Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
ElasticsearchElasticsearch
Elasticsearch
Elasticsearch
Monitor Elasticsearch Clusters, Nodes, Indexes, remotely or locally, via API.
Extension
Free trialDocumentation
Elasticsearch dashboardElasticsearch host KPIsCluster statusCluster nodes and indexesDisks and threads
  • Product information
  • Release notes
Overview
This extension remotely monitors your Elasticsearch Clusters, Nodes, and Indexes metrics, ingesteing metrics minutely. You can use the Unified Analysis screens to analyze Elasticseach clusters' health and drill down into individual metrics to identify the root cause of potential performance issues.
This is intended for users, who:
  • Want to monitor the health and performance of their Elasticsearch Clusters, Nodes, and Indexes.
  • Look for analysis support for Ops, IT and Network Admins.
This enables you to:
  • Monitor your Elasticsearch infrastructure using comprehensive unified analysis screens and dashboards.
  • Enable alerts based on detected anomalies.
Use cases
  • Monitor health and performance of your ElasticSearch cluster, using built-in analysis screens and easy-to-navigate dashboards
  • Root-cause analysis for Elasticsearch cluster, nodes and indexes performance issues.
Get started
  • In Dynatrace, download the Elasticsearch extension and click Add monitoring configuration next to an extension version under the Versions list.
  • Select the host you want to monitor then define the URL to the elasticsearch instance and the credentials to connect to it.
  • Finally select the feature sets containing the metrics you want to import.
Elasticsearch cluster access permissions required
The extension uses following Elasticsearch endpoints to scrape metrics:
  • /_cluster/health
  • /_all/_stats?level=shards
  • /_nodes/stats
  • /_alias
  • /_cat/shards
According to the Elasticsearch documentation, at least the
  • monitor cluster privilege and
  • monitor and view_index_metadata indices privileges
are required for the user defined in the extension monitoring configuration.
Details
The Elasticsearch extension is build on the new Extension 2.0 framework utilizing a built-in Elasticsearch metric exporter. The Unified Analysis screens provide insight into the health and performance of your Elasticsearch clusters.
This extension package contains
  • Data source configuration for metric ingestion.
  • Topology and relationship definitions for Elasticsearch clusters and their Nodes, Indexes, Disks, and Thread Pools.
  • Unified analysis screens for every entity (Accessible from the dashboard)
  • An overview dashboard
  • Alerts for several key metrics
    • Total CPU Util > 85%
    • Filesystem Usage > 80%
    • Open File Descriptors > 80% of Max File Descriptors
    • Heap Used > 85%
    • Rejected Threads > 300
Compatibility information
  • This extension connects to the Elasticsearch cluster via API. The cluster needs to be reachable from the ActiveGate where the extension has been activated.
  • One Agent-instrumented host can run this extension too, so the Elasticsearch cluster can be monitored from OneAgent. pointing at the localhost network address.
    • However, if you activate extension on multiple hosts in the same cluster, you will receive the same cluster data multiple times. So - activate it only on one host in a cluster if you decide to run it locally.
  • This extension supports Elasticsearch version 8.0 or higher.
Q&A
Q: What is the DDU Consumption of this extension?
