Monitor all open source Redis instances in your Dynatrace environment on a single pane of glass.
Make all Redis instances part of the Dynatrace monitoring, adding the power of Davis to Redis in memory data structure store.
Monitors Redis instance performance within your Enterprise. In combination with the freely available "Prometheus Redis Exporter", you will be able to monitor all your (including unlicensed) Redis instances from within a single pain of glass. Plugin uses classic and "new" Dynatrace dashboards.
This plugin requires the Prometheus Redis Metrics Exporter to create the Prometheus layer
Plugin collects 100+ metric, collecting can be activated on the plugin per functional group. 6 most crucial metrics charts are available per instance on the generated dashboards.
