Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Active Directory extended monitoringActive Directory extended monitoring
Enhance Active Directory services monitoring with advanced metrics.
Extension
Free trialDocumentation
A snapshot of advanced AD metrics added to the dashboard
  • Product information
  • Release notes
Overview
This Dynatrace extension is a companion to the Active Directory services monitoring extension and provides an extended set of AD metrics, obtained through dedicated PowerShell cmdlets. This extension is not intended to work alone - it should be activated as a companion to the Active Directory services monitoring extension.
This is intended for users, who: Want to enhance the Active Directory services monitoring already implemented, with additional metrics that characterize:
  • AD replication status
  • DHCP server status and performance
  • System-dependent services status like time synchronization, volume health and network adapter health
  • LDAP BIND performance, ATQ thread usage, FSMO consistency, AD database disk usage
Use cases
Get started
Start with activating the Active Directory services monitoring extension. Then activate this extension, as it is intended to enhance the the Active Directory services monitoring.
When enabling this extension, you will be prompted for
  • User name and password to a Windows account
    • Able to logon locally
    • The account requires KEY_READ permission to read registry keys from HKLM\SYSTEM\CurrentControlSet\Services\NTDS\Parameters
    • The account requires permission to locally execute PowerShell cmdlets on the AD server
    • If collecting DHCP scope metrics, the user must be part of the DHCP Users group
    • Note that the account doesn't have to be the local account on an AD server. It can be domain account, but it requires local server privileges (registry key read, PS cmdlet run).
  • API token to the Dynatrace tenant on which the extension is activated
    • API token requires the settings.write, settings.read and entities.read scope
    • You need to prepare this token on your Dynatrace tenant (Settings > Integrations > Access tokens) and copy-paste this token into the extension configuration
Details
This extension is intended to work locally on the AD server. It executes:
  • PowerShell cmdlets, locally, to access Windows registry and specific AD metrics available only through PowerShell. Several of these metrics map to metrics available through commonly used DCDIAG tool.
  • API calls against the OS Service Monitoring, to report AD services availability
  • Log ingestion of the AD services logs
The extension package contains:
  • PowerShell snippets that retrieve metrics from the AD server
  • Alert templates for time skew monitoring, database file space, ATQ thread usage and replication consistency
  • Topology rules and screen definitions that weave this extension metrics into the entities managed by the Active Directory services monitoring extension
  • Log ingest rules, applied on AD hosts monitored with this extension, which further enable alerting on AD services-related issues logged into Windows logs system
  • Log processing rules, which enrich logs ingested with a field that flag AD-related context where content pertains to AD services
  • Log event extraction rules, which scan logs ingested for AD-related context and trigger alerts when log information carries potential AD issue or error information
Log ingest configured by this extension By default, this extension sets up log ingestion rules on hosts where it is installed. AD services logs are used to generate events and further alert on service anomalies and malfunctions.
You can disable log ingestion with a settings toggle in the extension configuration screen. Note that this setting does not control any other log ingestion rules that might have been configured on hosts where this extension has been activated.
Following log ingestion rules are being set up by this extension:
  • Windows Event Log
    • source is
      • Active Directory Web Services
      • DFS Replication
      • Directory Service
      • DNS Server
    • and log record level is in (ERROR WARN CRITICAL SEVERE)
  • Windows Log
    • source is
      • Windows Application Log
      • Windows System Log,
      • Security
And the following events from each event provider.
|Event Provider|Event IDs|
|Microsoft-Windows-ADFS|102, 104, 111, 356, 385, 509, 546, 549, 1034, 1036|
|Microsoft-Windows-Directory-Services-SAM|12299, 16643|
|Microsoft-Windows-Time-Service|21, 34, 36|
|DNSAPI|11150, 11162, 11151, 11155, 11163, 11167, 11154, 11166, 11152, 11153, 11164, 11165|
|Microsoft-Windows-Kerberos-Key-Distribution-Center|6, 15, 17|
|Microsoft-Windows-Security-Auditing|1102, 4616, 4621, 4649, 4660, 4675, 4707, 4710, 4712, 4715, 4716, 4730, 4740, 4743, 4764, 4766, 4771, 4866, 4867, 4935, 5025, 5030, 5034, 5035, 5037, 5139, 5141, 5483, 5484, 6008, 6145|
|Microsoft-Windows-CertificationAuthority|0, 3, 5, 9, 16, 17, 19, 20, 21, 22, 23, 28, 33, 34, 35, 38, 39, 40, 42, 43, 44, 48, 49, 51, 59, 60, 63, 65, 74, 75, 78, 82, 83, 86, 87, 90, 92, 94, 95, 96, 98, 99, 100, 102, 106, 107, 130, 132|
|Microsoft-Windows-OnlineResponder|39, 60, 92|
Compatibility information
  • This extension is intended as a companion to the Active Directory services monitoring extension. with advanced metrics.
