redis Enterprise - Prometheus logo
Remotely monitor your Redis Enterprise software with the official Redis Prometheus exporter
Redis Open Source logo
Redis Open Source
AtosAtos
Monitor all open source Redis instances in your Dynatrace environment on a single pane of glass
Remote Desktop Protocol logo
Monitor the performance of user sessions for Windows RDP, and gain insights into the health of your Virtual Desktop solution.
Remote Unix Monitoring logo
ActiveGate extension that remotely monitors Unix OS and process metrics by connecting via SSH and executing commands.
Remote Windows Host Monitoring logo
Monitor health and improve performance of Microsoft Windows Hosts without installing an agent
restify logo
restify
Framework for building semantically correct RESTful web services ready for use at scale.
Riak logo
Riak
NoSQL data store that offers high availability, operational simplicity, and scalability.
Richfaces logo
Richfaces
Ajax-enabled component library for JavaServer Faces (open source).
Rookout Live Debugger logo
RookoutRookout
Cloud-native debugging and live data collection platform
Ruby logo
Ruby
Dynatrace monitors your Ruby applications and services on the process level.
Ruby on Rails Agent logo
Ruby on Rails Agent
Spica SolutionsSpica Solutions
Full stack visibility for Ruby on Rails applications without need of code changes.
Runtime Application Protection logo
Application Protection detects and blocks attacks on your applications automatically and in real-time.
Runtime Vulnerability Analytics logo
Detect vulnerabilities in your environment in real-time, with full context and automated risk assessment.
Salesforce Streaming API logo
Enables you to monitor the usage of your salesforce environment by end users.
Salt Stack logo
Salt Stack
Infrastructure automation software that is used to drive security and reliability.
SAP Business Technology Platform logo
SAP Business Technology Platform (SAP BTP) is the technological foundation for the intelligent enterprise
SAP Commerce Cloud logo
SAP Commerce Cloud
SAP Cloud Platform integrates data and business processes.
SAP GUI and ABAP platform logo
Automatic problem detection and visibility into every user transaction, and insight into the performance of RFC without changing any code.
SAP HANA Database (remote monitoring) logo
Easily understand the health and performance of your SAP HANA databases!
SAP JVM logo
SAP JVM
Automatically and intelligently monitor, analyze, and optimize the performance of your virtual machine.
Scala logo
Scala
Programming language providing support for functional programming and a strong static type system.
Selenium WebDriver logo
Selenium WebDriver
Web automation framework that allows you to execute your tests against different browsers.
Sencha ExtJS logo
Sencha ExtJS
JavaScript application framework for building interactive cross platform web applications.
Sencha Touch logo
Sencha Touch
Automatically and intelligently monitor, analyze, and optimize your applications developed with Sencha Touch.
Serverless logo
Serverless
Seamless integration with serverless technologies to eliminate blind spots through OOTB integrations with AWS, Azure, and Google Cloud
ServiceNow logo
ServiceNow
IT service management for large corporations, including help desk functionality.
Session Replay logo
Session Replay
Troubleshoot faster, address user complaints, and optimize customer journeys with securely captured visual recordings of every user session
Siebel logo
Siebel
Gathers metrics from the Siebel SARM logs to provide aggregated task information
SIGNL4 – Critical Mobile Alerting logo
DerdackDerdack
For a 10x faster response to critical incidents.
Slack logo
Slack
Where the people you need, the information you share, and the tools you use come together.
SNMP Traps logo
SNMP Traps
Supplement network device statistics with event-based data reported via SNMP Traps
Snowflake logo
Snowflake
Expand visibility to improve health and performance monitoring of your Snowflake accounts.
Snyk logo
Snyk
Snyk is integrated with Dynatrace to provide precise vulnerability matches, actionable descriptions, and detailed remediation guidance.
Solarwinds logo
Solarwinds
Monitor events and node performance
Spring logo
Spring
Application framework and inversion of control container for the Java platform.
SSL Checker logo
SSL Checker
Detects expired SSL certificates
StatsD logo
StatsD
The easiest way to get you custom application metrics into Dynatrace
SUSE Linux Enterprise Server logo
Distributed system and application software from other open source projects.
Symfony logo
Symfony
Automatically and intelligently monitor, analyze, and optimize your applications developed with Symfony.
Synthetic monitor DNS logo
Synthetically monitor your DNS servers to be proactively alerted when they go down.
Synthetic monitor Ping logo
Synthetically monitor your device availability using ping. This allows you to be proactively alerted when they are unavailable.
Synthetic monitor Ports logo
Synthetically monitor port availability on your servers. This allows you to be proactively alerted when they are unavailable.
Synthetic Monitor SSH logo
Report on KPIs through Synthetic monitors that execute Linux commands over SSH and interpret results numerically or by regular expressions.
Synthetic SFTP monitor logo
Monitor SFTP availability and performance. Visualize the data as Synthetic tests in Dynatrace.
Syslog (via Fluentd) logo
Stream Syslog data do Dynatrace via Fluentd for analysis.
TeamCity logo
TeamCity
Powerful continuous integration out of the box.
