Volume state | netapp.ontap.volume.state | Volume state: error, mixed, offline, or online | Count |
Volume throughput (other) | netapp.ontap.volume.throughput.other.count | The volume's rate of throughput bytes observed at the storage object (other) | Byte |
Volume throughput (read) | netapp.ontap.volume.throughput.read.count | The volume's rate of throughput bytes observed at the storage object (read) | Byte |
Volume throughput (write) | netapp.ontap.volume.throughput.write.count | The volume's rate of throughput bytes observed at the storage object (write) | Byte |
Volume throughput (total) | netapp.ontap.volume.throughput.total.count | The volume's rate of throughput bytes observed at the storage object (total) | Byte |
Volume IOPS (other) | netapp.ontap.volume.iops.other.count | The volume's number of I/O operations observed at the storage object (other) | Count |
Volume IOPS (read) | netapp.ontap.volume.iops.read.count | The volume's number of I/O operations observed at the storage object (read) | Count |
Volume IOPS (write) | netapp.ontap.volume.iops.write.count | The volume's number of I/O operations observed at the storage object (write) | Count |
Volume IOPS (total) | netapp.ontap.volume.iops.total.count | The volume's number of I/O operations observed at the storage object (total) | Count |
Volume latency (total) | netapp.ontap.volume.latency.total | The volume's raw latency in microseconds observed at the storage object (total) | MicroSecond |
Volume latency (read) | netapp.ontap.volume.latency.read | The volume's raw latency in microseconds observed at the storage object (read) | MicroSecond |
Volume latency (write) | netapp.ontap.volume.latency.write | The volume's raw latency in microseconds observed at the storage object (write) | MicroSecond |
Volume latency (other) | netapp.ontap.volume.latency.other | The volume's raw latency in microseconds observed at the storage object (other) | MicroSecond |
Volume size | netapp.ontap.volume.size | Total provisioned size | Byte |
Volume space available | netapp.ontap.volume.available | The available space | Byte |
Volume space used | netapp.ontap.volume.used | Volume space used (including data and metadata) | Byte |
Volume space used percentage | netapp.ontap.volume.used_percent | Percentage of volume space used (including data and metadata) | Percent |
- | netapp.ontap.volume.files.maxiumum | - | - |
Files (inodes) | netapp.ontap.volume.files.used | Number of files (inodes) used for user-visible data permitted on the volume. | Count |
Files (inodes) used percentage | netapp.ontap.volume.files.used_percentage | Percentage of the maximum number of files used on the volume. | Percent |
