Extend the platform,
empower your team.
Monitor Elasticsearch Clusters, Nodes, Indexes, remotely or locally, via API.
ExtensionThis extension remotely monitors your Elasticsearch Clusters, Nodes, and Indexes metrics, ingesteing metrics minutely. You can use the Unified Analysis screens to analyze Elasticseach clusters' health and drill down into individual metrics to identify the root cause of potential performance issues.
This is intended for users, who:
This enables you to:
The extension uses following Elasticsearch endpoints to scrape metrics:
According to the Elasticsearch documentation, at least the
are required for the user defined in the extension monitoring configuration.
The Elasticsearch extension is build on the new Extension 2.0 framework utilizing a built-in Elasticsearch metric exporter. The Unified Analysis screens provide insight into the health and performance of your Elasticsearch clusters.
A: The formula for DDU consumption of the extension is:
((12 * number of Clusters)
+ (53 * number of Nodes)
+ (47 * number of Indexes)
+ ( 5 * number of Disks)
+ ( 5 * number of Thread Pools)) * 525.6 DDUs/year
DDU cost above does not include any possible Log events or Custom events triggered by the extension. For more information on this, please visit the DDU log event cost and DDU custom event cost pages.
Metric name | Metric key | Description | Unit |
Initializing Shards | elasticsearch_cluster_health_initializing_shards | Number of initializing shards | Count |
Unassigned Shards | elasticsearch_cluster_health_unassigned_shards | Number of unassigned shards | Count |
Relocating Shards | elasticsearch_cluster_health_relocating_shards | Number of relocating shards | Count |
Delayed Unassigned Shards | elasticsearch_cluster_health_delayed_unassigned_shards | Number of delayed unassigned shards | Count |
Data nodes | elasticsearch_cluster_health_number_of_data_nodes | Number of data nodes | Count |
Total Documents By Shard | elasticsearch_indices_shards_docs | Total documents by shard | Count |
Deleted Documents By Shard | elasticsearch_indices_shards_docs_deleted | Deleted documents by shard | Count |
Shard Size | elasticsearch_indices_shards_store_size_in_bytes | Shard size in bytes | Byte |
Deleted Documents | elasticsearch_indices_deleted_docs_total | Total count of deleted documents | Count |
Indexing Documents | elasticsearch_index_stats_index_current | Count of documents that are currently being indexed | Count |
Merge Stopped Time | elasticsearch_index_stats_merge_stopped_time_seconds_total | Total large merge stopped time in seconds | Second |
Merge Throttle Time | elasticsearch_index_stats_merge_throttle_time_seconds_total | Total merge I/O throttle time in seconds | Second |
Breaker Limit Size | elasticsearch_breakers_limit_size_bytes | Circuit Breaker Limit Size | Byte |
Breaker Tripped | elasticsearch_breakers_tripped | Whether or not a breaker tripped | State |
Filesystem Size | elasticsearch_filesystem_data_size_bytes | Filesystem size in bytes | Byte |
Filesystem Free | elasticsearch_filesystem_data_free_bytes | Filesystem available in bytes | Byte |
Kilobytes Read From Disk | elasticsearch_filesystem_io_stats_device_read_size_kilobytes_sum | Total kilobytes read from disk | KiloByte |
Kilobytes Written To Disk | elasticsearch_filesystem_io_stats_device_write_size_kilobytes_sum | Total kilobytes written to disk | KiloByte |
Filter Cache Size | elasticsearch_indices_filter_cache_memory_size_bytes | Size of the filter cache in bytes | Byte |
Fielddata Memory Usage | elasticsearch_indices_fielddata_memory_size_bytes | Fielddata memory usage in bytes | Byte |
Heap Max Bytes | elasticsearch_jvm_memory_max_bytes | Heap max bytes | Byte |
Heap Used Bytes | elasticsearch_jvm_memory_used_bytes | Heap used bytes | Byte |
Disk IOPS | elasticsearch_filesystem_io_stats_device_operations_count | Amount of disk IO operations per second | PerSecond |
Disk Read Rate | elasticsearch_filesystem_io_stats_device_read_operations_count | Amount of read operations per second | PerSecond |
Disk Write Rate | elasticsearch_filesystem_io_stats_device_write_operations_count | Amount of write operations per second | PerSecond |
Heap Committed Bytes | elasticsearch_jvm_memory_committed_bytes | Heap committed bytes | Byte |
Garbage Collection Time | elasticsearch_jvm_gc_collection_seconds_sum | Garbage collection time in seconds | Second |
Garbage Collection Count | elasticsearch_jvm_gc_collection_seconds_count.count | - | Count |
Query Count | elasticsearch_indices_search_query_total.count | Total query count | Count |
Query Time | elasticsearch_indices_search_query_time_seconds | Query time in seconds | Second |
Fetch Count | elasticsearch_indices_search_fetch_total.count | Total fetch count | Count |
Fetch Time | elasticsearch_indices_search_fetch_time_seconds | Fetch time in seconds | Second |
Get Count | elasticsearch_indices_get_total.count | Total get count | Count |
Get Time | elasticsearch_indices_get_time_seconds | Get time in seconds | Second |