Telegraf logo
Telegraf
Automatically analyze and monitor hundreds of Telegraf provided plugins and metrics with Dynatrace
TIBCO ActiveMatrix BusinessWorks logo
Complete observability of applications and technologies across BusinessWorks processes.
TIBCO EMS logo
TIBCO EMS
Automatic and intelligent observability for Tibco EMS with end-to-end traces of connected producers and consumers.
Timeseries Streamer logo
Timeseries Streamer
360performance360performance
Export any Dynatrace metric to external timeseries databases for advanced processing, analytics and visualization.
Trello logo
Trello
Easy, free, flexible, and visual way to manage your projects and organize anything.
Tricentis NeoLoad for Cloud Automation logo
TricentisTricentis
Integrate Tricentis Neoload with Cloud Automation to execute performance tests.
T-Systems / Jenkins logo
T-Systems / Jenkins
T-SystemsT-Systems
Self-contained Java-based program, ready to run out-of-the-box.
tvOS logo
tvOS
Monitor mobile apps running on Apple TV.
Ubuntu logo
Ubuntu
Open-source, free Linux distribution based on Debian.
Varnish logo
Varnish
HTTP accelerator designed for content-heavy dynamic web sites as well as APIs.
Varnish Cache logo
Varnish Cache
versio.io logo
versio.io
Versio.ioVersio.io
Change detection and processing platform for business and IT with real-time CMDB
Vert.x logo
Vert.x
Extend observability by seamlessly integrating OpenTracing data emitted by the Vert.x web framework into PurePathÂŽ distributed traces.
VictorOps logo
VictorOps
Incident management platform that combines the power of people and data to embolden DevOps teams.
VMware logo
VMware
Monitor health and performance of VMware virtual machines from the system’s perspective.
VMware Cloud on AWS logo
VMware Cloud on AWS
Integrated cloud offering jointly developed by Amazon Web Services (AWS) and VMware.
soon
VMware ESXi Host logo
VMware ESXi Host
Monitor health and performance of VMware ESXi virtual machines from the system’s perspective.
VMware Horizon logo
VMware Horizon
Gather metrics from your VMware Horizon gateways, connection servers, domains, farms, event databases and Remote Desktop Services (RDS)
VMware Tanzu logo
VMware Tanzu
Dynatrace & VMware Tanzu – accelerate adoption automatic, AI-powered; TAS, TKG, hybrid, multi-cloud, automated DevOps continuous CD.
VMware Unified Access Gateway logo
Gather connection metrics for your VMware UAG (Unified Access Gateway)
VMware VCenter Alarms logo
Collects VCenter triggered alarms into Dynatrace
VMware vCenter Server logo
Monitor health and performance of VMware vCenter Server virtual machines from the system’s perspective.
VMware vSAN logo
VMware vSAN
Gather metrics about your VMware vSAN Datastores
WebHooks logo
WebHooks
Out-of-the-box integrations that automatically push problem notifications to third-party solutions.
WeChat Mini-Program Monitoring logo
ZonefoundZonefound
Integrated monitoring of business, performance, and user experience for WeChat Mini-Programs
Wildfly logo
Wildfly
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Windows logo
Windows
Group of several proprietary graphical operating system families, developed by Microsoft.
Windows Communication Foundation (WCF) logo
Free and open-source runtime in the .NET Framework for building connected, service-oriented apps.
Windows Scheduled Tasks logo
Monitor the state and execution of your tasks set up in Windows Task Scheduler.
Windows Server File System Quotas logo
Monitor the utilization of your File System Quotas in Windows Servers
WIPRO Holmes logo
WIPRO Holmes
WiproWipro
All your needs from building to monetization of heterogeneous AI solutions.
WordPress logo
WordPress
Content management system written in PHP and paired with a MySQL or MariaDB database.
WSO2 API Manager logo
WSO2 API Manager
A fully open-source, full lifecycle API Management solution.
Xamarin logo
Xamarin
Monitor mobile applications built with Microsofts's popular Xamarin platform running on iOS or Android.
Xcode logo
Xcode
Environment containing a suite for developing software for macOS, iOS, iPadOS, watchOS, and tvOS.
Xen logo
Xen
Monitor health and performance of Xen virtual machines from the system’s perspective.
xMatters logo
xMatters
xMatters powers the world’s most reliable customer experiences.
Yii logo
Yii
Automatically and intelligently monitor, analyze, and optimize your applications developed with Yii.
Zabbix hosts logo
Zabbix hosts
Bring events from your Zabbix Hosts into Dynatrace
Zabbix Integration logo
Zabbix Integration
AlanataAlanata
Monitoring consolidation - eliminate event storms, reduce MTTR using Zabbix hosts data and problems in Dynatrace leveraging Davis AI engine
Zenduty logo
Zenduty
YellowAntYellowAnt
Modern incident response with Dynatrace & Zenduty
ZigiOps - Integration Platform logo
ZigiWaveZigiWave
ZigiOps is a highly scalable no-code integration platform, which creates powerful integrations within minutes with security in mind.
ZK logo
ZK
Open-source Ajax Web application framework, written in Java.
