Automatically and intelligently monitor, analyze, and optimize the performance of your virtual machine.
Dynatrace automatically detects all applications executed on the virtual machine including end-to-end tracing, metrics and log insights. Deep code-level insights combined with market leading profiling capabilities like method hotspots, error/exception analysis, and thread analysis help you to improve the robustness of virtual machines. Comprehensive metrics give you visibility into memory allocation, garbage collection, and thread behaviour.
If your virtual machine is running directly on a system, install OneAgent on that virtual machine to get started.
If your virtual machine is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your virtual machine is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
