Get insights into Google Compute Engine metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Compute Engine services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 345 metrics that are specific to Google Compute Engine, like Dropped bytes, Dropped packets, Runnable task count, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Compute Engine logs.
Use preconfigured alerting.
Set custom alerts that trigger remediation workflows.
Google Compute Engine metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Compute Engine configuration:
This extension package contains:
Google VM Instance CPU utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
