All
0 Results filtered by:
We couldn't find any results
You can search all listings, or try a different spelling or keyword. Still nothing? Dynatrace makes it easy to create custom apps.
Extend the platform,
empower your team.
Supplement network monitoring with event-based data reported via SNMP Traps.
ExtensionSNMP traps can be used to gain more details about the health state of your network devices. By adding event-based data to all the metrics reported in combination with dedicated SNMP extensions, you are able to diagnose the performance and availability issues even better.
Simply enable the extension and configure your device, so that SNMP traps can reach the Dynatrace SNMP listener.
Events
feature set in the monitoring configuration.This extension collects a count of SNMP traps every minute. Once data is produced, this is ingested as metric datapoints and subject to license consumption. Whether you are on a Classic or DPS license model, the measurement unit for metric ingestion is based on metric datapoints.
To estimate the amount of metric datapoints produced by your extension configuration, use the following list which gives you a number of metrics per feature set and a multiplier value depending on which entity the metric is split by. Add all of these up and you will have the number of datapoints produced every minute.
Events
1 x SNMP Traps DevicesAssuming there is 1 SNMP Trap Device being monitored (1 metric x 1 SNMP Trap Device), it will ingest:
1 x 60 = 60
metric datapoints per hour1 x 60 x 24 = 1,440
metric data points per day1 x 60 x 24 x 365 = 525,600
metric data points per dayThis extension also ingests trap events as logs. To calculate consumption, refer to the documentation depending on your licensing:
To troubleshoot this extension, use the guide in the Dynatrace Documentation.
Further information on configuring an SNMP trap extension can be found page.
Metric name | Metric key | Description | Unit |
Traps count | com.dynatrace.extension.snmp-traps-generic.traps.count | Number of traps received. | Count |
Gain insights into the performance of your F5 BIG-IP LTM and DNS solutions.
Monitor Cisco devices using SNMP to feed Dynatrace with metrics and alerts.
Gain insights into the performance of your network devices.
Gain insights into the performance of your Juniper networking solutions.
No release notes
