Extend the platform,
empower your team.
Get insights into Google Memorystore service metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
ExtensionThis Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Memorystore services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 31 metrics that are specific to Google Memorystore, like Blocked Clients, Connected Clients, Calls, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Memorystore logs.
Set custom alerts that trigger remediation workflows.
Google Memorystore metric and log ingestion requires advanced GCP integration.
Compatibility requirements
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
To add this extension to your environment:
Following GCP integration and Google Memorystore configuration:
Metric name | Metric key | Description | Unit |
Blocked Clients | cloud.gcp.redis_googleapis_com.clients.blocked | - | Count |
Connected Clients | cloud.gcp.redis_googleapis_com.clients.connected | - | Count |
Calls | cloud.gcp.redis_googleapis_com.commands.calls.count | - | Count |
Total Time of Calls | cloud.gcp.redis_googleapis_com.commands.total_time.count | - | MicroSecond |
Time per Call | cloud.gcp.redis_googleapis_com.commands.usec_per_call | - | Count |
Average TTL | cloud.gcp.redis_googleapis_com.keyspace.avg_ttl | - | MilliSecond |
Keys | cloud.gcp.redis_googleapis_com.keyspace.keys | - | Count |
Expirable Keys | cloud.gcp.redis_googleapis_com.keyspace.keys_with_expiration | - | Count |
Persisting RDB | cloud.gcp.redis_googleapis_com.persistence.rdb.bgsave_in_progress | - | Count |
Bytes lagging | cloud.gcp.redis_googleapis_com.replication.master.slaves.lag | - | Byte |
Replication byte offset (Replica) | cloud.gcp.redis_googleapis_com.replication.master.slaves.offset | - | Byte |
Replication byte offset (Master) | cloud.gcp.redis_googleapis_com.replication.master_repl_offset | - | Byte |
Bytes pending replication | cloud.gcp.redis_googleapis_com.replication.offset_diff | - | Byte |
Node Role | cloud.gcp.redis_googleapis_com.replication.role | - | Count |
Uptime | cloud.gcp.redis_googleapis_com.server.uptime | - | Second |
Cache Hit ratio | cloud.gcp.redis_googleapis_com.stats.cache_hit_ratio | - | Count |
Total Connections Received | cloud.gcp.redis_googleapis_com.stats.connections.total.count | - | Count |
CPU seconds | cloud.gcp.redis_googleapis_com.stats.cpu_utilization.count | - | Second |
Evicted Keys | cloud.gcp.redis_googleapis_com.stats.evicted_keys.count | - | Count |
Expired Keys | cloud.gcp.redis_googleapis_com.stats.expired_keys.count | - | Count |
Hits | cloud.gcp.redis_googleapis_com.stats.keyspace_hits.count | - | Count |
Misses | cloud.gcp.redis_googleapis_com.stats.keyspace_misses.count | - | Count |
Maximum Memory | cloud.gcp.redis_googleapis_com.stats.memory.maxmemory | - | Byte |
Time in system memory overload | cloud.gcp.redis_googleapis_com.stats.memory.system_memory_overload_duration.count | - | MicroSecond |
System Memory Usage Ratio | cloud.gcp.redis_googleapis_com.stats.memory.system_memory_usage_ratio | - | Count |
Used Memory | cloud.gcp.redis_googleapis_com.stats.memory.usage | - | Byte |
Memory Usage Ratio | cloud.gcp.redis_googleapis_com.stats.memory.usage_ratio | - | Count |
Total traffic to Redis | cloud.gcp.redis_googleapis_com.stats.network_traffic.count | - | Byte |
Pubsub Channels | cloud.gcp.redis_googleapis_com.stats.pubsub.channels | - | Count |
Pubsub Patterns | cloud.gcp.redis_googleapis_com.stats.pubsub.patterns | - | Count |
Rejected Connections | cloud.gcp.redis_googleapis_com.stats.reject_connections_count | - | Count |
region
to gcp.region
Support for GCP overview
No release notes