  • Only on-premises Active Directory deployments are supported.
  • Azure AD is not supported.
  • Verified with Windows Server 2016, 2019 and 2022
  • Required minimum PowerShell version on AD servers is 5.x and above
Q&A
Q: What is the DDU Consumption of this extension?
A: The formula for DDU consumption of the extension is:
 ( 10
+ (17 * number of Domain Controllers)
+ (11 * number of DHCP servers)
+ ( 2 * number of LDAP instances)
 )  * 525.6 DDUs/year
Typical consumption for a single-domain AD server, hosting one DHCP server and one LDAP instance, amounts to 21,024 DDUs/year
DDU cost above does not include log lines ingested any possible Log events or Custom events triggered by the extension. For more information on this, please visit the DDU log event cost and DDU custom event cost pages.
Q: Does this extension collect KPIs available from DCDIAG?
A: All in all - equivalents of the DCDIAG KPIs are available in Dynatrace:
  • NTDS Service - monitored through OneAgent OS Service Monitoring
  • Services - monitored through OneAgent OS Service Monitoring
  • Replications - similar data is available through parsing of the repadmin outputs, in this extension
  • FSMO KnowsOfRoleHolders - can be found as part of the FSMO role holder ping/LDAP metrics
  • Advertising - delivered by the FSMO role holder consistency metric
Q: Why do I need to provide separate credentials in this extension if OneAgent already runs under LocalSystem?
A: An account with additional permissions is required to run this extension due to the kind of metrics it collects. Although OneAgent typically runs as LocalSystem account, Python extensions run as LocalService. The LocalService account has the minimum privileges on the local computer which is why the extension requires an account with enough permissions to read a few registry keys and run cmdlets like repadmin and dcdiag.
Q: Why there is a need to grant KEY_READ permission to HKLM\SYSTEM\CurrentControlSet\Services\NTDS\Parameters?
A: KEY_READ permission to HKLM\SYSTEM\CurrentControlSet\Services\NTDS\Parameters is required to obtain following metrics:
active-directory.database.diskfree
active-directory.database.disk.total
active-directory.database.diskfree.total
active-directory.replication.consistency.status
Q: What is the Dynatrace API token used for?
A: API token is required to enable integration of the AD-related log ingestion and the OS service monitoring with OOTB host-level reporting. No metrics are ingested using the API token. API token is used to allow the services to be seen on the Dynatrace Host UA screen and the logs on the AD Instance UA screen.
Q: What do I need OS Service Monitoring for?
A: The extension utilizes the API token to add entries into the OneAgent's OS Service Monitoring. The OneAgent will ingest availibility metrics and alerts so you know when a critical service is down. In some cases log events can refer to the OS Service which emitted the event.
Q: Does the extension support Group Managed Service Accounts (gMSA)?
