Automatic and intelligent observability for RabbitMQ with end-to-end traces of connected producers and consumers.
With Dynatrace you will get observability for the lightweight RabbitMQ message broker without touching any code through auto-instrumentation. Seamless end-to-end traces for connected producer and consumer services will help you to better understand potential anomalies that may impact your mission-critical applications. Comprehensive metrics will give you insights about the performance of queues and nodes. Events will point you to critical metric anomalies.
Get started for RabbitMQ messaging clients:
If your client application runs on a virtual machine or bare-metal, install OneAgent on it to get started.
If your client application runs as a workload in Kubernetes or OpenShift, set up Dynatrace on Kubernetes or OpenShift.
Activate the following OneAgent features to get full tracing insight:
Activate log monitoring to get full log insight.
Get started for RabbitMQ messaging servers:
If your messaging server runs on a virtual machine or bare-metal, install OneAgent on it to get started.
Activate the local extension for RabbitMQ or the Prometheus extension for RabbitMQ to get full metric insight including events.
Activate log monitoring to get log insight.
