Get insights into Google Network Topology metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Network Topology services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze metrics that are specific to Google Network Topology, like Number of probes.
Build custom dashboards for your cloud infrastructure.
Analyze Google Network Topology logs.
Set custom alerts that trigger remediation workflows.
Google Network Topology metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Network Topology configuration:
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
