Get insights into Google Cloud Spanner metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud Spanner services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 15 metrics that are specific to Google Cloud Spanner, like API requests, Bytes received by Cloud Spanner., API request rate, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud Spanner logs.
Use preconfigured alerting.
Set custom alerts that trigger remediation workflows.
Google Cloud Spanner metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Cloud Spanner configuration:
This extension package contains:
Google Cloud Spanner Instance CPU utilization [GCP], Google Cloud Spanner Instance storage utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