Indexing Count | elasticsearch_indices_indexing_index_total.count | Total indexing count | Count |
Indexing Time | elasticsearch_indices_indexing_index_time_seconds_total | Indexing time in seconds | Second |
Refresh Count | elasticsearch_indices_refresh_total.count | Total refresh count | Count |
Refresh Time | elasticsearch_indices_refresh_time_seconds_total | Refresh time in seconds | Second |
Flush Count | elasticsearch_indices_flush_total.count | Total flush count | Count |
Flush Time | elasticsearch_indices_flush_time_seconds | Flush time in seconds | Second |
Delete Count | elasticsearch_indices_delete_total.count | Total delete count | Count |
Delete Time | elasticsearch_indices_delete_time_seconds | Delete time in seconds | Second |
Merge Count | elasticsearch_indices_merges_total.count | Total merge count | Count |
Merge Time | elasticsearch_indices_merges_total_time_seconds_total | Merge time in seconds | Second |
Merge Size | elasticsearch_indices_merges_total_size_bytes_total | Merge size in bytes | Byte |
Threads | elasticsearch_thread_pool_threads_count.gauge | Count of threads | Count |
Rejected Threads | elasticsearch_thread_pool_rejected_count.gauge | Count of rejected threads | Count |
Alias | elasticsearch_indices_aliases | The index alias | Unspecified |
Total Documents | elasticsearch_indices_docs_total | Total count of documents | Count |
Documents Without Replicas | elasticsearch_indices_docs_primary | Total count of documnets without replicas | Count |
Index Size | elasticsearch_indices_store_size_bytes_total | Index size in bytes | Byte |
Query Cache Caches Count | elasticsearch_index_stats_query_cache_caches_total.count | Amount of caches in the query cache | Count |
Query Cache Hits | elasticsearch_index_stats_query_cache_hits_total | Amount of query cache hits | Count |
Query Cache Misses | elasticsearch_index_stats_query_cache_misses_total | Amount of query cache misses | Count |
Query Cache Evictions | elasticsearch_index_stats_query_cache_evictions_total | Amount of query cache evictions | Count |
Request Cache Evictions | elasticsearch_index_stats_request_cache_evictions_total | Amount of request cache evictions | Count |
Request Cache Hits | elasticsearch_index_stats_request_cache_hits_total | Amount of request cache hits | Count |
Request Cache Misses | elasticsearch_index_stats_request_cache_misses_total | Amount of request cache misses | Count |
CPU Load Average(1m) | elasticsearch_os_load1 | CPU load average over 1 minute | Count |
CPU Load Average(5m) | elasticsearch_os_load5 | CPU load average over 5 minutes | Count |
CPU Load Average(15m) | elasticsearch_os_load15 | CPU load average over 15 minutes | Count |
Max File Descriptors | elasticsearch_process_max_files_descriptors | Max file descriptors | Count |
Open File Descriptors | elasticsearch_process_open_files_count.gauge | Open file descriptors | Count |
Node Roles | elasticsearch_nodes_roles | Node roles | Count |
Total Documents | elasticsearch_indices_docs | Total count of documents | Count |
Documents Deleted | elasticsearch_indices_docs_deleted | Total count of deleted documents | Count |
Shards | elasticsearch_node_shards_total | Total count of shards | Count |
Store Throttle Time | elasticsearch_indices_store_throttle_time_seconds_total | Index store throttle time in seconds | Second |
Translog Operations | elasticsearch_indices_translog_operations | Total translog operations | Count |
Translog Size | elasticsearch_indices_translog_size_in_bytes | Translog size in bytes | Byte |
OS CPU Util | elasticsearch_os_cpu_percent | OS cpu utilization percent | Percent |
Process CPU Util | elasticsearch_process_cpu_percent | Process cpu utilization percent | Percent |
Queued Threads | elasticsearch_thread_pool_queue_count.gauge | Count of queued threads | Count |
Active Threads | elasticsearch_thread_pool_active_count.gauge | Count of active threads | Count |
Completed Threads | elasticsearch_thread_pool_completed_count.gauge | Count of completed threads | Count |
Health Status | elasticsearch_cluster_health_status | Status of cluster health | Unspecified |
Number of Nodes | elasticsearch_cluster_health_number_of_nodes | Number of nodes in a cluster | Count |
Active Shards | elasticsearch_cluster_health_active_shards | Number of active shards | Count |
Active Primary Shards | elasticsearch_cluster_health_active_primary_shards | Number of active primary shards | Count |
Pending Tasks | elasticsearch_cluster_health_number_of_pending_tasks | Number of pending Tasks | Count |
Max Task Waiting Time | elasticsearch_cluster_health_task_max_waiting_in_queue_millis | Amount of task waiting time in millis | MilliSecond |
Segments | elasticsearch_indices_segment_count_total | Number of segments | Count |
Network Received Packets | elasticsearch_transport_rx_packets_total.count | Amount of packets received | Count |
Network Sent Packets | elasticsearch_transport_tx_packets_total.count | Amount of packets sent | Count |
