Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
IBM JVMIBM JVM
IBM JVM
IBM JVM
Automatically and intelligently monitor, analyze, and optimize the performance of your virtual machine.
Technology
Free trial
  • Product information
Overview
Dynatrace automatically detects all applications executed on the virtual machine including end-to-end tracing, metrics and log insights. Deep code-level insights combined with market leading profiling capabilities like method hotspots, error/exception analysis, and thread analysis help you to improve the robustness of virtual machines. Comprehensive metrics give you visibility into memory allocation, garbage collection, and thread behaviour.
Use cases
  • Capture every transaction, across every tier, without gaps or blind spots.
  • Improve the performance of your Java code with continuous insights into your applications.
  • Profile CPU, memory and thread problems with Dynatrace' industry leading production grade continous profiler.
  • Detect availability and performance problems across your stack proactively.
  • Monitor all your virtual machine metrics via Dynatrace's builtin JMX monitoring capability.
Get started
If your virtual machine is running directly on a system, install OneAgent on that virtual machine to get started.
If your virtual machine is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your virtual machine is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
Dynatrace
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
1 Results filtered by:
Composer logo
Composer
Simplify your Dynatrace Configuration