A: The formula for DDU consumption of the extension is:
 ((12 * number of Clusters)
+ (53 * number of Nodes)
+ (47 * number of Indexes)
+ ( 5 * number of Disks)
+ ( 5 * number of Thread Pools)) * 525.6 DDUs/year
DDU cost above does not include any possible Log events or Custom events triggered by the extension. For more information on this, please visit the DDU log event cost and DDU custom event cost pages.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
screen injections
2
metric metadata
151
alerts
5
metric query
29
screen layout
5
list screen layout
5
screen entities lists
6
screen chart groups
21
screen properties
5
dashboards
1
generic type
5
generic relationship
5
Feature sets
Heap Committed Byteselasticsearch_jvm_memory_committed_bytesHeap committed bytesByte
Garbage Collection Timeelasticsearch_jvm_gc_collection_seconds_sumGarbage collection time in secondsSecond
Garbage Collection Countelasticsearch_jvm_gc_collection_seconds_count.count-Count
Disk IOPSelasticsearch_filesystem_io_stats_device_operations_countAmount of disk IO operations per secondPerSecond
Disk Read Rateelasticsearch_filesystem_io_stats_device_read_operations_countAmount of read operations per secondPerSecond
Disk Write Rateelasticsearch_filesystem_io_stats_device_write_operations_countAmount of write operations per secondPerSecond
Heap Max Byteselasticsearch_jvm_memory_max_bytesHeap max bytesByte
Heap Used Byteselasticsearch_jvm_memory_used_bytesHeap used bytesByte
Filter Cache Sizeelasticsearch_indices_filter_cache_memory_size_bytesSize of the filter cache in bytesByte
Fielddata Memory Usageelasticsearch_indices_fielddata_memory_size_bytesFielddata memory usage in bytesByte
Kilobytes Read From Diskelasticsearch_filesystem_io_stats_device_read_size_kilobytes_sumTotal kilobytes read from diskKiloByte
Kilobytes Written To Diskelasticsearch_filesystem_io_stats_device_write_size_kilobytes_sumTotal kilobytes written to diskKiloByte
Filesystem Sizeelasticsearch_filesystem_data_size_bytesFilesystem size in bytesByte
Filesystem Freeelasticsearch_filesystem_data_free_bytesFilesystem available in bytesByte
Breaker Limit Sizeelasticsearch_breakers_limit_size_bytesCircuit Breaker Limit SizeByte
Breaker Trippedelasticsearch_breakers_trippedWhether or not a breaker trippedState
Total Documents By Shardelasticsearch_indices_shards_docsTotal documents by shardCount
Deleted Documents By Shardelasticsearch_indices_shards_docs_deletedDeleted documents by shardCount
Shard Sizeelasticsearch_indices_shards_store_size_in_bytesShard size in bytesByte
Deleted Documentselasticsearch_indices_deleted_docs_totalTotal count of deleted documentsCount
Indexing Documentselasticsearch_index_stats_index_currentCount of documents that are currently being indexedCount
Merge Stopped Timeelasticsearch_index_stats_merge_stopped_time_seconds_totalTotal large merge stopped time in secondsSecond
Merge Throttle Timeelasticsearch_index_stats_merge_throttle_time_seconds_totalTotal merge I/O throttle time in secondsSecond
Initializing Shardselasticsearch_cluster_health_initializing_shardsNumber of initializing shardsCount
Unassigned Shardselasticsearch_cluster_health_unassigned_shardsNumber of unassigned shardsCount
Relocating Shardselasticsearch_cluster_health_relocating_shardsNumber of relocating shardsCount
Delayed Unassigned Shardselasticsearch_cluster_health_delayed_unassigned_shardsNumber of delayed unassigned shardsCount
Data nodeselasticsearch_cluster_health_number_of_data_nodesNumber of data nodesCount
Fielddata Evictionselasticsearch_index_stats_fielddata_evictions_totalNumber of fielddata evictionsCount
Fielddata Memoryelasticsearch_index_stats_fielddata_memory_bytes_totalAmount of fielddata memory in bytesByte
Query Cache Memoryelasticsearch_index_stats_query_cache_memory_bytes_totalAmount of query cache memory in bytesByte
Query Cache Sizeelasticsearch_index_stats_query_cache_sizeSize of the query cache in bytesByte
Request Cache Sizeelasticsearch_index_stats_request_cache_memory_bytes_totalRequest cache size in bytesByte