Query Cache Size | elasticsearch_indices_query_cache_memory_size_bytes | Size of the query cache in bytes | Count |
Request Cache Size | elasticsearch_indices_request_cache_memory_size_bytes | Size of the request cache in bytes | Byte |
Fielddata Evictions | elasticsearch_indices_fielddata_evictions | Number of fielddata evictions | Count |
Breaker Estimated Size | elasticsearch_breakers_estimated_size_bytes | Circuit breaker estimated size in bytes | Byte |
Breaker Overhead | elasticsearch_breakers_overhead | Circuit breaker overhead | Count |
Network Received bytes | elasticsearch_transport_rx_size_bytes_total | Amount of bytes received | Byte |
Network sent bytes | elasticsearch_transport_tx_size_bytes_total | Amount of bytes sent | Byte |
Query Count | elasticsearch_index_stats_search_query_total.count | Total query count | Count |
Query Time | elasticsearch_index_stats_search_query_time_seconds_total | Query time in seconds | Second |
Fetch Count | elasticsearch_index_stats_search_fetch_total.count | Total fetch count | Count |
Fetch Time | elasticsearch_index_stats_search_fetch_time_seconds_total | Fetch time in seconds | Second |
Get Count | elasticsearch_index_stats_get_total.count | Total get count | Count |
Get Time | elasticsearch_index_stats_get_time_seconds_total | Get time in seconds | Second |
Indexing Count | elasticsearch_index_stats_indexing_index_total.count | Total indexing count | Count |
Indexing Time | elasticsearch_index_stats_indexing_index_time_seconds_total | Indexing time in seconds | Second |
Refresh Count | elasticsearch_index_stats_refresh_total.count | Total refresh count | Count |
Refresh Time | elasticsearch_index_stats_refresh_time_seconds_total | Refresh time in seconds | Second |
Flush Count | elasticsearch_index_stats_flush_total.count | Total flush count | Count |
Flush Time | elasticsearch_index_stats_flush_time_seconds_total | Flush time in seconds | Second |
Delete Count | elasticsearch_index_stats_indexing_delete_total.count | Total delete count | Count |
Delete Time | elasticsearch_index_stats_indexing_delete_time_seconds_total | Delete time in seconds | Second |
Merge Count | elasticsearch_index_stats_merge_total.count | Total merge count | Count |
Merge Time | elasticsearch_index_stats_merge_time_seconds_total | Merge time in seconds | Second |
Indexing Throttle Time | elasticsearch_index_stats_indexing_throttle_time_seconds_total | Indexing throttle time in seconds | Second |
Indexing No-op count | elasticsearch_index_stats_indexing_noop_update_total.count | Total indexing no-op count | Count |
Scroll Time | elasticsearch_index_stats_search_scroll_time_seconds_total | Scroll time in seconds | Second |
Scroll Count | elasticsearch_index_stats_search_scroll_total.count | Total scroll count | Count |
Warmer Count | elasticsearch_index_stats_warmer_total.count | Total warmer count | Count |
Warmer Time | elasticsearch_index_stats_warmer_time_seconds_total | Warmer time in seconds | Second |
Search Suggest Count | elasticsearch_index_stats_search_suggest_total.count | Total search suggest count | Count |
Search Suggest Time | elasticsearch_index_stats_search_suggest_time_seconds_total | Search suggest time in seconds | Second |
Free Memory | elasticsearch_os_mem_free_bytes | Free memory in bytes | Byte |
Used Memory | elasticsearch_os_mem_used_bytes | Used memory in bytes | Byte |
Fielddata Evictions | elasticsearch_index_stats_fielddata_evictions_total | Number of fielddata evictions | Count |
Fielddata Memory | elasticsearch_index_stats_fielddata_memory_bytes_total | Amount of fielddata memory in bytes | Byte |
Query Cache Memory | elasticsearch_index_stats_query_cache_memory_bytes_total | Amount of query cache memory in bytes | Byte |
Query Cache Size | elasticsearch_index_stats_query_cache_size | Size of the query cache in bytes | Byte |
Request Cache Size | elasticsearch_index_stats_request_cache_memory_bytes_total | Request cache size in bytes | Byte |
New features
Breaking change After adopting this release, you have to recreate your monitoring configuration. Apologies for inconvenience, but Credentials vault support change comes with such consequence.
Patch level changes:
Patch level changes
New features:
New features
Patch level changes
This release changes the way how clusters are identified.
This is a breaking change: entities created by previous version of the extension will not be continued and new entities will be created after the extension update. This may affect your custom dashboards and alerts if you created any - they may need an update too.
Additionally, in this release:
Fixed issues with querying endpoints quietly failing. Updated node idPattern to be unique across clusters, so monitoring on multi-cluster, multi-node performance retains correct drill downs and topological relationships.
Initial release of the Prometheus-based Elasticsearch monitoring extension. Uses commonly available APIs, no need to enable Prometheus to monitor Elasticsearch.
