Automatic and intelligent observability for MSMQ with end-to-end traces of connected producers and consumers.
With Dynatrace you can get observability for the MSMQ without touching any code thanks to auto-instrumentation. Seamless end-to-end traces for connected producer and consumer services will help you to better understand the potential anomalies that may impact your mission-critical applications. Comprehensive metrics give you insights about the performance of queues.
If your MSMQ is running directly on a virtual machine, install OneAgent on that virtual machine to get started.
If your MSMQ is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your MSMQ is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate the following OneAgent feature for MSMQ to get full tracing insight:
Activate the MSMQ Extension to get additional metrics, a custom MSMQ dashboard, and the ability to view MSMQ instances and queues on a Unified Analysis page. Metrics include:
Activate log monitoring to get full log insight.
