Extend the platform,
empower your team.
Get insights into Google Cloud Run service metrics.
Extension by DynatraceThis Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud Run services. This extension combines all relevant data into pre-configured dashboards, providing alerting and event tracking.
View and analyze 11 metrics that are specific to Google Cloud Run, like Billable Instance Time, Container CPU Allocation, Container CPU Utilization, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud Run logs.
Set custom alerts that trigger remediation workflows.
Google Cloud Run metric and log ingestion requires advanced GCP integration.
This extension package contains:
Google Cloud Run Revision Container CPU utilization [GCP], Google Cloud Run Revision Container memory utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Below is a complete list of the feature sets provided in this version. To ensure a good fit for your needs, individual metrics can be activated and deactivated by your administrator during configuration.
Metric name | Metric key | Description | Unit |
Billable Instance Time | cloud.gcp.run_googleapis_com.container.billable_instance_time.count | - | Second |
Container CPU Allocation | cloud.gcp.run_googleapis_com.container.cpu.allocation_time.count | - | Second |
Container CPU Utilization | cloud.gcp.run_googleapis_com.container.cpu.utilizations | - | Percent |
Instance Count | cloud.gcp.run_googleapis_com.container.instance_count.gauge | - | Count |
Max Concurrent Requests | cloud.gcp.run_googleapis_com.container.max_request_concurrencies | - | Count |
Container Memory Allocation | cloud.gcp.run_googleapis_com.container.memory.allocation_time.count | - | GibiByte |
Container Memory Utilization | cloud.gcp.run_googleapis_com.container.memory.utilizations | - | Percent |
Received Bytes | cloud.gcp.run_googleapis_com.container.network.received_bytes_count | - | Byte |
Sent Bytes | cloud.gcp.run_googleapis_com.container.network.sent_bytes_count | - | Byte |
Request Count | cloud.gcp.run_googleapis_com.request_count | - | Count |
Request Latency | cloud.gcp.run_googleapis_com.request_latencies | - | MilliSecond |
Support for GCP overview
No release notes
