Get insights into Google Kubernetes Engine metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Kubernetes Engine services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 116 metrics that are specific to Google Kubernetes Engine, like Log entries, Allocatable cores, CPU allocatable utilization, and more.
Use dashboard presets for immediate visibility into availability, usage, and performance of your Google Kubernetes Engine services.
Build custom dashboards for your cloud infrastructure.
Analyze Google Kubernetes Engine logs.
Set custom alerts that trigger remediation workflows.
Google Kubernetes Engine metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Kubernetes Engine configuration:
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