Free Memoryelasticsearch_os_mem_free_bytesFree memory in bytesByte
Used Memoryelasticsearch_os_mem_used_bytesUsed memory in bytesByte
Query Countelasticsearch_index_stats_search_query_total.countTotal query countCount
Query Timeelasticsearch_index_stats_search_query_time_seconds_totalQuery time in secondsSecond
Fetch Countelasticsearch_index_stats_search_fetch_total.countTotal fetch countCount
Fetch Timeelasticsearch_index_stats_search_fetch_time_seconds_totalFetch time in secondsSecond
Get Countelasticsearch_index_stats_get_total.countTotal get countCount
Get Timeelasticsearch_index_stats_get_time_seconds_totalGet time in secondsSecond
Indexing Countelasticsearch_index_stats_indexing_index_total.countTotal indexing countCount
Indexing Timeelasticsearch_index_stats_indexing_index_time_seconds_totalIndexing time in secondsSecond
Refresh Countelasticsearch_index_stats_refresh_total.countTotal refresh countCount
Refresh Timeelasticsearch_index_stats_refresh_time_seconds_totalRefresh time in secondsSecond
Flush Countelasticsearch_index_stats_flush_total.countTotal flush countCount
Flush Timeelasticsearch_index_stats_flush_time_seconds_totalFlush time in secondsSecond
Delete Countelasticsearch_index_stats_indexing_delete_total.countTotal delete countCount
Delete Timeelasticsearch_index_stats_indexing_delete_time_seconds_totalDelete time in secondsSecond
Merge Countelasticsearch_index_stats_merge_total.countTotal merge countCount
Merge Timeelasticsearch_index_stats_merge_time_seconds_totalMerge time in secondsSecond
Indexing Throttle Timeelasticsearch_index_stats_indexing_throttle_time_seconds_totalIndexing throttle time in secondsSecond
Indexing No-op countelasticsearch_index_stats_indexing_noop_update_total.countTotal indexing no-op countCount
Scroll Timeelasticsearch_index_stats_search_scroll_time_seconds_totalScroll time in secondsSecond
Scroll Countelasticsearch_index_stats_search_scroll_total.countTotal scroll countCount
Warmer Countelasticsearch_index_stats_warmer_total.countTotal warmer countCount
Warmer Timeelasticsearch_index_stats_warmer_time_seconds_totalWarmer time in secondsSecond
Search Suggest Countelasticsearch_index_stats_search_suggest_total.countTotal search suggest countCount
Search Suggest Timeelasticsearch_index_stats_search_suggest_time_seconds_totalSearch suggest time in secondsSecond
Network Received byteselasticsearch_transport_rx_size_bytes_totalAmount of bytes receivedByte
Network sent byteselasticsearch_transport_tx_size_bytes_totalAmount of bytes sentByte
Breaker Estimated Sizeelasticsearch_breakers_estimated_size_bytesCircuit breaker estimated size in bytesByte
Breaker Overheadelasticsearch_breakers_overheadCircuit breaker overheadCount
Query Cache Sizeelasticsearch_indices_query_cache_memory_size_bytesSize of the query cache in bytesCount
Request Cache Sizeelasticsearch_indices_request_cache_memory_size_bytesSize of the request cache in bytesByte
Fielddata Evictionselasticsearch_indices_fielddata_evictionsNumber of fielddata evictionsCount
Network Received Packetselasticsearch_transport_rx_packets_total.countAmount of packets receivedCount
Network Sent Packetselasticsearch_transport_tx_packets_total.countAmount of packets sentCount
Health Statuselasticsearch_cluster_health_statusStatus of cluster healthUnspecified
Number of Nodeselasticsearch_cluster_health_number_of_nodesNumber of nodes in a clusterCount
Active Shardselasticsearch_cluster_health_active_shardsNumber of active shardsCount
Active Primary Shardselasticsearch_cluster_health_active_primary_shardsNumber of active primary shardsCount
Pending Taskselasticsearch_cluster_health_number_of_pending_tasksNumber of pending TasksCount
Max Task Waiting Timeelasticsearch_cluster_health_task_max_waiting_in_queue_millisAmount of task waiting time in millisMilliSecond
Segmentselasticsearch_indices_segment_count_totalNumber of segmentsCount
Queued Threadselasticsearch_thread_pool_queue_count.gaugeCount of queued threadsCount
Active Threadselasticsearch_thread_pool_active_count.gaugeCount of active threadsCount
