Automatically and intelligently monitor, analyze, and optimize your applications developed with Jetty.
With Dynatrace, you can get observability for all applications and microservices deployed in your Jetty web server, including automatic end-to-end tracing, metrics and log insights. Dynatrace deep code level insights will give you CPU profiling insights including method hotspots, insights into calls to databases, error/exception analysis, and much more. Comprehensive out-of-the-box metrics will give you insights into memory allocation, garbage collection, and thread behavior.
If your Jetty runs on a virtual machine or bare-metal, install OneAgent on it to get started.
If your Jetty runs as a workload in Kubernetes or OpenShift, set up Dynatrace on Kubernetes or OpenShift.
Activate the OneAgent features to get tracing insight:
Activate the Jetty JMX extension] to get metric insight including events.
Activate log monitoring to get log insight.
