Easily understand the health and performance of your SAP HANA databases.
Our SAP HANA database monitoring solution is based on a remote monitoring approach implemented as a Dynatrace ActiveGate extension. The extension queries SAP HANA databases for key performance and health. Captured metrics include infrastructure measures (CPU, Disk, and Network metrics) as well as details related to Backups, Savepoints, Replication, and more. Dynatrace's DAVIS AI then analyzes these metrics to provide anomaly and problem analysis.
This is intended for users, who:
This enables you to:
This extension connects remotely via an ActiveGate to your SAP HANA Database using the credentials provided. It pulls a variety of metrics via the Monitoring Views provided by the database itself.
PUBLIC
and MONITORING
rolesngdbc-2.14.7.jar
to this directory on all your ActiveGates in your desired group
C:\ProgramData\dynatrace\remotepluginmodule\agent\conf\userdata\libs
/var/lib/dynatrace/remotepluginmodule/agent/conf/userdata/libs
Then activate the extension in your environment using the in-product Hub, provide the necessary device configuration and you’re all set up.
Make generic databases queries to your Oracle, Postgres, MSSQL, MySQL, DB2, Informix or SAP HANA databases and send the metrics to Dynatrace.
Automatic problem detection and visibility into every user transaction, and insight into the performance of RFC without changing any code.
