Extend the platform,
empower your team.
Synthetically monitor your device availability using ping and allows alerting.
ExtensionThe Synthetic monitor ping extension allows you to monitor the availability of devices with ping.
The Extension creates Third-Party Synthetic monitors that can be accessed via the Synthetic tool in the Dynatrace menu.
Features
The Extension must be installed both on an ActiveGate and on the Dynatrace Cluster. See Deploy an extension in our full documentation for more details. The ActiveGate needs to have the restInterface module enabled, which is the default behavior.
Extract the extension zip file to the plugin_deployment
folder at the root of the remote plugin module.
Linux:
unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment custom.remote.python.thirdparty_ping.zip
/opt/dynatrace
Windows:
%PROGRAMFILES%\dynatrace\remotepluginmodule\plugin_deployment
Tip: Make sure the unzipped folder is not nested inside another folder. The path should be in the form: \plugin_deployment\custom.remote.python.thirdparty_ping\<extension files>
Upload the same extension zip file to your tenant. The Extension configuration and upload UI is located at:
Settings > Monitored technologies > Custom extensions > Upload extension
Only update to this version once you are using ActiveGate version 1.279 or newer. No other changes are included.
No release notes
