Get insights into Google Assistant Smart Home metrics collected from the Google Operations API to ensure health of the cloud infrastructure.
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Assistant Smart Home services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
This enables you to:
View and analyze 5 metrics that are specific to Google Assistant Smart Home, like Daily active users, Request count, Request latencies, and more.
Build custom dashboards for your cloud infrastructure.
Analyze Google Assistant Smart Home logs.
Set custom alerts that trigger remediation workflows.
Google Assistant Smart Home metric and log ingestion requires advanced GCP integration.
Compatibility requirements
To add this extension to your environment:
Following GCP integration and Google Assistant Smart Home configuration:
This extension package contains:
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
