Get insights into Google App Engine service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google App Engine services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 40 metrics that are specific to Google App Engine, like Monitoring Agent API Request Count, Logging Agent Log Entry Count, Logging Agent Retried Log Entry Writes Count, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google App Engine logs.
Use preconfigured alerting.
Set custom alerts that trigger remediation workflows.
Google App Engine metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google App Engine configuration:
This extension package contains:
Google App Engine Application CPU utilization [GCP], Google App Engine Instance CPU Utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