Completed Threadselasticsearch_thread_pool_completed_count.gaugeCount of completed threadsCount
OS CPU Utilelasticsearch_os_cpu_percentOS cpu utilization percentPercent
Process CPU Utilelasticsearch_process_cpu_percentProcess cpu utilization percentPercent
Node Roleselasticsearch_nodes_rolesNode rolesCount
Total Documentselasticsearch_indices_docsTotal count of documentsCount
Documents Deletedelasticsearch_indices_docs_deletedTotal count of deleted documentsCount
Shardselasticsearch_node_shards_totalTotal count of shardsCount
Store Throttle Timeelasticsearch_indices_store_throttle_time_seconds_totalIndex store throttle time in secondsSecond
Translog Operationselasticsearch_indices_translog_operationsTotal translog operationsCount
Translog Sizeelasticsearch_indices_translog_size_in_bytesTranslog size in bytesByte
Max File Descriptorselasticsearch_process_max_files_descriptorsMax file descriptorsCount
Open File Descriptorselasticsearch_process_open_files_count.gaugeOpen file descriptorsCount
CPU Load Average(1m)elasticsearch_os_load1CPU load average over 1 minuteCount
CPU Load Average(5m)elasticsearch_os_load5CPU load average over 5 minutesCount
CPU Load Average(15m)elasticsearch_os_load15CPU load average over 15 minutesCount
Query Cache Caches Countelasticsearch_index_stats_query_cache_caches_total.countAmount of caches in the query cacheCount
Query Cache Hitselasticsearch_index_stats_query_cache_hits_totalAmount of query cache hitsCount
Query Cache Misseselasticsearch_index_stats_query_cache_misses_totalAmount of query cache missesCount
Query Cache Evictionselasticsearch_index_stats_query_cache_evictions_totalAmount of query cache evictionsCount
Request Cache Evictionselasticsearch_index_stats_request_cache_evictions_totalAmount of request cache evictionsCount
Request Cache Hitselasticsearch_index_stats_request_cache_hits_totalAmount of request cache hitsCount
Request Cache Misseselasticsearch_index_stats_request_cache_misses_totalAmount of request cache missesCount
Aliaselasticsearch_indices_aliasesThe index aliasUnspecified
Total Documentselasticsearch_indices_docs_totalTotal count of documentsCount
Documents Without Replicaselasticsearch_indices_docs_primaryTotal count of documnets without replicasCount
Index Sizeelasticsearch_indices_store_size_bytes_totalIndex size in bytesByte
Threadselasticsearch_thread_pool_threads_count.gaugeCount of threadsCount
Rejected Threadselasticsearch_thread_pool_rejected_count.gaugeCount of rejected threadsCount
Query Countelasticsearch_indices_search_query_total.countTotal query countCount
Query Timeelasticsearch_indices_search_query_time_secondsQuery time in secondsSecond
Fetch Countelasticsearch_indices_search_fetch_total.countTotal fetch countCount
Fetch Timeelasticsearch_indices_search_fetch_time_secondsFetch time in secondsSecond
Get Countelasticsearch_indices_get_total.countTotal get countCount
Get Timeelasticsearch_indices_get_time_secondsGet time in secondsSecond
Indexing Countelasticsearch_indices_indexing_index_total.countTotal indexing countCount
Indexing Timeelasticsearch_indices_indexing_index_time_seconds_totalIndexing time in secondsSecond
Refresh Countelasticsearch_indices_refresh_total.countTotal refresh countCount
Refresh Timeelasticsearch_indices_refresh_time_seconds_totalRefresh time in secondsSecond
Flush Countelasticsearch_indices_flush_total.countTotal flush countCount
Flush Timeelasticsearch_indices_flush_time_secondsFlush time in secondsSecond
Delete Countelasticsearch_indices_delete_total.countTotal delete countCount
Delete Timeelasticsearch_indices_delete_time_secondsDelete time in secondsSecond
Merge Countelasticsearch_indices_merges_total.countTotal merge countCount
Merge Timeelasticsearch_indices_merges_total_time_seconds_totalMerge time in secondsSecond
Merge Sizeelasticsearch_indices_merges_total_size_bytes_totalMerge size in bytesByte
Customer story BT
“When the system went live, it felt like we had a thousand log analysts helping us understand where to focus efforts to improve our services.”
