Extend the platform,
empower your team.
Monitor Redis Enterprise with the official Redis Prometheus exporter.
Extension by DynatraceThis extensions provides the ability to remotely monitor your Redis Enterprise Clusters, Databases, Nodes, Proxies, Replicas and Shards. Every minute, this extension polls metrics through the official Redis Prometheus exporter to ingest data about how each resource is performing.
This extension enables insights into the overall health of the Redis cluster and components.
This extension scrapes many of the metrics listed at: Redis Prometheus Metrics
Simply activate the extension in your environment using the in-product Hub, provide the necessary device configuration and you’re all set up.
Read more in the Dynatrace Prometheus Extension Documentation
This extension uses the Redis Enterprise Prometheus Endpoint to scrape and ingest metrics.
This Redis metrics_exporter component is enabled by default and listens on Port 8070.
In Dynatrace, create a new Monitoring Configuration and select 'Monitor Remotely without OneAgent" near the bottom of the Monitoring Source Screen.
https://redis.cluster:8070
. With auth if required.The Database name - label "bdb_name" is not enabled by default. Without this, Dynatrace will just use the database ID in dimensions and entity definitions.
To enable it for all databases on a cluster you have to issue the following commands:
ccs-cli hset cluster_settings metrics_exporter_expose_bdb_name enabled
supervisorctl restart metrics_exporter
The new labels will then be added to the Prometheus metrics once this setting is changed and the metrics_exporter process is restarted.
Redis Enterprise. Open-source Redis does not include the required metrics_exporter.
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Node Available Memory | node_available_memory | Amount of free memory in node (bytes) that is available for database provisioning | Byte |
Node Average Latency | node_avg_latency | Average latency of requests handled by endpoints on node (seconds); returned only when there is traffic | Second |
Node Client Connections | node_conns | Number of clients connected to endpoints on node | Count |
Node Outgoing Traffic | node_egress_bytes | Rate of outgoing network traffic to node (bytes/sec) | BytePerSecond |
Node Incoming Traffic | node_ingress_bytes | Rate of incoming network traffic to node (bytes/sec) | BytePerSecond |
Node Persistent Storage Available | node_persistent_storage_avail | Disk space available to RLEC processes on configured persistent disk (bytes) | Byte |
Node Persistent Storage Free | node_persistent_storage_free | Free disk space on configured persistent disk (bytes) | Byte |
Node Provisional Memory | node_provisional_memory | Amount of RAM that is available for provisioning to databases out of the total RAM allocated for databases | Byte |
Node Request Rate | node_total_req | Request rate handled by endpoints on node (ops/sec) | PerSecond |
Node Up Status | node_up | Node is part of the cluster and is connected | Count |
Listener AUTH Commands | listener_auth_cmds | Number of memcached AUTH commands sent to the DB | Count |
Listener AUTH Errors | listener_auth_errors | Number of error responses to memcached AUTH commands | Count |
Endpoint Client Connections | listener_conns | Number of clients connected to the endpoint | Count |
Last Command Request Time | listener_last_req_time | Time of last command sent to the DB | Count |
Last Command Response Time | listener_last_res_time | Time of last response sent from the DB | Count |
Client Connection Rate | listener_total_connections_received | Rate of new client connections to the endpoint (connections/sec) | PerSecond |
Endpoint Request Rate | listener_total_req | Request rate handled by the endpoint (ops/sec) | PerSecond |
Endpoint Response Rate | listener_total_res | Rate of all responses on the endpoint (ops/sec) | PerSecond |
Number of Database Responses | listener_total_started_res | Number of responses sent from the DB of all types | Count |
Endpoint Write Response Rate | listener_write_res | Rate of write responses on the endpoint (ops/sec) | PerSecond |
Endpoint Write Response Count | listener_write_started_res | Number of responses sent from the DB of type “write” | Count |
CRDB Incoming Compressed Traffic Rate | bdb_crdt_syncer_ingress_bytes | Rate of compressed incoming network traffic to CRDB (bytes/sec) | BytePerSecond |
CRDB Incoming Decompressed Traffic Rate | bdb_crdt_syncer_ingress_bytes_decompressed | Rate of decompressed incoming network traffic to CRDB (bytes/sec) | BytePerSecond |
CRDM Traffic Lag Time | bdb_crdt_syncer_local_ingress_lag_time | Lag time between the source and the destination (ms) for CRDB traffic | MilliSecond |
CRDB Syncer Status | bdb_crdt_syncer_status | Syncer status for CRDB traffic; 0 = in-sync, 1 = syncing, 2 = out of sync | Count |
Redis AOF Delayed Fsync | redis_aof_delayed_fsync | Number of times an AOF fsync caused delays in the redis main thread (inducing latency); This can indicate that the disk is slow or overloaded | Count |
Redis Blocked Clients | redis_blocked_clients | Count the clients waiting on a blocking call | Count |
Redis Connected Clients | redis_connected_clients | Number of client connections to the specific shard | Count |
Redis Up Status | redis_up | Shard is up and running | Count |
Redis Total Commands Processed | redis_total_commands_processed | Number of commands processed by the shard; Calculate the number of commands for a time period by comparing the value at different times | Count |
Redis Volatile Keys Average TTL | redis_db0_avg_ttl | Average TTL of all volatile keys | MilliSecond |
Redis Total Commands Received | redis_total_connections_received | Number of connections received by the shard; Calculate the number of connections for a time period by comparing the value at different times | Count |
Redis Used Memory | redis_used_memory | Memory used by shard (in bigredis this includes flash) (bytes) | Byte |
DB Read Latency Max | bdb_avg_read_latency_max | Highest value of average latency of read operations (seconds); returned only when there is traffic | Second |
DB Write Latency Max | bdb_avg_write_latency_max | Highest value of average latency of write operations (seconds); returned only when there is traffic | Second |
DB Client Connections | bdb_conns | Number of client connections to DB | Count |
DB Outgoing Traffic | bdb_egress_bytes | Rate of outgoing network traffic from the DB (bytes/sec) | BytePerSecond |
DB Incoming Traffic | bdb_ingress_bytes | Rate of incoming network traffic to the DB (bytes/sec) | BytePerSecond |
DB Memory Limit | bdb_memory_limit | Configured RAM limit for the database | Byte |
DB Request Rate | bdb_total_req | Rate of all requests on DB (ops/sec) | PerSecond |
Database Status | bdb_up | Database is up and running | Count |
DB Used Memory | bdb_used_memory | Memory used by db (in bigredis this includes flash) (bytes) | Byte |
DB Average Latency | bdb_avg_latency | Average latency of operations on the DB (seconds); returned only when there is traffic | Second |
DB Number of Keys | bdb_no_of_keys | Number of Keys in DB | Count |
DB Read Hits | bdb_read_hits | Rate of read operations accessing an existing key (ops/sec) | PerSecond |
DB Read Hits Max | bdb_read_hits_max | Highest value of rate of read operations accessing an existing key (ops/sec) | PerSecond |
DB Read Misses | bdb_read_misses | Rate of read operations accessing a non-existing key (ops/sec) | PerSecond |
Initial published extension.
Redis Enterprise metrics for:
