Get insights into Google Cloud Composer metrics collected from the Google Operations API to ensure health of your cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Cloud Composer services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 17 metrics that are specific to Google Cloud Composer, like API Requests, API Latency, Parse Error Count, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Cloud Composer logs.
Set custom alerts that trigger remediation workflows.
Google Cloud Composer metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Cloud Composer configuration:
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
