Get insights into Google Cloud Run service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud Run services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 11 metrics that are specific to Google Cloud Run, like Billable Instance Time, Container CPU Allocation, Container CPU Utilization, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud Run logs.
Set custom alerts that trigger remediation workflows.
Google Cloud Run metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Cloud Run configuration:
This extension package contains:
Google Cloud Run Revision Container CPU utilization [GCP], Google Cloud Run Revision Container memory utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
