Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Dynatrace automatically detects all applications and microservices deployed in your application server and provides automatic end-to-end tracing, application server metrics and log insights. Dynatrace visualizes your web application and its dependencies from website to application to container, infrastructure and cloud. It diagnoses anomalies in real-time with AI and pinpoints the root-cause down to the broken code before your customers are even affected. Deep code-level insights combined with market-leading profiling capabilities like method hotspots, error/exception analysis, memory profiling, and thread analysis will help you leverage the robustness of your production environment.
If your WebSphere Application Server is running on a virtual machine directly, install OneAgent on that virtual machine to get started.
If your WebSphere Application Server is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your WebSphere Application Server is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed on it.
Automatic and intelligent end-to-end observability for Java applications.
