Extend the platform,
empower your team.
Get insights into Google Cloud's operations suite metrics collected from the Google Operations API to ensure health of cloud infrastructure.
Extension by DynatraceThis Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud's operations suite services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
View and analyze 8 metrics that are specific to Google Cloud's operations suite, like Check passed, Content mismatch, Request latency, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud's operations suite logs.
Set custom alerts that trigger remediation workflows.
Google Cloud's operations suite metric and log ingestion requires advanced GCP integration.
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Content mismatch | cloud.gcp.monitoring_googleapis_com.uptime_check.content_mismatch | - | Unspecified |
Request latency | cloud.gcp.monitoring_googleapis_com.uptime_check.request_latency | - | MilliSecond |
Time until SSL certificate expires | cloud.gcp.monitoring_googleapis_com.uptime_check.time_until_ssl_cert_expires | - | Day |
Check passed | cloud.gcp.monitoring_googleapis_com.uptime_check.check_passed | - | Unspecified |
Exported log bytes | cloud.gcp.logging_googleapis_com.exports.byte_count | - | Byte |
Exported log entries failures | cloud.gcp.logging_googleapis_com.exports.error_count | - | Count |
Exported log entries | cloud.gcp.logging_googleapis_com.exports.log_entry_count | - | Count |
Spans Exported to BigQuery | cloud.gcp.cloudtrace_googleapis_com.bigquery_export.exported_span_count | - | Count |
Support for GCP overview
No release notes