Chris Deane
Senior Engineering Manager, Cloud Platform Services
Full version history
ReleaseDate
Patch level changes
  • Fixed issues with endpoint authentication under certain circumstances
  • Fixed Number of nodes metrics value reporting when nodes share the same host
  • Fixed inconsistent Query time metric value reporting
New features
  • Credentials vault support has been added. Now user name and password required to connect to your ElasticSearch can be stored in a compliant way in the Dynatrace Credentials vault
Breaking change After adopting this release, you have to recreate your monitoring configuration. Apologies for inconvenience, but Credentials vault support change comes with such consequence.
Patch level changes:
  • Support for filtering metrics by Management Zones
  • Fix issue with fastcheck using the wrong 'endpoint' variable
  • Fixed a wrong conditional which prevented shards info to be collected
Patch level changes
  • When the Elasticsearch API is publicly accessible, no username or password is required.
  • Added a check to verify if username and password are set before setting a basic authentication type
New features:
  • support for API token-based authentication to the Elasticsearch endpoint
New features
  • Added support for proxy in the remote ElasticSearch cluster connection
Patch level changes
  • Fixed SAME_AS relationship between OneAgent-monitored host and server entities instantiated by this extension
This release changes the way how clusters are identified.
  • Now cluster UUID is used instead of cluster name for entity idPattern. This change is necessary to address situations when extension monitors two identical clusters with identical cluster name node names, deployed in different environments, e.g. prod and dev.
This is a breaking change: entities created by previous version of the extension will not be continued and new entities will be created after the extension update. This may affect your custom dashboards and alerts if you created any - they may need an update too.
Additionally, in this release:
  • Fixed issue with fastcheck failing due to activation schema parsing error.
Fixed issues with querying endpoints quietly failing. Updated node idPattern to be unique across clusters, so monitoring on multi-cluster, multi-node performance retains correct drill downs and topological relationships.
Initial release of the Prometheus-based Elasticsearch monitoring extension. Uses commonly available APIs, no need to enable Prometheus to monitor Elasticsearch.
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
0 Results filtered by:
Reach out to certified Dynatrace partners to solve your unique use-case
Moviri logo
Moviri
Certified individuals: 14
Advanced Sales Partner
Alanata logo
Alanata
Certified individuals: 30Endorsements: Services Endorsed Partner
Premier Sales Partner
Spica Solutions logo
Spica Solutions
Authorized Sales Partner
Matrix logo
Matrix
Omnilogy logo
Omnilogy
Certified individuals: 38Endorsements: Services Endorsed Partner
AHEAD logo
AHEAD
Certified individuals: 8
Arctiq logo
Arctiq
Certified individuals: 19
Eviden logo
Eviden
Certified individuals: 79Endorsements: Services Endorsed Partner
Phenisys logo
Phenisys
Certified individuals: 32Endorsements: Services Endorsed Partner
Accenture logo
Accenture
Certified individuals: 156
AsiaPac Technology Pte Ltd logo
AskMe Solutions & Consultants Co Ltd logo
Asper Technologia logo
Asper Technologia
Certified individuals: 20
Avocado logo
Avocado
Certified individuals: 9
avodaq AG logo
avodaq AG
Certified individuals: 31Endorsements: Services Endorsed Partner
Carahsoft logo
Carahsoft
Certified individuals: 21
Deutsche Telekom MMS gmbh logo
Certified individuals: 18Endorsements: Services Endorsed Partner
DPM logo
DPM
Certified individuals: 30Endorsements: Services Endorsed Partner, SaaS Upgrade specialization
DXC logo
DXC
Certified individuals: 341
Evolane logo
Evolane
Certified individuals: 29
Galaxy Software Services Corporation (GSS) logo
ISATEC logo
ISATEC
Certified individuals: 20Endorsements: Services Endorsed Partner
Konsalt logo
Konsalt
Certified individuals: 13
Kyndryl logo
Kyndryl
Certified individuals: 202
PRAGMA INFORMATICA SA logo
Certified individuals: 10
PT. Mitra Integrasi Informatika logo
Certified individuals: 24
Scala logo
Scala
Spindox logo
Spindox
Certified individuals: 11
TestCrew logo
TestCrew
TI724 logo
TI724
Tsoft logo
Tsoft
VS Data logo
VS Data
Certified individuals: 12
Your Compass logo
Your Compass
Certified individuals: 68Endorsements: Services Endorsed Partner, CloudOps specialization