A: No the extension does not suport gMSA accounts. The extension can only use local or domain-joined accounts since gMSA accounts are not meant for interactive use. The extension works by impersonating the account provided in the monitoring configuration to execute commands in that user's security context. gMSA accounts cannot be impersonated and therefore aren't able to be used by the extension.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
metric query
1
screen logs cards
1
alerts
4
screen chart groups
12
screen properties
1
metric metadata
36
screen injections
12
generic relationship
2
generic type
6
screen layout
1
Feature sets
DHCP Scope Delay v4active-directory.dhcp.server.scope.delayDHCP Scope Delay v4 in millisecondsMilliSecond
DHCP Scope Addresses Free v4active-directory.dhcp.server.scope.addresses.freeNumber of DHCPv4 scope addresses freeCount
DHCP Scope Addresses Used v4active-directory.dhcp.server.scope.addresses.usedNumber of DHCPv4 scope addresses usedCount
DHCP Scope Addresses Reserved v4active-directory.dhcp.server.scope.addresses.reservedNumber of DHCPv4 scope addresses reservedCount
Percent of DHCP Scope Addresses Used v4active-directory.dhcp.server.scope.addresses.used.pctPercent of DHCPv4 scope addresses usedPercent
DHCP Scope Pending Offers v4active-directory.dhcp.server.scope.pending.offersNumber of DHCPv4 scope pending offersCount
Good Network Adapter Countactive-directory.network.goodadapter.totalThe number of enabled network adapters that can ping the Domain DNS Server.Count
Bad Network Adapter Countactive-directory.network.badadapter.totalThe number of enabled network adapters that cannot ping the Domain DNS Server.Count
Total Network Adapter Countactive-directory.network.adapter.totalThe total number of enabled network adapters.Count
Disk Free Spaceactive-directory.database.diskfree.totalFree disk space of the disk containing the database file.Byte
Total Disk Spaceactive-directory.database.disk.totalTotal disk space of the disk containing the AD database file.Byte
Disk Free Space Percentageactive-directory.database.diskfreePercent of free disk space of the disk containing the database file.Percent
ATQ Average Thread Usageactive-directory.atq.server.average.thread.usageAverage usage of threads in Domain Controller ATQPercent
Shared Resource Availableactive-directory.replication.shared.availablePercentage of replication shared resources that are availablePercent
Replication - Destination Deltaactive-directory.replication.destination.deltaReplication time delta between this server and the destination server.Second
Replication - Source Deltaactive-directory.replication.source.deltaReplication time delta between this server and the source server.Second
Replication Errorsactive-directory.replication.errors-Count
Replication Attemptsactive-directory.replication.total-Count
LDAP Bind Timeactive-directory.ldap.server.bindtime.millisTime taken to bind to the fsmo role holder using LDAPMilliSecond
LDAP Bind Availabilityactive-directory.ldap.bind.availabilityWhether or not the domain controller can bind to the domain DNS serverCount
Kerberos Replication Partner Countactive-directory.replication.partner.countKerberos replication partners count in Active Directory domainCount
Replication Queue Countactive-directory.replication.queue.countCount of items in replication queue by Active Directory Domain Controller monitorCount
Global Catalog Search Response Timeactive-directory.globalcatalog.searchtime.millisGlobal catalog search response time of Domain ControllerMilliSecond
Replication Consistency Statusactive-directory.replication.consistency.statusWhether or not strict replication consistency is enabledCount
Time Skew in secondsactive-directory.timeskew.secsTime difference between the local domain controller and a target domain controllerSecond
Lost and Found Objectsactive-directory.lostandfound.object.count.totalCount of lost and found objects by Active Directory Domain monitorCount
FSMO Role Holder Consistencyactive-directory.fsmoroleholder.consistencyWhether or not the domain controllers agree on who the FSMO role holders areCount
FSMO Checkactive-directory.fsmo.checkContains a 'message' dimension about whether or not the correct services can be found from the domain controllerCount
SYSVOL Healthactive-directory.sysvol.healthThe SYSVOL share's healthCount
DHCP Scope Addresses Free v6active-directory.dhcp.server.v6.scope.addresses.freeNumber of DHCPv6 scope addresses freeCount
DHCP Scope Addresses Used v6active-directory.dhcp.server.v6.scope.addresses.usedNumber of DHCPv6 scope addresses usedCount
DHCP Scope Addresses Reserved v6active-directory.dhcp.server.v6.scope.addresses.reservedNumber of DHCPv6 scope addresses reservedCount
Percent of DHCP Scope Addresses Used v6active-directory.dhcp.server.v6.scope.addresses.used.pctPercent of DHCPv6 scope addresses usedPercent
DHCP Scope Pending Advertises v6active-directory.dhcp.server.v6.scope.pending.advertisesNumber of DHCPv6 scope pending advertisesCount
Customer story Village Roadshow
“One of the biggest impacts of partnering with Dynatrace is the amount of time given back to our teams. There are no more sleepless nights on the weekends.”
Michael Fagan
Chief Transformation Officer
Related to Active Directory extended monitoring
Active Directory services logo
Monitor the health and performance of Microsoft Active Directory services.
Full version history
ReleaseDate
  • Fixed issue with replication metrics.
