Get insights into Google Load Balancing metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud Load Balancing services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 30 metrics that are specific to Google Cloud Load Balancing, like Backend latency, Backend Request Bytes, Backend Request Count, and more.
Use dashboard presets for immediate visibility into availability, usage, and performance of your Google Cloud Load Balancing services.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud Load Balancing logs.
Set custom alerts that trigger remediation workflows.
Google Cloud Load Balancing metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Cloud Load Balancing configuration:
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
