Automatically and intelligently monitor, analyze, and optimize your applications developed with Play Framework.
With Dynatrace you will get observability for all applications developed with the Play Framework framework including end-to-end distributed tracing, metrics and log insights. Additionally Dynatrace deep code level insights will give you CPU profiling insights including method hotspots, insights into calls to databases, error/exception analysis, and much more. Comprehensive out-of-the box metrics will give you insights into memory allocation, garbage collection, and thread behavior.
If Play Framework is running directly on a virtual machine, install OneAgent on that virtual machine to get started.
If Play Framework is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If Play Framework is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