  • Fixed issue reading local configuration file.
Patch level changes:
  • Fix error where query method was trying to prematurely access the results cache
Note: breaking change. While upgrading to this release, you have to recreate your monitoring configurations.
New features:
  • Separate feature set replication-summary which controls metrics retrieved through repadmin/replsummary.
    • This lets you control and disable these specific metrics if you notice that running their retrievals takes too much time - this situation will likely manifest itself by gaps in metrics timeseries.
    • Less frequent data collection might be especially beneficial on highly loaded AD servers.
  • Choose frequency at which metrics are collected on AD servers.
    • Default is 1 minute.
    • Change it to less frequent collection, e.g. 5 minutes, if you see that extension execution time exceeds 1 minute - this situation will likely manifest itself by gaps in metrics timeseries.
Patch level changes
  • Fixed Lost&Found object counter - report number every minute instead of monotonically growing counter
  • Added missing ADCS log ingest activation toggle in settings
  • Updated Q&A with information on OS services monitoring and comprehensive list of imported log events
  • Fixed an issue with the is_read_only dimension having the wrong value
  • Replaced the Powershell script with a command so users that enforce Powershell script signing can get replication summary metrics
  • Fix issue with indexing the domain name returned by one of the WMI queries, which resulted in empty domain name reported
Enhancements:
  • Added monitoring config option for query interval
  • Added Credential Vault support
  • Fixed bug with services cleanup on shutdown
  • Added the source entity type for all metrics
  • Fixed bug with GC query in FSMO Check
  • Fix to improve execution time of complex metrics
  • TrustMonitor metric is based on log events now, as it might have many unique dimensions
  • Added hub tile information on log ingest rules set up by this extension
Now the extension supports running it on the AD non-server nodes, e.g. a separate DHCP server.
Fixed irregularities when accessing specific Registry keys required to obtain ReplicationConsistencyMetrics and DatabaseFileDiskSpaceMetrics.
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
0 Results filtered by:
Reach out to certified Dynatrace partners to solve your unique use-case
Moviri logo
Moviri
Certified individuals: 14
Advanced Sales Partner
Alanata logo
Alanata
Certified individuals: 30Endorsements: Services Endorsed Partner
Premier Sales Partner
Spica Solutions logo
Spica Solutions
Authorized Sales Partner
Matrix logo
Matrix
Omnilogy logo
Omnilogy
Certified individuals: 38Endorsements: Services Endorsed Partner
AHEAD logo
AHEAD
Certified individuals: 8
Arctiq logo
Arctiq
Certified individuals: 19
Eviden logo
Eviden
Certified individuals: 79Endorsements: Services Endorsed Partner
Phenisys logo
Phenisys
Certified individuals: 32Endorsements: Services Endorsed Partner
Accenture logo
Accenture
Certified individuals: 156
AsiaPac Technology Pte Ltd logo
AskMe Solutions & Consultants Co Ltd logo
Asper Technologia logo
Asper Technologia
Certified individuals: 20
Avocado logo
Avocado
Certified individuals: 9
avodaq AG logo
avodaq AG
Certified individuals: 31Endorsements: Services Endorsed Partner
Carahsoft logo
Carahsoft
Certified individuals: 21
Deutsche Telekom MMS gmbh logo
Certified individuals: 18Endorsements: Services Endorsed Partner
DPM logo
DPM
Certified individuals: 30Endorsements: Services Endorsed Partner, SaaS Upgrade specialization
DXC logo
DXC
Certified individuals: 341
Evolane logo
Evolane
Certified individuals: 29
Galaxy Software Services Corporation (GSS) logo
ISATEC logo
ISATEC
Certified individuals: 20Endorsements: Services Endorsed Partner
Konsalt logo
Konsalt
Certified individuals: 13
Kyndryl logo
Kyndryl
Certified individuals: 202
PRAGMA INFORMATICA SA logo
Certified individuals: 10
PT. Mitra Integrasi Informatika logo
Certified individuals: 24
Scala logo
Scala
Spindox logo
Spindox
Certified individuals: 11
TestCrew logo
TestCrew
TI724 logo
TI724
Tsoft logo
Tsoft
VS Data logo
VS Data
Certified individuals: 12
Your Compass logo
Your Compass
Certified individuals: 68Endorsements: Services Endorsed Partner, CloudOps specialization
